CAP volunteer?
Old October 3rd 04, 06:34 AM
dancingstar
Robert M. Gary wrote:
Has anyone on this list working with CAP. I'm a CFI and would be
willing to donate some instruction if they were interested and if it
were helpful. Is CAP interested in civilian CFIs or just those with a
military background? What does it mean that some CAP orgs are "Cadet"
and some are "composite"? As a CFI would I need to commit to a large
chunk of time as a CFI or just a couple hours a weekend? There doesn't
seem to be much info on the web, they seem to just point you to the
local groups.
-Robert
I believe there is also a civilian branch of the CAP which is composed
of private pilots donating their time as they are able.
Antonio
Old October 4th 04, 01:25 AM
Roger Long
Just be sure you have a high tolerance for the military mindset. Remember,
if you discover a safety problem, it is not a problem and does not exist if
mentioning it would embarrass a senior officer. If it really was a problem,
you can be sure that someone senior to you would have already discovered and
taken care of it.
I joined as a maintenance officer and foolishly thought that it might be
part of my job to review the aircraft logs and give the aircraft a careful
look over. What I discovered was rather shocking. The aircraft were not
legal. AD's were not complied with. Instruments were improperly marked. POH's
were not updated with proper fuel consumption and weight and balance numbers
after engine conversions. One plane was even missing it's ELT antenna. The
coax just ran up under the panel and ended.
I'd already learned that there was no point in reporting such things to Wing
in order to get them corrected because CAP operates to the highest
professional standards, has their planes inspected every 100 hours, and any
problems would certainly be discovered by trained A&P's at the next
inspection.
Just before I took over, a plane was stumbling and losing power on climb
out. Permission to have it checked out was denied because it was clearly the
result of pilots adjusting the mixture improperly at our sea level airport
and something that remedial training would resolve. (It turned out to be all
except two bolts sheered on an intake manifold.)
My C.O., who was quite sympathetic to my position, agreed that getting some
independent verification would be helpful. I therefore, and with his
approval, took advantage of the FSDO safety inspection which is segregated
from enforcement action. They confirmed what I found and discovered so many
other deficiencies that I was a bit embarrassed. I wrote up my report and
gave it to my C.O. to take up to Wing.
It happened to be pilot meeting night. Because the PIC is responsible for
the condition of the aircraft, my C.O. agreed that we had to share the
findings with the pilots.
The result of my report and the pilot meeting was a blast from wing. It was
announced that, "after extensive discussions with the FAA" the aircraft were
found to be fully airworthy and I had overstepped my authority by
investigating the logbooks and inspecting the aircraft. Since the FAR's
require every PIC to have done this, I find it odd that a maintenance
officer would be the only pilot not permitted to do so.
My C.O. was then told to reassign me which he refused to do. Wing simply
stopped answering my calls and emails which made it impossible to do the job
so I quite and went on leave. A few months later, I resigned.
I learned later that the planes were put in the shop and thousands of
dollars spent on them. Personnel changes were made and, when the new
maintenance officer calls up to say something it wrong, it gets fixed.
Basically, they did everything they should have done and I achieved what I
set out to do.
Of course, I'm no longer in CAP and I would like to be because it is
something I believe in. I don't want this post to be viewed primarily as a
criticism or attack on CAP. It's really about the rank based, military,
model of organizations. Making your superiors look good is job one. Safety
and achieving the aims of the organization are jobs 2 and 3. When there is a
conflict, prioritize accordingly.
As I said shortly after all this happened, I thought at first that I had
uncovered a pocket of corruption but I had really only uncovered a pocket of
absolute normalcy.
I just heard on NPR (and excuse me if I didn't get it quite straight) two
FBI agents tried to point out before 911 that middle easterners that the INS
had lost track of were taking flight training and there was talk about
flying airliners into buildings. They were told to keep such fantasies to
themselves. They went around their superiors and it was the end of their
careers. 911 did not resurrect their careers.
