#21
Mike...
Would you consider autorotation a LOW LIFT condition??? I kinda thought you would...so please refer to the following and read about the CONING HINGE. I and I'm sure the group will await your response. http://www.copters.com/mech/mr_semi.html |
![]() No. A steady autorotation is not a "low lift condition"; it is a low shaft power condition. In flight the lift is equal to the aircraft's weight times it's load factor, g's. Low lift means on the ground, or in pushovers, or at unusually low weights. Autorotation gives zero or negative steady blade lag, but the coning does not decrease. In fact, if you measure it closely enough you will see that the coning actually increases slightly in autorotations because the blade lift distribution shifts outboard during autos. "Bob" wrote in message ... Mike... Would you consider autorotation a LOW LIFT condition??? I kinda thought you would...so please refer to the following and read about the CONING HINGE. I and I'm sure the group will await your response. http://www.copters.com/mech/mr_semi.html |
Are There Any P-47 Experts Out There Too? | Schlomo Lipchitz | Naval Aviation | 10 | February 15th 05 03:06 AM |
Advice and experts with 400 series Cessnas (414 and 421), purchase and training | [email protected] | Owning | 36 | January 9th 05 02:32 AM |
PIREP--CO Experts low level carbon monoxide detector | Jay Honeck | Piloting | 10 | December 3rd 04 11:21 AM |
aero-domains for homebuilt experts | secura | Home Built | 0 | June 26th 04 07:11 AM |
Aircraft Id needed from newsgp experts! | RGP | Military Aviation | 1 | January 1st 04 07:15 PM |
