Ramapriya wrote:
If my understanding is correct, an aircraft stalls beyond that AOA which, when increased any further, produces no (further) lift. If A _wing_ (not an aircraft) is considered stalled whenever the AOA is greater than the AOA of maximum lift. Beyond that point an increase in AOA produces less lift, not more. There is still _some_ lift being produced, all the way up to 90 degrees AOA. (If this was what you meant with "no (further) lift" then you have the general idea right) correct, would it be logical to infer that an aircraft's stalling AOA: The stalling AOA of a _wing_, not of an aircraft. When an aircraft stalls the AOA will of course be somewhere close to the stalling AOA of the wing, but they are still different concepts. a. is dependent on its airspeed, and is independent of its weight and weight distribution, and b. varies, for a given airspeed, with the air density (altitude) The stalling AOA of the _wing_ is generally constant, typically around 15 degrees, and does not depend on any of those factors. The _speed_ at which the _aircraft_ stalls does depend on factors like weight, but the stall will still happen at an AOA somewhere close to the stalling AOA of the wing. CV |
PIREP--CO Experts low level carbon monoxide detector | Jay Honeck | Piloting | 10 | December 3rd 04 11:21 AM |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Altimeter setting != Sea Level Pressure - Why? | JT Wright | Piloting | 5 | April 5th 04 01:04 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
flight level in Flight simulator | Robert | Piloting | 3 | August 20th 03 07:37 PM |