This story was in connection with Congress just declining to pass a law to
protect such people. It makes me feel a lot better to know that Congress
would agree that it is appropriate for me to no longer be in CAP. I made
service a lot safer for the people I admire who get the call to go out and
fly in the dark to help others. The price of doing that is no longer being
able to serve myself but that is just the way of things. It's not a CAP
problem, it's a problem of our whole culture.
Roger Long
Old October 5th 04, 12:32 AM
Ronald Gardner
CAP has cadet only squadrons and ones with both cadet and senior members
as well as senior only squadrons.
Cadet's may take flight training for PP while seniors may only go for
additional ratings. CAP offers cadets very good rates for the aircraft
and as you said the CFI can not charge for his time. A 172 here is $50.00
wet a 182 is $55.00 not a bad price.
You only need to take on as much as you wish. However, CAP primary
mission is search and rescue. As an Aux. of the USAF there are the typical
military rules and regulations to be followed. I work with our Group HQ
in managing the Cadet Orientation Flights for a third of the state (PA).
Each cadet get 10 flights, 5- 1 hr powered and 5 glider. This really get
them interested in flight training and some have followed through and
became pilots and went on to be USAF pilots.
So if interested contact your local units and find one that has aircraft
(not all do) and check them out
Ron Gardner
local groups.
-Robert
Old October 7th 04, 02:55 PM
Gary G
What is the general commitment requirements after joing CAP?
How many times a week and for how long
would one need to commit to.
I think this sounds really great, and would like
to learn a bit more about the requirements.
Thanks!
Old October 7th 04, 03:25 PM
Jay Honeck
Well, our squadron meets weekly, for about 2.5 hours. There are encampments
and other training, too.
You can put in as little (or as much) time as you have available.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
"Gary G" wrote in message
Thanks!
Old October 7th 04, 06:37 PM
W P Dixon
Another question about CAPS. Are their any maintinance jobs in CAPS. I got a
package from them ..it had accountants listed but no A&P's etc. , just
didn't make alot of sense to me! Wish I could get some sport pilot training
through them. With my limited funds it would be great to trade my time for
some flight lessons!!! If they give them to old codgers like me! HAHAHA
Patrick
"Jay Honeck" wrote in message
news:2lc9d.198258$MQ5.73279@attbi_s52...
encampments
Jay Honeck
Iowa City, IA
Pathfinder N56993
Thanks!
Old October 8th 04, 12:11 AM
Jay Honeck
a
training
Patrick, you've got to actually talk to a wing commander, rather than
relying on CAP's printed promotional materials.
One thing I've found is that CAP is WAY more involved than their brochures
let on. I'd be willing to bet that someone, somewhere, in CAP, will give
their eye teeth to have an A&P join. (I'm fairly certain you are
commissioned an officer right away, if you're an A&P)
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old October 8th 04, 12:19 AM
Ronald Gardner
Well Jay I didn't know you were in CAP. Some day I hope to get out your way and
meet you.
Ron
Jay Honeck
Iowa City, IA
Pathfinder N56993
Thanks!
Old October 8th 04, 03:33 AM
Jay Honeck
way and
meet you.
Well, Ron, I'm just four months into it, along with my 14 year old son. (It
was actually his suggestion -- how could I argue? :-)
So far, it's been a great experience!
I've really only been concentrating on the cadet program, but hope to find
time to get flight certified and involved in ES training once we're in the
off-season at the inn.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Bush Flew Fighter Jets During Vietnam WalterM140 Military Aviation 609 September 11th 04 03:26 AM
Dress blues needed by volunteer John Miller Naval Aviation 13 August 22nd 04 08:10 AM
Bush flew fighter jets, but never over VIETNAM. ArtKramr Military Aviation 159 July 21st 04 02:22 PM
Sun N Fun - Highs and Lows Jay Honeck Piloting 29 April 21st 04 06:00 PM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
