The Latest Military Airspace Grab: 700 Square Miles!
Old February 16th 05, 12:41 PM
Larry Dighera
On 16 Feb 2005 01:52:38 -0800, wrote in
.com::
Larry Dighera wrote:
Does the military _ever_ return its airspace to public use?
AVflash Volume 11, Number 7a -- February 14, 2005
GA PILOTS TAKE ON MILITARY IN N.M.
New Mexico has some wide-open skies, but apparently there is not
enough room there for all the military and civilian pilots who want
to
fly. The U.S. Air Force wants to add 700 square miles to the 2,600
square miles now used by the F-16 Falcons based at Cannon Air Force
Base. The airspace expansion would mean rerouting about 40 civilian
flights per day, and intrude onto GA routes between Albuquerque and
Roswell. "They've grabbed up so much airspace, it's going to be
dangerous for small, civilian aircraft," U.S. Pilots Association
President Steve Uslan told The Albuquerque Journal. "And that's a
long
way around, and that means a lot of fuel and a lot of time wasted."
http://www.avweb.com/eletter/archive...ll.html#189168
I have to add an international flavour (flavor) to this disucssion of
controlled airspace.
http://www.caa.co.uk/docs/7/DAP_EIS03.pdf
(Somewhere beneath the mishmash of controlled airspace depicted on page
2 of the document apparently lies a map of the UK)
That's interesting. Virtually the entire US lies under controlled
airspace; there is very little Class G.
And another showing low level military flying areas:
http://www.mod.uk/linked_files/uk_lfas.gif
Given the current trend, I would expect the US to be totally blanketed
with military airspace, like the UK appears to be, if the military
thought they could get away with it.
Did a lot of flying in CO and NM I think you've got it easy!
Best wishes
David
Thanks for the information.
Old February 16th 05, 03:32 PM
Ed Rasimus
On Wed, 16 Feb 2005 12:41:48 GMT, Larry Dighera
s.com::
to fly. The U.S. Air Force wants to add 700 square miles to the 2,600
long way around, and that means a lot of fuel and a lot of time wasted."
Most of Europe operates under a combination of (maybe it's changed
since I was in the business, but I doubt it), OAT "Operational Air
Traffic" and GAT "General Air Traffic" control. This means there are
two over-lapping (and hence competing) systems of air traffic control
with regulations, airspace, controllers, radars, etc.
On the one hand, it helps the military get the mission done, on the
other, it makes GA flying a bit more complicated for the little guy.
The airlines aren't much impacted.
That's true, but don't confuse that "controlled airspace" with special
use airspace or military requirement. "Area positive control" is the
airspace above a certain altitude MSL that is ALL controlled airspace
meaning you can only enter if on an IFR flight plan. So, no VFR there,
but it ISN'T military special use.
Dare I suggest a bit of inflammatory hyperbole there? We've already
pointed out that with the reduction of military installation in the
last thirty years there have been huge cancellations and eliminations
of no-longer needed military airspace. And, we've also discussed at
great length the fairly easy accessibility of a lot of airspace which
is designated special use, but open when not active. What parts of
this have you not understood?
Absolutely! Big sky theory applies.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
www.thunderchief.org
www.thundertales.blogspot.com
Old February 16th 05, 03:42 PM
s.com::
want
2,600
Force
civilian
and
wasted."
of
page
special
there,
blanketed
and long may it continue!
David
Old February 16th 05, 05:50 PM
Larry Dighera
On Mon, 14 Feb 2005 18:58:00 GMT, "Allen"
wrote in ::
"Larry Dighera" wrote in message
enough room there for all the military and civilian pilots who want to
President Steve Uslan told The Albuquerque Journal. "And that's a long
Go to www.cannon.af.mil . There is a 421 page .pdf of the proposed areas.
The proposal creates a new MOA on the flight path.
