Where is the LX S80?
Old October 9th 14, 05:50 PM posted to rec.aviation.soaring
Default Where is the LX S80?
Excellent questions and observations.
I am focused on the S80 and Butterfly primarily because they have an artificial horizon but also would like a unit that can filter out horizontal gusts that cause me/us to think we have entered a strong thermal. It also would seem that the instantaneous wind readings would be very helpful when flying convergence lines.
Old October 9th 14, 06:55 PM posted to rec.aviation.soaring
Richard[_9_]
On Thursday, October 9, 2014 9:36:20 AM UTC-7, jfitch wrote:
On Thursday, October 9, 2014 7:31:08 AM UTC-7, Richard wrote:
On Wednesday, October 8, 2014 7:47:11 PM UTC-7, wrote:
On Wednesday, October 8, 2014 9:24:51 PM UTC-4, wrote:
There has been soooooooo much time from the initial announcement of the S80 and the now just released manual that they may have changed the design perameters of the unit.
I want to hear from LX how the winds are computed.
Reading through the manual, there is no mention of wind at all. Also no mention of being able to connect a compass module, which is referenced on their S80 page in the second to last line of the paragraph directly below the picture of the unit. It states: "fast wind calculation with external compass"
http://www.lxnav.com/products/lxnav-varios/s80.html
The same web page mentions under "Hardware": integrated synthesized speech output. Yet in the manual, it states on page 45 under "stall speed", that the voice module is _not_ integrated in the S80. Confusing.
Interesting feature is ability to set the battery chemistry and battery warnings.
I heard from LXNAV
Compass can be connected via can bus. In the moment compass is not available.
Maybe some sounds are not implemented , but will be in future releases.
Concerning Winds: I have both the PowerFlarm-V7-Ultimate Le system and the Butterfly Vario in my glider. I do not see a significant difference in the wind calculation between the systems. Approx 400 hours of flying comparing the systems.
Richard
www.craggyaero.com
Richard, how do the winds compare in instantaneous changes? Also what to you have the wind filter set to?
I don't have a V7 (never seen one) but it appears to calculate winds by the traditional schemes: either thermal drift or GPS track velocity compared to heading and airspeed. On my Butterfly, in steady state conditions the inertial wind compares with the traditionally derived schemes as seen on PDA, Cambridge, etc. However the Butterfly reports momentary abrupt changes in wind in and around thermals, and sometimes during glides, that these traditional methods miss entirely. Based on other available data, I believe the Butterfly is correct.
If you fly with iGlide, Butterfly uses the rapid instantaneous wind changes in thermals for their thermalling assistant, which presents a wind direction arrow in each lift dot each second. At least in well organized thermals, the instantaneous wind reliably points towards the center of lift, and can be used to center.
At other times (notably on final glides over the Carson valley heading back to Truckee) there will be a sudden increase in wind that lasts for many minutes (or perhaps an altitude band, or geographic location) before reverting the the prevailing wind. For example it will go from 8 knots southwest to 28 knots south for 5 minutes, then back - as reported by the Butterfly. This can be confirmed by comparing GPS to TAS. After some time, the traditional methods will agree. When the strong wind is cross, the traditional method may never show it, while the Butterfly does.
My conclusion is that in steady state, and particularly for headwind/tailwind components, averaged over some time, the traditional and inertial methods agree well. But the traditional methods miss a lot of rapid changes and there are times when this is significant.
One problem with observing every change in wind is that if final glide calculations are based on them, you see it varying rapidly as wind gradients are encountered. As far as I know, the Butterfly itself has no way to set the averaging filters differently for final glide calcs, which would be desirable.
A curiosity (but proof of Butterfly's method) is that while the engine in my ASH26e is running, traditional wind calculation is off by a huge amount since the tail pneumatics are in the prop wash. However the Butterfly correctly calculates the wind during engine runs.
I usually fly with my wind filter in the Butterfly at 20 sec. I agree with you for the traditional and inertial for final glide. Also the V7 uses some inertial assist. I have it set to 4 of 4 . I also have the butterfly set to 50% for vertical airmass filter Inerital vs TE.
