George...
In terms that any competent history major can understand, can you tell me how you want me to fix this type mismatch? Jim -There's two mismatches between the KP0207.htm file and the other files: the parts -list file and full test PDF are Kpparts.pdf and Kptext.pdf on the webserver, but are -KPparts.pdf and KPText.pdf in the URLs in the KP0207.htm file (note the case -difference in the "P"s). So the real URLs to the full text and parts list a - -http://www.rst-engr.com/kitplanes/KP0207/Kpparts.pdf -http://www.rst-engr.com/kitplanes/KP0207/Kptext.pdf - -I imagine that the above to references will break here shortly when Jim fixes the -KP0207.htm file or renames the PDFs. - -Russell Kent Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote: In terms that any competent history major can understand, can you tell me how you want me to fix this type mismatch? Well, the fastest way to fix it is to rename the two files to match the URLs. Alternately, I can change the URLs in the html file and resend that. If you go the first route, rename "Kpparts.pdf" to "KPparts.pdf" and rename "Kptext.pdf" to "KPText.pdf". The difference in names also exists on my computer; the reason I didn't catch it is that the link still works for me. It didn't show up in testing. I'll double-check for that sort of thing with August. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
Renamed both the files with the KP prefix. Try to break it again, if you would
please. Jim - -There's two mismatches between the KP0207.htm file and the other files: the parts -list file and full test PDF are Kpparts.pdf and Kptext.pdf Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote:
Renamed both the files with the KP prefix. Try to break it again, if you would please. Seems fine now. Dave |
| Thread Tools | |
| Display Modes | |
| Kitplanes PTT story | JFLEISC | Home Built | 1 | January 14th 04 04:14 AM |
| Kitplanes CD-ROM directory | David Smith | Home Built | 4 | January 1st 04 10:31 PM |
| KitPlanes - Home Page by Ron Wanttaja | RobertR237 | Home Built | 40 | August 12th 03 11:17 PM |
| Jim Weir's CO detector design in June Kitplanes | Michael | Home Built | 0 | August 9th 03 12:54 AM |
| Jim Weir's CO Detector in Kitplanes June edition. | Michael | Home Built | 0 | July 29th 03 02:32 PM |