Many thanks for that link. Here are some excerpts from the USAF EIS
with my comments interspersed:
DRAFT ENVIRONMENTAL IMPACT STATEMENT FOR
NEW MEXICO TRAINING RANGE INITIATIVE
a. Responsible Agency: United States Air Force
b. Cooperating Agency: Federal Aviation Administration
c. Proposals and Actions: This Draft Environmental Impact
Statement (EIS) analyzes the potential environmental consequences
of a proposal to modify the training airspace near Cannon Air
Force Base (AFB), New Mexico. The proposal would improve airspace
for training primarily New Mexico-based pilots. The existing
airspace no longer suffices to train aircrews in all of the
tactics they will be expected to use in combat. The Proposed
Action and two action alternatives are comprised of four elements:
modifying the configuration of existing airspace (including
expanding the size, operational altitudes, and usefulness of the
Pecos Military Operations Area [MOA] and associated Air Traffic
Control Assigned Airspace [ATCAA], and moving Jet Route J-74
[J-74] and deconflicting commercial traffic five to seven nautical
miles (nm) north of the modified training airspace); creating new
airspace (the Capitan MOA/ATCAA to connect the existing Beak MOA
and the expanded Pecos MOA); flying at supersonic speeds above
10,000 feet above mean sea level (MSL) or approximately 5,000 to
6,000 feet above ground level (AGL) in the airspace; and extending
the use of defensive countermeasures (chaff and flares) to the
new and modified airspace. Alternative A modifies the airspace
configuration, establishes the Capitan MOA/ATCAA, includes
supersonic flight above 10,000 feet MSL, and expands defensive
chaff and flares use. Alternative A does not move J-74. Under
Alternative A, other deconfliction methods could be instituted to
route commercial traffic around active Pecos North ATCAA airspace.
Alternative B modifies the Pecos MOA/ATCAA airspace, reroutes J-74
traffic, includes supersonic flight above 10,000 feet MSL, and
extends use of defensive chaff and flares. The Capitan MOA/ATCAA
would not be created under Alternative B. Under the No-Action
Alternative, aircrews would continue to train in the existing
airspace, fly at supersonic speeds above 30,000 feet MSL, and use
If proposed alternative A or B were implemented, would the military
airspace above 10,000' be returned to civil use?
d. Comments and Inquiries: Written comments on this document
should be directed to Ms. Brenda Cook, New Mexico Training Range
Initiative EIS Project Manager, HQ ACC/CEVP, 129 Andrews Street,
Suite 102, Langley AFB, VA 23665-2769. Telephone inquiries may be
made to Cannon AFB Public Affairs at (505) 784-4131.
Under No-Action, aircrews would be required to travel to bases or
locations with adequately sized airspace for training with current
weapons and tactics. This would both reduce training opportunities
and increase costs.
Under the Proposed Action and Alternative B, rerouting commercial
traffic from the current J-74 and other directly routed civilian
aircraft would add one to two minutes of additional flight time
for a re-routed aircraft.
The increase in sonic booms from one per five days under No-Action
to two per three days under the Proposed Action or Alternatives A
or B would not be expected to affect wildlife or livestock
behavior.
Predicted peak overpressure noise from sonic booms would not be
strong enough to cause damage to structures in good condition.
Sonic booms are not expected to occur at pressure levels that
could damage structures, although older windows or objects on
shelves could be vibrated or damaged. Change in sonic booms from
one per five days to two per three days or any chaff or flare
residual materials would not be in amounts that would affect
property values or land use. The added risk of flare-induced fire
in the affected area, compared to other potential sources of fire,
would be very low. Therefore, no effects on socioeconomic resource
are expected from the Proposed Action or Alternative A or B. In
the unlikely event of property damage due to an Air Force
activity, the Air Force has established procedures for damage
claims.
I'm sure that is a great comfort to Ms. Jacques Olivier and her
daughter:
http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=1
An annual total of 60,770 chaff bundles and 40,286 flares would
continue to be authorized throughout the new, modified, and
existing airspace. ... About 5 million chaff strands are dispensed
in each bundle of chaff.
These mishap rates do not consider combat losses due to enemy
action. F-16C aircraft have flown more than 3,336,700 hours since
the aircraft entered the Air Force inventory during Fiscal Year
1985. Over that period, 120 Class A mishaps have occurred and 113
aircraft have been destroyed.
That would be an average of one F-16C non-combat Class A mishap every
two months!
Under the airspace, 14 percent is lands managed by the Bureau of
Land Management (BLM), 16 percent is state land, and 69 percent is
private.
There are seven counties underlying or partially underlying the
training airspace.
Record searches of both the New Mexico State Register of Cultural
Properties and the NRHP indicate that there are NRHP-listed
properties in one county underlying project MOAs and proposed
expansion areas. As Table 3.6-1 indicates, listed properties in De
Baca county include the De Baca County Courthouse, which was
constructed in 1917; the Fort Sumner Railroad Bridge, which was
constructed in 1906; the Rodrick Drug Store; the Fort Sumner
Women’s Club; and the Fort Sumner Ruins.
