iPhone 6+ or Galaxy Note 4?
Old October 17th 14, 08:15 AM posted to rec.aviation.soaring
Duster
Default iPhone 6+ or Galaxy Note 4?
With the larger-format 5.5" iPhone 6 Plus coming out to match the Galaxy Note 4, which of those two do glider pilots recommend for running common navigation software? ...or other pluses/minuses?
Michael
Old October 17th 14, 09:04 AM posted to rec.aviation.soaring
Christopher Bishop
Michael
Wait a couple more weeks and get a nexus 6, android for xcsoar.
Old October 17th 14, 05:21 PM posted to rec.aviation.soaring
Dan Marotta
Before you decide on either try to have a viewing in full sunlight to
see if they're, in fact, useful at all.
I had a Galaxy III for a while and found it next to useless in direct
sunlight. I made a sun shade from construction paper and tape and that
helped but, when the sun was behind me, the Galaxy III was useless. I
used my wife's Nexus 7 in my glider and found that it was readable in
sunlight, but just barely when the sun was behind me.
I have no experience with the Oudie but I lot of people like them.
I use a Dell Streak 5 which is fully readable in all lighting
conditions, including the sun over my shoulder. I like it so much, in
fact, that I bought a second one to keep as a spare for that inevitable
day when the one I fly with dies or gets stepped on. You can get them
brand new on Amazon for $100 and XCSoar and Tophat are free.
Dan Marotta
Michael
Old October 17th 14, 06:22 PM posted to rec.aviation.soaring
jfitch
Michael
Depends on what software you want to run? Certainly there are more programs available for Android, however iGlide only runs on the iPhone and makes the others look two decades dated.
Old October 17th 14, 07:13 PM posted to rec.aviation.soaring
Bruce Hoult[_2_]
Michael
Wow, that's pricey!!
OK, it's cheaper than the iPhone, let alone the glider. And I'm sure
the market is small and the developer needs to buy groceries...
Does it work only from the internal sensors (e.g. GPS), or can it
receive info from airspeed, heading, vario etc? If so, how?
Old October 17th 14, 08:44 PM posted to rec.aviation.soaring
jfitch
Michael
iGlide will work with the internal GPS, maybe in the future it might use the barometric sensor in the iPhone 6 though one shouldn't expect great vario performance from that.
But you can connect it to your other instruments one way or another. With a Butterfly vario, via WiFi. With other instruments, via the Air Avionics (Butterfly) Air Connect, which creates a WiFi connection from your standard 9 pin serial NMEA stream. Or buy Air's black box sensor/recorder Air Sens which also includes the WiFi interface (but I don't think gives you variometer functions?).
For navigation and most glide calculations the internal GPS alone does an OK job. Connected to your other systems you get barographic glide calculations, Flarm leeching display, thermal assistant, etc. Price is a bit cheaper than SYM, even for the Pro version, eh? No other software even comes close to the user interface.
Old October 17th 14, 11:59 PM posted to rec.aviation.soaring
Craig Funston
Michael
Is the iPhone 6 plus display easily readable in strong sunlight?
Craig
Old October 18th 14, 02:06 AM posted to rec.aviation.soaring
jfitch
Michael
Craig
Good question. I haven't been able to find one to look. The brightness specs are the same as the 5s, but the contrast specs are better. I have found the 5s to be marginal in direct sun, and unreadable if there are reflections in the direct sun. Somewhat better if you turn off terrain. Not as bright as the Avier/OudieII, but brighter than the iPaq 39xx. The screen on the iPhone is MUCH higher resolution than the Avier/Oudie, but physically smaller until you get a 6 or 6 plus. The larger size cannot hurt. It is not a transflective like the Dell.
Old October 20th 14, 07:13 AM posted to rec.aviation.soaring
Surge
Michael
Besides the screen brightness, there are a few other questions I'd ask such as:
1. If also intend using the phone for every day use, which of the two eco systems do you want to tie yourself into? Apple's payware, do-it-our-way-only system or the more flexible, more open Android eco system?
2. Does Apple cover accidental damage?
With Samsung you get also get two free, no questions asked, free repairs for accidental screen or water damage. (ADH Premium)
3. Battery life. Not having to use external power saves on the expense and hassle of extra cabling and an external power source to keep the device running. The Note 4 has a significant advantage over the iPhone 6 in terms of battery life.
I use the Note 2 with XCSoar and from a full charge I get 8.5 hours of continuous use which is longer than I plan to stay in the air for.
Old March 27th 17, 11:01 AM posted to rec.aviation.soaring
The kobi e readers (at least some of them) are compatible with xc soar. Shouldn't e readers be a smart way to go with the lower battery use and very little disadvantage with black and white? Has anyone tried any other eReaders with xc soar? I imagine most E readers really are not built to operate in direct sunlight, same as phones/tablets but there could be some exceptions.
The dell streak 5" is around 300 dollars now.
FS: iPhone 6, 6Plus, 5S, 5C, HTC, iPad Air, Macbook,Galaxy S5 andlots more John Nicholas Soaring 0 September 22nd 14 05:08 PM
C-5 Galaxy approaches WPAFB - C-5 Galaxy WPAFB final apch 4-17-07.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 0 April 18th 07 03:03 PM
C-5 Galaxy approaches WPAFB - C-5 Galaxy WPAFB apch 4-17-07.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 0 April 18th 07 03:03 PM
C-5 Galaxy-getting in some flight time - C-5 Galaxy lft bank Dayton,OH 12-14-06.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 0 December 17th 06 04:41 PM
C-5 Galaxy-getting in some flight time - C-5 Galaxy rt bank Dayton,OH 12-14-06.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 0 December 17th 06 04:41 PM
