Can you fly and post to Usenet at the same time?
Sure, but the extension cord's pretty expensive. You can also use one of those IR ports and post wirelessly, though you'd need a pretty powerful beam to reach the ground. A high powered laser ought to be able to deliver the bandwidth you'd need for Usenet posting while piloting an aircraft. ![]() Jose r.a.student trimmed -- Money: What you need when you run out of brains. for Email, make the obvious change in the address. |
On Tue, 04 Jan 2005 03:53:03 GMT, "G.R. Patterson III"
wrote: Can you fly and post to Usenet at the same time? Sure, but the extension cord's pretty expensive. My kids made a brief stop in Seal yesterday at Annapolis. They climbed up onto the radar platform (atop the stern gantry) with their laptops and downloaded their email from a wi-fi node that someone had conviently left open. www.expeditionsail.com |
John Doe wrote:
"Cecil Chapman" wrote: Can you fly and post to Usenet at the same time? That depends on your definition of "flying". Any modern airliner has data hookups for laptops nowadays, at least in business/first class. jue |
If you had the student takeoff for the first time and immediately land again
you would be subjecting him immediately to the most critical and dangerous part of flying.... the flare and landing. And this would be before he had an opportunity at altitude to experiment with the flight controls to see how they react. At 5,000' you can make lots of errors with no problem. At 10', descending to land, you have to do everything right. -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - "John Doe" wrote in message ... I have never piloted an aircraft. I do flight simulation from time to time. Currently I am messing with radio controlled aircraft. There are simulators for that also. Having only simulation experience, but I'm wondering about how piloting is taught. Getting to the point, why not use a long runway and have the student take off just enough for the wheels to leave the ground and then immediately touch down? Again, inexperienced with the real thing, but isn't landing so difficult/critical to warrant special treatment like that? Trainer runways are not long enough? The wear and tear would be too much? That maneuver would be too difficult for a beginner to coordinate? Genuinely curious. Thank you. |
John,
The technique you suggest was widely used prior to and during much of World War I when the intention was to get persons to solo as quickly as possible (and get them into combat as soon as possible; many of whom flew in combat with under 20 hours of total time. They also tended to be killed on their first or second mission, life expectancy was under 30 days for most WWI pilots in the middle portion of the war). Often airplanes with clipped wings or very small engines were used, referred to as penguins, because they would barely get into the air, and could not climb out of ground effect. The technique was dropped as it was learned that landing is only one portion of the process of learning to fly. All the best, Rick John Doe wrote: I have never piloted an aircraft. I do flight simulation from time to time. Currently I am messing with radio controlled aircraft. There are simulators for that also. Having only simulation experience, but I'm wondering about how piloting is taught. Getting to the point, why not use a long runway and have the student take off just enough for the wheels to leave the ground and then immediately touch down? Again, inexperienced with the real thing, but isn't landing so difficult/critical to warrant special treatment like that? Trainer runways are not long enough? The wear and tear would be too much? That maneuver would be too difficult for a beginner to coordinate? Genuinely curious. Thank you. |
World War I when the intention was to get persons to solo as quickly as possible (and get them into combat as soon as possible; many of whom flew in combat with under 20 hours of total time. They also tended to be killed on their first or second mission, life expectancy was under 30 days for most WWI pilots in the middle portion of the war). Often airplanes with clipped wings or very small engines were used, referred to as penguins, because they would barely get into the air, and could not climb out of ground effect. Honestly, Rick, I learn more about aviation history from your posts than from all others, combined. Thanks for posting. Nice article on the Bo conversion in AOPA Pilot this month, by the way. That thing sounds like a 200 knot version of my plane! :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
George,
Hmm, the Brits used airplanes that were capable of flight, but only in ground effect and in a straight line. Once the student had done "solo straights" he was moved into an airplane where he could climb and make turns. Claude Graham-White's school is described in _The Eighth Sea_ by Frank T. Courtney, who worked there and learned to fly just prior to the start of WWI and later flew combat in the war. You are probably correct that the penguins could not leave the ground at the French schools. They also used airplanes that would not climb out of ground effect for the solo straight training, as did the Brits. All the best, Rick |
Well.. you T/O with full power. If you want to then do an immediate
landing, you will have one hell-ov-a power-back-flaps-down-establish-glide-flair-land TRANSITION in a very compressed amount of time. Doesn't sound like a good learning technique to me. -Frank "John Doe" wrote in message ... I have never piloted an aircraft. I do flight simulation from time to time. Currently I am messing with radio controlled aircraft. There are simulators for that also. Having only simulation experience, but I'm wondering about how piloting is taught. Getting to the point, why not use a long runway and have the student take off just enough for the wheels to leave the ground and then immediately touch down? Again, inexperienced with the real thing, but isn't landing so difficult/critical to warrant special treatment like that? Trainer runways are not long enough? The wear and tear would be too much? That maneuver would be too difficult for a beginner to coordinate? Genuinely curious. Thank you. |
You missed trim adjustments & maybe some others too. I've decided not
to do touch and goes on short runways any more in my 172 of 27 years. It just gets too darn busy & creates a chance to screw up. |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
First Time Buyer - High Time Turbo Arrow | [email protected] | Owning | 21 | July 6th 04 07:30 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap | tim liverance | Military Aviation | 0 | August 18th 03 12:18 AM |
Retroactive correction of logbook errors | Marty Ross | Piloting | 10 | July 31st 03 06:44 AM |