Towns within the study area range in population from less than 200
to about 1,900 (University of New Mexico [UNM] 2000).
The majority (78 percent) of the land under the airspace is
privately held. The majority of the public land that would be
affected by the Proposed Action is administered by the BLM.
Approximately 71 percent of all land under the restricted airspace
is held in private ownership, 21 percent are state lands, and 8
percent is administered by the Air Force (Air Force 2001e).
One high-altitude Jet Route, J-74 (J-74), provides direct
east-to-west routing between the Texico VORTAC and the Corona
VORTAC. Jet routes are established under Federal Aviation
Regulation (FAR) Part 71 in Class A airspace to designate
frequently used routings. Jet routes extend from FL 180 to FL 450,
inclusive. They have no specified width; width varies depending
on many aeronautical factors (FAA Order 7400.2 2000). J-74 passes
over the Pecos North High MOA, through the northern portion of the
Pecos ATCAA, and over the restricted airspace associated with
Melrose AFR. Currently, the Pecos ATCAA is capped at FL 300, and
does not conflict with civil traffic generally at FL 310 or
higher. Commercial traffic routed via direct or using J-74
fluctuates from light to heavy, depending on the time of day. Most
traffic involves operations to and from Dallas-Fort Worth, Texas.
Peaks normally occur during mid-morning and mid to late afternoon
(personal communication, Semanek 2004). The 27 FW seldom requests
authorization to use this airspace because it is unavailable for
military use even though it is greatly needed for training. The
lack of access has “conditioned” the 27 FW to constantly work
around this capped airspace, which diminishes the area for
realistic training.
IFR traffic would require ATC clearance to transit the active MOA.
However, VFR traffic could transit the active MOA using the
“see-and-avoid” concept.
The USAF's suggestion that VFR traffic employ see-and-avoid techniques
to avoid mid-air collisions with supersonic military fighter aircraft
reveals a their desire to mislead.
Currently, J-74 provides routing between the Texico Very High
Frequency Omni-directional Radio Range and Tactical Air Navigation
Aid (VORTAC) (east of the New Mexico Training Range Initiative
[NMTRI] airspace) and the Corona VORTAC (west of the NMTRI
airspace). This route passes through the northern portion of the
Pecos ATCAA. Conflicting use of this airspace is resolved by Air
Traffic Control (ATC). J-74 would be moved under the Proposed
Action. This could be accomplished by establishing a way-point
north of the ATCAA, and the route would be divided into two
segments.
Rerouting J-74 and direct traffic to the north encroaches on the
utilization of another jet route further to the north. This is the
area of J-72 ...
The average time between aircraft ranges from 2.7 minutes to 20.9
minutes. The peak hour demand, which occurs on Thursday from 11:00
a.m. to noon, would increase peak traffic from 19 flights per hour
to 30 flights per hour (see Table 4.1-1). The Air Force believes
that scheduling and coordination are required to prevent
over-extension of the National Airspace system.
The Air Force believes the likely number of aircraft requiring air
traffic control service from FAA controllers falls within their
ability and expertise to deconflict in the area north of the Pecos
MOA/ATCAA complex. To fully unencumber active available airspace
for military training, IFR traffic transiting this active airspace
must file their flight plans to avoid the Pecos airspace complex
through the Aeronautical Information System Replacement system.
The existing Pecos MOA complex would be expanded laterally and
vertically under the Proposed Action. The MOAs would be expanded
laterally to conform with the lateral boundaries of the ATCAA
overlying the complex. This expansion would include a southerly
expansion of the Pecos South Low MOA, thus adding additional low
altitude military airspace in that region (down to 500 feet AGL).
Is that an additional airspace grab?
The proposed westward expansion of the Pecos complex would result
in the MOA overlying portions of one Federal Airway, V-291. This
airway provides routing between the Corona VORTAC and Roswell. The
proposed MOA expansion would not totally prohibit use of this
airway.
The proposed southerly expansion of the Pecos South Low MOA, into
the area of the previously defined “Roswell Shelf,” would result
in lowering MOA airspace in that region from 11,000 feet MSL to
500 feet AGL.