If you want to set the wind filter at l or 2 sec you can see rapid wind changes with the butterfly but I am more concerned with the final glide winds..
I don't see a way to change the butterfly filter just for final glide. That is a question for Marc at Butterfly.
Richard
www.craggyaero.com
Old October 9th 14, 07:28 PM posted to rec.aviation.soaring
jfitch
I heard from LXNAV
Richard
www.craggyaero.com
At other times (notably on final glides over the Carson valley heading back to Truckee) there will be a sudden increase in wind that lasts for many minutes (or perhaps an altitude band, or geographic location) before reverting the the prevailing wind. For example it will go from 8 knots southwest to 28 knots south for 5 minutes, then back - as reported by the Butterfly.. This can be confirmed by comparing GPS to TAS. After some time, the traditional methods will agree. When the strong wind is cross, the traditional method may never show it, while the Butterfly does.
Richard
www.craggyaero.com
Richard,
Ok that explains why I am seeing something different. I have the wind filter set to 2 seconds. I find it very interesting to see just how dynamic the wind can be.
Some PDA software seems to have the ability to use a different wind source for final glide. I will put the feature request in to Marc for iGlide.
The S80 suggests that the inertial assist for the vario has only a small influence. I have the vertical air mass filter on the Butterfly set to 80% inertial. 100% seems to make it very twitchy. At 80% I seem to be able to see the difference between actual air mass movement and glider inefficiency. At least for the price of the Butterfly I have convinced myself I can!
Old October 14th 14, 02:51 PM posted to rec.aviation.soaring
Richard[_9_]
I heard from LXNAV
Richard
www.craggyaero.com
Richard
www.craggyaero.com
Richard,
S80s are on the way.
I should have in stock on Monday.
Richard
www.craggyaero.com
Old October 21st 14, 12:24 AM posted to rec.aviation.soaring
You have a built in filter that can eliminate false readings due to gusts. It's called your backside. If you can't feel the acceleration, it's not there.
Old October 21st 14, 12:48 AM posted to rec.aviation.soaring
Now that was a very sensitive, insightful, and constructive comment for this thread. Thank you.
Old October 21st 14, 01:33 PM posted to rec.aviation.soaring
krasw
On Thursday, 9 October 2014 04:18:53 UTC+3, jfitch wrote:
On Wednesday, October 8, 2014 3:30:33 PM UTC-7, wrote:
What are the differences in the inertial nagivation systems between the Butterfly vario and the S80?
The LX literature was confusing on how wind calculations are made and it says in one place that the S80 makes continuous wind calculations on its own but in another place it says that the S80 requires the compass module to improve wind calculations.
There is no information in the manual about inertial vertical air mass movement nor inertially derived wind - the two most impressive things about the Butterfly (Air).
It looks like it does have a very nice Flarm display and flarm warnings - the two least impressive things about the Butterfly.
I really can't think any scenario where I would not absolutely wan't to see variometer info and Flamr radar at same time, on separate displays. Main job of the variometer is to tell you what the glider and airmass are doing vertically. That seems to be very diffult thing to do. Flarm radar display is best shown on big moving map, with additional LED display on top of your panel.
Old October 21st 14, 03:59 PM posted to rec.aviation.soaring
jfitch
Why separate displays? On the Butterfly, all the vario information is always shown, regardless of whatever screen you are looking at - traffic, AHRS included.
  #29
Old October 21st 14, 04:03 PM posted to rec.aviation.soaring
jfitch
You have a built in filter that can eliminate false readings due to gusts.. It's called your backside. If you can't feel the acceleration, it's not there.
Acceleration due to a a vertical or horizontal gust are not discernible by the human backside. Both result in an increase in lift: the former due to an increase in the angle of attack and the latter due to an increase in air speed. Both can be used to gain energy, but you will find circling in the latter a pointless exercise. Which is why every variometer manufacturer is trying to differentiate them.
  #30
Old October 21st 14, 04:21 PM posted to rec.aviation.soaring
Thank you for such a clear explanation for why vario manufacturers are working so hard on these issues. It also makes me feel better about getting fooled by "my backside" and my vario when flying cross-country.
