" wrote:
I've seen gear-ups performed by retractable newbies and 10,000+ hr. pilots. A combination of distractions at the right time can sink the best of them. When I based at PHX, I once watched a commercial 737 come down short final with the gear up. They were coming back around for the second time after going around for traffic on the runway. While on the go around, they reported a problem with an engine indicator. It distracted them enough that they missed putting the gear down. Fortunately, the tower caught it and let them know and they went around again. John Deakin wrote a good article on this subject on Avweb, about almost landing a 747 gear up. http://www.avweb.com/news/columns/188536-1.html I also read an investigation report about someone almost doing it in a Learjet on a check flight. They went around when they felt the VHF antenna drag on the runway! http://www.atsb.gov.au/aviation/occu...ail.cfm?ID=220 The PIC (the instructor) is listed as having 17000 hours, 3000 on type. |
![]() "Maule Driver" wrote in message . com... I've always understood the message in that saying to be, "never think you've become so proficient that you are not subject to leaving the gear up" Not fatalistic but a warning to the wise. A corollary: "Whatever your method for remembering to get the gear down, remember no method is foolproof." Bob G said that "IMHO saying (internally) something like "three greens" at least twice before short final should eliminate the possibility of landing gear up. Worked for me." I'd say, "so far..." with considerable respect Bob.. There's always SOMETHING that can screw up your short final planning (e.g. bird strike, a streaker) and cause you to forget. If you haven't seen that SOMETHING yet, just keep living. I almost did it in my glider despite a foolproof method that worked for 1000 hours and hundreds of non-standard patterns and landings. Fortunately it happened during a contest and an observant ground crew radioed me 10 feet off the ground. P-3 in Hawaii shooting low approaches into Lihue airport on Kauai. They decided to do one all the way down to landing, and you guessed it. The airport was closed the rest of the day while they got it off the runway... |
![]() "gatt" wrote in message ... "...those who will forgot to lower their landing gear." Was told this by a guest instructor. I'm not at all comfortable with this. Thoughts? The "secret" in proving this prophecy false is called a "consistent habit pattern" You should naturally always perform a pre-landing checklist for the airplane you're flying, and in addition, I always tacked on an extra check that I completed on final REGARDLESS of all other checks completed, and that check was a GUMP touch and verify check redone on final. There are pilots who would be satisfied with the execution of a normal pre-landing checklist done at the "proper" time. I am not one of those pilots! I do the pre-landing checklist, then I double check with an extra GUMP check TRIGGERED by my being on final. There will be times when you will be interrupted or distracted DURING a pre-landing checklist procedure. It could be ATC asking you for something, or directing you to do something. It could be a fly on the windshield becoming an airplane heading right at you at your altitude. It could be anything! One split second's distraction away from the checklist has caused many an accident that could have been prevented by a simple triggered final abbreviated re-check on final. On final, I ALWAYS made that one last GUMP check......out loud to myself........YOU SAY ITYOU TOUCH ITAND YOU VERIFY IT'S RIGHT EVERY TIME. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired for private email; make necessary changes between ( ) dhenriques(at)(delete all this)earthlink(dot)net |
"gatt" wrote: "...those who will forgot to lower their landing gear." Was told this by a guest instructor. I'm not at all comfortable with this. Thoughts? -c About 40 years ago, I was at the old North American surplus store (looking out over the approach to LAX) and saw a DC-4 on short final (about 100 feet in the air) with gear up. As they passed, I saw the mains and nose gear drop into position. Five years ago, during our annual bonfire here at Spruce Creek, with about 1000 people as witnesses, a Cessna P210 did a gear up landing in front of everybody. I was talking to some friends when I heard "Thump! Thump! Thump!, scraaaaape!) and turned to see the P210 sliding to a halt. That was one expensive evening's entertainment! |
actually.. there are three groups... and you are always in one of the
three... hopefully you always remain in group 1 and never transition to group 2 which holds dual citizenship with group 3 1) There are those that will.. 2) There are those that have.. 3) There are those that will again.. BT (and doing that Gumps check to hopefully remain in Group1) "gatt" wrote in message ... "...those who will forgot to lower their landing gear." Was told this by a guest instructor. I'm not at all comfortable with this. Thoughts? -c |
I've made hundredes of gear up landings...all of them intentional.
Of course they were on water in an amphibian!!!!ggg Nearly got suckered into a gear up landing with a Twin Beech. Short final behind a Cessna. Just as I was about to declare a "go around" the Cessna landed short and taxied off the runway. I was headed for the far end of a 6000' runway and was cleared to land. I had already cycled the gear UP and flaps to take-off and had added power when the tower cleared me to land. I immediately reduced power and only my usual "short final" check of gear, props, mixture saved us from getting that sinking feeling and the terrible noise that follows. I still followed through with an orderly go-around and thought about how the events could have caused a gear up landing. Simply reinforced my routine last check on short final to insure gear down and welded or three green. Ol S&B |
"gatt" wrote: "...those who will forgot to lower their landing gear." Was told this by a guest instructor. I'm not at all comfortable with this. Thoughts? -c That's what they used to say about ground looping a tail dragger. Your instructor's point seems far less apt. -- Ron Parsons |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