Expansion of the Pecos MOA complex could interact with traffic on
the “Worth-3” SID.
Depending on which airspace were active for training, rerouting
could require flying around the entire Pecos MOA/ATCAA complex.
The more likely effect to private pilots would be to schedule a
flight at a time other than the hours during the typical two days
per month when the Capitan MOA/ATCAA was in use. As is always the
case, if an emergency, such as a life-flight were required, the
Air Force would immediately shift or end training to accommodate
the emergency.
The increase in sonic booms from supersonic activity would be
noticeable and can be intrusive. They will occur on average two
times in three days ... Public concerns expressed during scoping
include annoyance of people who are startled by booms, possible
damage to structures (particularly brittle objects like older
windows) and potential adverse effects on domestic and wild
animals. ... Sonic booms under the Proposed Action are not
expected to damage viable structures, such as foundations,
buildings, windmills, radio towers, or water tanks. ... Not all
structures are in good condition. Brittle elements such as windows
and plaster can weaken with age, and become susceptible to
breakage at low boom levels. ... Nonetheless, the presence of
susceptible structures, for whatever reason, means that some
damage attributable to sonic booms is to be expected.
Short-term reactions to new noises may include temporary shifts in
habitat use or activities. For example, prairie dogs and swift
foxes might spend more time in their burrows, where they would be
somewhat insulated from noises (Francine et al. 1995). Lesser
prairie-chickens are known to cease lekking activities for several
minutes to several hours in response to noise disturbances (Giesen
and Connelly 1993); therefore, a sudden onset low-level noise
event from an aircraft overflight could disturb lekking
prairie-chickens. ... Under the Proposed Action, a greater number
of sorties would include supersonic flight and supersonic flight
would occur at lower altitudes than under existing conditions.
Consequently, animals would be exposed to louder noise levels from
sonic booms than they are at present.
Several special-status species are rare in New Mexico, but could
be present during spring and fall migration, particularly along
the Pecos River (NMDGF 2002a, 2002b). These are brown pelican,
piping plover, mountain plover, black tern (Chlidonias niger),
interior least tern, peregrine falcon, bald eagle, and Baird’s
sparrow. These temporary visitors may not be habituated to
aircraft noise. Migrating birds require quality stopover habitat
to rest and eat. Noise disturbance, therefore, could cause
individual special-status birds and other migratory birds (e.g.,
ducks and geese) to leave their stopover area prematurely.
However, negative impacts to special-status populations would not
be expected. ... Wintering bald eagles are sensitive to noise
disturbance (Grubb and King 1991) and may be disturbed by aircraft
noise However, because of the short duration of a noise event
occurring at a particular location on the ground, any resulting
physiological or behavioral disturbance would be short-lived.
Noise from supersonic flight would increase in all parts of the
airspace, but at levels that would not be expected to
significantly impact biological resources. Resident wild animals
and livestock experiencing new noise levels may initially
experience negative effects and may temporarily shift habitat use
or activities as a result (Harrington and Veitch 1991).
Under the Proposed Action, the number of supersonic events
throughout the airspace would increase relative to current
conditions. Supersonic flights at 10,000 feet MSL could increase
the frequency and intensity of sonic booms.
The proposed MOA expansions and new airspace would not prohibit
general aviation use. MOAs are joint use airspace and both
military and civil pilots are required to operate under
see-and-avoid rules of flight.
Clearly, see-and-avoid failed to separate military and civil aircraft
at _subsonic_ speeds in these military-civil mishaps:
http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=1
http://www.ntsb.gov/ntsb/GenPDF.asp?...1FA028A&rpt=fi
http://www.ntsb.gov/ntsb/brief.asp?e...26X00109&key=2
That the USAF can muster the audacity to suggest that see-and-avoid
would be a successful technique for separating _supersonic_ aircraft
is hubris beyond comprehension.
Other socioeconomic factors, such as business activity,
employment, interest rates, and land scarcity (or availability)
are much more likely to affect property values than an altitude
redistribution of flight pattern changes in existing training
aircraft overflights.
What of the reduction of property values do supersonic military
aircraft operations above 30,000' feet over the affected area?
The New Mexico Air National Guard (NMANG) is proposing to create
the Smitty MOA underneath the current CATO MOA, which is 60 miles
southwest of Albuquerque. An EA analyzing this action is underway.
