Max gross weight
Old September 29th 04, 05:04 PM
Manu Skytt?
Chris wrote in message .. .
How do aircraft manufactures determine the maximum gross weight for a
given plane? I know I've come across articles that mention on a cool day
you can go over the max. gross weight by a percentage, I think 20% was
thrown out there but not sure. Then again, on a hot day you might not
get any where near that. Is it determined by a standard temp?
You dont´t know what is the reason for the maximum gross weight
(unless you know the designers). It is dangerous to assume that
take-off performance defines MTOW. MTOW is also the weight that has
been used as the "most critical weight" during the whole design. It
means that MTOW is there when you calculate the structural loads.
There is a reason why it is called _maximum_ take-off weight.
Old September 29th 04, 06:04 PM
Ron Natalie
"Chris" wrote in message ...
given plane?
They pick a number and then verify that it is OK through a number of tests.
There are a lot of requirements for aircraft to do "this or that" at various weights
up to gross.
For example, the Navion can be approved for various gross weights, some of
it is climb horsepower related. If you have the stronger gear and a bigger engine
you get a 100 lb increase, etc... Some of it is structural in cruise. Some of it
involves sturctures for landing. etc...
Burn whatever said that. If it were purely a performance issue, that would be
true. But that's not necessarily the case. Note that in the above example,
the two limiting factors on the Navion are performance AND the landing gear.
A cold day might give you a bit more performance but it isn't going to make
the landing gear any stronger.
Apache Alternate Gross Weight Jim Burns Owning 1 July 6th 04 05:15 PM
Dutch Roll SelwayKid Piloting 31 June 19th 04 11:43 PM
homebuilt safety anonymous coward Home Built 96 June 3rd 04 04:34 AM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
F35 cost goes up. Pat Carpenter Military Aviation 116 April 11th 04 07:32 PM
