Glider pilot rolls inverted and exits at 1400 feet AGL
Old July 29th 14, 02:47 PM posted to rec.aviation.soaring
son_of_flubber
Default Glider pilot rolls inverted and exits at 1400 feet AGL
On Tuesday, July 29, 2014 3:40:36 AM UTC-4, wrote:
wouldn't your glider pitch up and whack you after you released the stick?
On my SZD glider with trim adjustment independent of the stick, I suppose I could (in theory) set the trim position all the way forward, and then just let go of the stick, belts already off, when I was ready. Glider go down momentarily.
Even with the trim set for level flight, the glider would take a second to return to level flight after you let go of the stick and hopefully you would be clear by then.
Old July 29th 14, 04:53 PM posted to rec.aviation.soaring
Mark628CA
The advice to use negative G forces to extract yourself from the glider is valuable, but be aware that if your instrument panel is fixed, your legs may become trapped and a bailout will be much more difficult and probably very painful. You could even suffer broken legs, which will make the parachute landing really awful.
Do what you have to do, but try to avoid leaving parts of yourself in the cockpit.
Old July 29th 14, 08:08 PM posted to rec.aviation.soaring
Chris Nicholas[_2_]
Individual experiences may or may not be a good basis for future decisions, but 2 UK instances come to mind.
Well known pilot collided, found he had control (as did the other) and decided to bring it in to a landing rather than bale out. Tail came off at about 1000 feet, too low to bale out now, and he died.
More recently, another well known pilot had collision, glider uncontrollable, bunted, and it took all his strength and 3/4 round the outside loop before he got the canopy off and got out. Survived with relatively minor injuries. (The other landed OK.)
After the first, several people in the BGA decided that baling out was safer that hoping a damaged tail (or whatever) would keep on and permit a landing.
It seems that staying in and hoping to land is decided upon without enough information. Bill's story suggests the same.
(I don't think I could get out anyway - with infirmity, I can only just get out unaided, minus parachute, on the ground. I have Flarm and PCAS - and wish I had a BRS.)
Chris N
Old July 31st 14, 03:57 AM posted to rec.aviation.soaring
On Monday, July 28, 2014 11:14:48 AM UTC+12, son_of_flubber wrote:
http://news.stv.tv/tayside/282807-pi...de-in-mid-air/
Can anyone advise the make of the two sailplanes involved.
John
Old July 31st 14, 09:19 AM posted to rec.aviation.soaring
Ramy[_2_]
And where they using Flarm?
Ramy
Old July 31st 14, 11:46 AM posted to rec.aviation.soaring
John Galloway[_1_]
Ramy
No Flarms. There exists a difference of views at the Scottish Gliding
Centre
as to whether Flarm alerts have a net benefit for gliders on our local
ridge
overflying two villages. The worry is that pilots could be alarmed by
alarms
and thus overloaded.
John Galloway
Old July 31st 14, 01:53 PM posted to rec.aviation.soaring
Peter Higgs
Does anyone know what trajectory a glider takes when the pilot jumps out?
The loss of weight forward of the C/G would upset the trim by a significant
amount.... More so if the glider was inverted.
Old July 31st 14, 06:33 PM posted to rec.aviation.soaring
Ramy[_2_]
An amazing photo of the bailout just emerged:
http://www.cambridge-news.co.uk/Hunt...0731101407.htm
Ramy
Old August 2nd 14, 03:21 PM posted to rec.aviation.soaring
I notice that he did not jettison his canopy, just opened it.
In the first frame you can see it still attached.
Still worked out ok.
Old August 2nd 14, 04:14 PM posted to rec.aviation.soaring
Dave Nadler
Still worked out ok...
Please be sure you understand the bailout sequence for
any aircraft you fly. For SH gliders (as this appears
to be), jettisoning the (non-Roget-hook-equipped) canopy
can result in the canopy swinging sideways and hitting
you in the head and incapacitating you, or merely
breaking your jaw as happened to a friend of mine.
Consequently, IIRC the procedure was changed to open
only and do NOT pull the jettison knob.
Please be safe out there and MAKE SURE you know
your jettison procedure! Then periodically practice
on the ground...
Best Regards, Dave
Glider pilot and ME 163 Komet Pilot Rudy Opitz Has Died Paul Remde Soaring 5 May 12th 10 12:56 AM
JetPilot and Team Payne win USA OLC with Brilliant Last Minute 1400 km Wave Sortie [email protected] Soaring 1 October 12th 07 05:28 AM
Youth lands glider after dad blacks out at 3,000 feet [email protected] Soaring 0 July 27th 06 12:40 AM
New style emergency exits Michelle Piloting 7 February 7th 06 10:45 PM
5000th glider rolls out the SZD factory Janusz Kesik Soaring 0 November 19th 04 07:29 AM