Creation of this new MOA would not affect Cannon AFB or its
airspace
Is this yet another attempted military airspace grab?
Old February 16th 05, 07:43 PM
Ed Rasimus
On Wed, 16 Feb 2005 17:50:56 GMT, Larry Dighera
daughter:
How does expansion of a MOA for operations above 10,000 feet in New
Mexico relate to a mid-air collision in Florida on a low-level
training route?
two months!
Dunno about your math skills here, but I just read about 120 class A
mishaps during the period from FY 1985 to the present--that's a bit
more than 20 years of experience and doesn't begin to address rates
per 100,000 flying hours which for the F-16 (all models) are
significantly lower than previous single-seat, single-engine tactical
aircraft.
The numbers might confirm the contention that flying high performance
tactical aircraft is somewhat dangerous and therefore some airspace
reservation is a good idea.
It isn't "the USAF's suggestion", it is the basic concept of Visual
Flight Rules. Nothing misleading about it--the idea of VFR is to
provide simple rules for flight in VISUAL conditions and without need
for a flight plan or clearance or external third-party deconfliction.
Look out the window and don't bump into things in front of you.
You might also note that aircraft below 10,000 MSL (except in some
special use airspace) is already restricted to airspeeds below 250
KIAS.
"Additional"? If there were not similar airspace adjustments going on
all the time with both increases and reductions in airspace.
Guess what? Civilian aircraft operating under "see-and-avoid" run into
each other at subsonic speeds with much greater frequency. And, when
the military is involved in any mishap an investigation is conducted,
reported in the public domain and blame is assigned. Corrective action
to eliminate those accidents in the future is part of the process.
The "hubris beyond comprehension" here is your flogging of the issue
with little apparent background and a total unwillingness to
acknowledge any of the alternatives to your pronouncements.
For aircraft the size of F-16s, sonic booms above 30,000 feet are
usually not heard on the surface. That's why most supersonic airspace
in the US is at high altitudes.
airspace
Oh, and lest I forget....screw you, Larry. You're clueless.
Ed Rasimus
Old February 16th 05, 08:39 PM
Dick L.
Much as it pains me to agree with a fighter dood, I have to go along
with that remark.
Dick
Former MATS/MAC AC
Old February 16th 05, 10:02 PM
Larry Dighera
On Wed, 16 Feb 2005 12:43:05 -0700, Ed Rasimus
wrote in
In the unlikely event of property damage due to an Air Force
claims.
daughter:
training route?
The USAF's statement regarding claims procedures for "damage due to
Air Force activity" is probably inadequate to replace Ms. Oliveier's
late husband.
The November 16, 2000 fatal F-16/Cessna 172 MAC occurred at 3,000' at
subsonic speed.
I believe the expansion of the MOA relates to low-level supersonic
military operations within "5,000 to 6,000 feet above ground level
(AGL)".
two months!
Perhaps you'll be good enough to assist me in calculating the number
of F-16C non-combat mishaps per month given the USAF's statement, that
120 Class A mishaps have occurred to date (Jan. 2005) since the 1985
Fiscal Year.
aircraft.
Be that as it may, I was commenting on the number of F-16C non-combat
mishaps per month.
I agree, that it tends to confirm the danger involved in flying USAF
F-16C's in a non-combat environment.
Whether or not additional reserved airspace for low-level supersonic
military operations will improved the F-16C's non-combat Class A
bimonthly mishap rate is a speculative matter at best.
Flight Rules.
Yes. It is the 'law' of VFR operations, however in this case it was
suggested as a _viable_ means of transiting the proposed MOA while
low-level supersonic military operations are in progress!
The NAS is a system. As such, it is dependent on each aspect of its
implementation to be functional in order for the whole to function
properly.
FARs are part of that system. The prohibiting of flight in excess of
250 knots below 10,000 feet is a FAR. The military has exploited the
"SPEED AUTHORIZATION GRANTED TO DOD May 18, 1978" which states:
The regulation grants an exception to aircraft having flight
characteristics which preclude safe operation at speeds below 250
knots by providing that if the minimum safe airspeed for any
particular operation is greater than the maximum speed prescribed,
the aircraft may be operated at that minimum safe airspeed.
