Third Military-Civil MAC Jan. 18, 2005
Old February 10th 05, 02:35 AM
Steve.T
Larry Dighera:
Thank you for that fact - you are missing the point of 14CFR91.113(f).
I think this is the point most of us have been trying to make - and
most of us are not lawyers, but live by the rules of physics and common
sense, something that many times seems lost on lawyers and congress
critters.
Later,
Steve.T
PP ASEL/Instrument
Old February 10th 05, 06:49 AM
Larry Dighera
On 9 Feb 2005 18:31:41 -0800, "Steve.T" wrote
in .com::
It is also very revealing to find that you didn't read the *rest* of
the reg.
(f) Overtaking. Each aircraft that is being overtaken has the
right-of-way and each pilot of an overtaking aircraft shall alter
course to the right.
What does it reveal?
Was one of the aircraft being overtaken from behind in this MAC?
Old February 11th 05, 02:43 AM
Blueskies
"Larry Dighera" wrote in message ...
in .com::
the reg.
Doesn't say anything about being overtaken from behind...
Old February 11th 05, 04:04 AM
Morgans
By definition, overtaken IS always from some degree of behind. Anything
catching up to you from behind 90 degrees (off the side) of the flight path
qualifies as you being overtaken.
Old February 11th 05, 03:30 PM
Larry Dighera
On Thu, 10 Feb 2005 23:04:36 -0500, "Morgans"
wrote in ::
According to the preliminary NTSB report
http://www.ntsb.gov/ntsb/brief.asp?e...26X00109&key=2
The Air Tractor was destined for Huron, South Dakota from Olney
Municipal Airport, near Olney, Texas, with an intermediate
refueling stop in Hutchinson, Kansas.
The T-37 departed Frederick Municipal Airport (FDR), near
Frederick, Oklahoma, en route back to Sheppard Air Force Base
(located in northern Wichita Falls, Texas) on a heading of 100
degrees.
The T-37B and AT-502B impacted farm fields about 3.5 miles east of
Hollister, Oklahoma.
From this information in conjunction with a sectional chart, one
should be able to deduce the likely headings of each aircraft at the
time of impact. Near as I am able to tell from Mapquest* maps, the
T-37 was east bound and the Air Tractor was north bound.
If that constitutes 'overtaking' as defined by the FAA, I would be
surprised.
* For reference:
T-37 intended leg:
Frederick, OK to Wichita Falls, TX
http://www.mapquest.com/directions/m...d&2v=CITY&2pl=
T-37 actual leg:
Frederick, OK to Hollister, OK:
http://www.mapquest.com/directions/m...2v=C ITY&2pl=
Air Tractor intended leg:
Olney, TX to Hutchinson, KS
http://www.mapquest.com/directions/m...2v=CITY&2pl =
Air Tractor actual leg:
Olney, TX to Hollister, OK:
http://www.mapquest.com/directions/m...2v=CITY&2p l=
Old February 13th 05, 02:11 AM
Steven P. McNicoll
ATC was found by the NTSB to be contributory to the cause of this MAC.
Well, that doesn't make it so. What ATC error contributed to this accident?
The NTSB brief says "ATC's lack of awareness that there was more than one
F-16 aircraft in the formation flight, which reduced the ATC controllers
ability to detect and resolve the conflict that resulted in the collision."
I'll wager the controller understands very well that EVERY formation flight
has more than one aircraft in it, although the NTSB may not.
Old February 13th 05, 02:21 AM
Steven P. McNicoll
news
The T-37 had been maneuvering in the MOA. It was not apparent from
the NTSB preliminary report if "3.5 miles east of Hollister, Oklahoma"
was within the MOA boundaries or not. Thanks for that information.
The NTSB preliminary report indicates the collision occurred after the
period of airwork in the MOA and after pattern work at Frederick Municipal
Airport. A check of the sectional chart indicates "3.5 miles east of
Hollister, Oklahoma" is not in a MOA.
So you contend (based on the limited information available at this
time*), that the Air Tractor pilot only violated the equivalent Air
Force Instructions (AFI) 11-202, Volume III of § 91.113(b), while the
T-37 PIC violated both § 91.113(b) and § 91.113(d)?
* http://www.ntsb.gov/ntsb/brief.asp?e...26X00109&key=1
No, I contend (based on the limited information available at this time),
that the Air Tractor pilot and T-37 crew violated the requirement to
maintain vigilance so as to see and avoid other aircraft. I base that on
the fact that a collision did occur between these aircraft.
Old February 13th 05, 02:24 AM
Steven P. McNicoll
"Blueskies" wrote in message
m...
Overtakes tend to be from behind.
  #29
Old February 13th 05, 02:39 AM
Blueskies
ink.net...
m...
My take on this is anything that catches up with you from the 179° behind the plane is overtaking you.
  #30
Old February 13th 05, 03:49 AM
Larry Dighera
On Sun, 13 Feb 2005 02:39:59 GMT, "Blueskies"
wrote in
link.net...
m...
Are you attempting to imply, that if aircraft A impacts aircraft B
from a relative bearing from aircraft B of ~90 degrees to 270 degrees,
it constitutes aircraft B being overtaken by aircraft A by authority
of regulation?
01 Jan 2005 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 January 2nd 05 12:34 AM
22 Aug 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 August 24th 04 06:47 AM
22 Aug 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 August 24th 04 06:46 AM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