When the speed of aircraft below 10,000 feet exceeds 250 knots as
mandated by FAR § 91.117(a)*, the integrity of the NAS is compromised
as evidenced by at least two of the three military/civil mishaps, and
corroborated by the military's own study which concluded, that out of
each 20 seconds of flight below 250 knots, 17 seconds must be
dedicated to scanning for conflicting traffic and 3 seconds remained
for scanning cockpit gages; this was for "highly trained" military
pilots.
So it is evident that see-and-avoid is completely impracticable for
maintaining aircraft separation when aircraft are traveling in excess
of Mach one.
http://ecfr.gpoaccess.gov/cgi/t/text....2.4.9&idno=14
Oh, if it were only so simple.
KIAS.
Of course, the military has found a way around that speed restriction.
(see above)
If there are so many adjustments occurring, it should be easy to
provide several examples of _reductions_ in military airspace, please.
That may be due to the relative number of aircraft and the number of
operational hours between the military and civil fleets.
And, when the military is involved in any mishap an investigation
is conducted, reported in the public domain and blame is assigned.
Actually, the same thing occurs for civil mishaps; the NTSB finds and
reports probable cause. The specific action taken by the FAA against
a civil pilot is a matter of public record. Here's what occurred in
the case of the November 16, 2000 fatal MAC in Florida:
Air Force officials said the mistakes [sic] Lt. Col. Parker made
leading up to the crash over Manatee County deserved only
"administrative action" — a written or verbal reprimand. He will
also retain his officer's pension.
The decision regarding Parker was made by Brig. Gen. John Rosa,
commander of Moody Air Force Base in south Georgia, where the F-16
pilots were stationed at the time of the crash.
Citing confidentiality laws, Air Force officials would not
elaborate on what form of administrative action was taken. They
also would not say which of the mistakes he made the day of the
crash led to the reprimand, the Sarasota Herald-Tribune
reported...
-- Associated Press
Corrective action to eliminate those accidents in the future is part
of the process.
Well, at least the USAF tries to give the impression that that occurs:
Thursday, June 21, 2001
Associated Press
BRADENTON — Military aircraft on low-level training missions in
civilian air space should fly at the slowest possible speed, the
Air Force says following an F-16 crash that killed a civilian
pilot.
The Air Force has updated flight manuals and safety procedures on
high-speed, low-altitude flights after reviewing the collision of
the F-16 Fighting Falcon and a Cessna 172 over Manatee County on
Nov. 16, military officials said Tuesday.
Pilots on training maneuvers in civilian air space now are
required to fly at the slowest possible speed although not less
than 250 knots, or 287.5 miles per hour.
In an official review of the crash, released in March, the Air
Force downplayed the F-16's 480 mph speed as a factor. The pilot
was flying 180 mph faster than federal and Air Force guidelines
then allowed for military jets in air space near
Sarasota-Bradenton International Airport.
The updates are written in general terms and refer to slowing the
aircraft and reviewing training routes near congested flying
areas.
The report, overseen and released by Air Force Chief of Staff Gen.
Michael Ryan, comes more than seven months after the F-16, flown
by Capt. Greg Kreuder, collided with the Cessna, killing its
pilot, Jacques Olivier, 57, a [ATP rated] flight instructor from
Hernando County.
"We can't speculate on whether these recommendations would have
affected the outcome of the crash had they already been in place,"
said Air Force spokeswoman Maj. Cheryl Law. "We always consider
safety as our highest priority." ...
When the government perpetrates injustice, it is the prerogative of a
citizen of a free nation to publicly air his views. I believe I have
provided evidence of reasonable background knowledge, and haven't seen
any alternative "pronouncements" to which you refer.
The proposed MOA enlargement is to permit supersonic operations at
between 5,000' and 6,000' as stated in the USAF EIS. Why are you
referring to 30,000' feet? That is the current, not proposed,
altitude floor in the MOA for supersonic operations.
airspace
Ed Rasimus
Well, it would appear one of us is. But at least I'm not forced to
profane a fellow airman due to lack of reasonable arguments.
Old February 16th 05, 10:07 PM
Morgans
David
Please, please, take the time to snip out most of the preceding post.
Failing to do so is very rude.
  #29
Old February 16th 05, 10:37 PM
Larry Dighera
On 16 Feb 2005 12:39:23 -0800, "Dick L." wrote
in . com::
with that remark.
Dick
Former MATS/MAC AC
I'll take your agreement with Ed's remark as an admission, that you
have no valid argument to present on the subject proposed MOA
expansion.
  #30
Old February 16th 05, 11:28 PM
Ed Rasimus
On Wed, 16 Feb 2005 22:02:08 GMT, Larry Dighera
wrote in
claims.
daughter:
training route?
late husband.
And, your arguments citing a mishap in Florida relating to a MOA
change in New Mexico are inadequate to address the training
requirements of combat forces in high performance tactical jet
aircraft. I'm deeply sympathetic to Ms Olivier or Oliveier, but I'm
also sympathetic to the surviving wives and families of quite
literally hundreds of USAF, USN and USMC tactical aviators who died or
were imprisoned when lost in military flight operations in the service
of their country.
subsonic speed.
(AGL)".
So, creating a MOA which would advise all aircraft operators of the
intended operations would not be as good as operating in non-special
use airspace as was being done in the Florida accident?
two months!
Fiscal Year.
My point was that 3.3 MILLION hours per 120 mishaps (which aren't all
mid-airs or even aircraft losses and which didn't all occur in special
sue airspace) is a statistic that is better viewed as mishaps/100k
flight hours rather than mishaps/month.
aircraft.
mishaps per month.
Which means what relative to training airspace in NM?
In ANY environment.
Precisely! The mishap rate and the need for training airspace are not
related to each other!
Flight Rules.
First, note that the tactical applicability of supersonic operations
at high or low altitude is very limited. Second, note that most
PLANNED supersonic operation is done at high altitude, such as
high-speed intercept training. Third, note that UNPLANNED supersonic
operation can occur momentarily during air combat maneuver/BFM
training and that might be at relatively low altitude (although most
tactical training employs a 10k or 5k AGL "floor"). Fourth, note that
most training in which supersonic operations are planned or highly
likely will be conducted in restricted airspace rather than MOA.
Fifth, note that transiting of MOAs by VFR traffic while allowed is
discourage; by IFR traffic is not allowed when the MOA is in use.
properly.
pilots.
of Mach one.
You confirm my asssertion of cluelessness. Some military aircraft
don't function very well at 250 KIAS unless in landing configuration.
They burn fuel at high rates and are restricted in their agility. For
that reason the FARs have waivered the 250 max exactly for the reason
you quote "minimum SAFE airspseed".
Let's take this to an example you are probably more familiar with:
driving your car. How much time when driving do you spend looking out
the window versus staring at your speedometer? Ditto for airplanes.
Don't knock it if you haven't tried it.
KIAS.
(see above)
And, you can take it to the bank that they will continue to do so.
Did you read previous posts? Walker AFB, Roswell NM. Williams AFB,
Chandler AZ. Webb AFB, Big Spring TX. Wendover AFB, Wendover UT.
Wurtsmith AFB....and those are just W's--all closed within the last 30
years, all with airspace which was no longer needed.
And, it may even be due to private pilots being clueless about where
they are. Or maybe they are talking on their cell phones.
reported...
-- Associated Press
If you read the accident report you would find a clear detailing of
the "mistakes" and you would learn whether they were primary,
secondary or lesser causes.
As for the "administrative action" it could range from corrective
training to removal from flight status to loss of pay to mandatory
retirement. But, the mere fact that he didn't have his sword broken,
his buttons cut off and his epaulets removed before hanging in the
public square MIGHT mean he wasn't guilty of anything significant!
Injustice? Going through a public hearing process before designating
special use airspace is now "injustice"?
And, reread my sentence above: "unwillingness to acknowledge any of
the alternatives to your pronouncements"--that's not "alternative
'prounouncement'".
Posters have given you blocks of information regarding special use
airspace refuting your basic position opposing expansion of the MOA.
You continue to throw stuff at the wall hoping that some sticks,
regardless of relevance.
I'm referring to 30,000 feet BECAUSE YOU REFERRED TO 30,000 FEET!!!!!
That's YOUR quote above mine.
Ed Rasimus
Excuse me? I've got more time in the Beak MOA inverted than you've
apparently got in military jets. And, if you've missed my presentation
of "reasonable arguments" you can't read. Oh, and "screw you" isn't
profaning you, it's exercising restraint despite the frustration at
your apparent inability to make any sense of all of this.
If you want profaning of "a fellow airman", I suggest you scan recent
posts from Dudley--he's proven a master at it. But, I can stoop if
need be.
Ed Rasimus
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Piloting 12 April 26th 04 06:12 PM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
