Cambridge 302 and GPS-NAV owners – IMPORTANT NEWS
Old November 26th 14, 02:23 AM posted to rec.aviation.soaring
Tango Eight
Default Cambridge 302 and GPS-NAV owners - IMPORTANT NEWS
News from ClearNav Instruments...
The Garmin GPS date problem in C-302 can be repaired, if no other issues are present, for $180 + shipping/handling.
Barograph calibration, if required, would be $60 additional.
All other repairs are subject to $350 flat rate, include calibration and 1 year warranty.
See http://www.clearnav.net/main/cn-service.html
Best regards,
Evan Ludeman for CNi
Old November 26th 14, 02:46 PM posted to rec.aviation.soaring
Tango Eight
I added an area for CAI 302 owners over on the ClearNav discussion board. There's a whole lot of nothing there right now, but 302 owners may feel free to sign up and utilize this area for mutual support. I have around 600 flight hours on the 302 system and still have one in my own ship (it makes a good backup :-)), so if nothing else, you've got me. Advantages vs r.a.s. may or may not be of value to anyone, the "market", as usual, can make that decision.
http://clearnav.net/simplemachinesforum/index.php
best regards,
Old November 27th 14, 05:43 PM posted to rec.aviation.soaring
CLewis95
For anyone keeping score ..
I powered up my (3) GPS/NAV Model 20's .. All said UTC 04/12/95.
Curt - 95
Old November 28th 14, 04:41 PM posted to rec.aviation.soaring
Paul Remde
Hi Curt,
Please make sure they have a lock on satellites before checking the date.
The green light blinks when the unit has a lock on satellites.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_______________________
"CLewis95" wrote in message
Curt - 95
Old November 28th 14, 04:55 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Correction on my group. Test 10, 7 failed.
For those keeping score, failed serial numbers from my group (Model 20 unless otherwise stated):
C0H5
C1SJ (Model 25)
C1ER
0418 (Model 25)
0205
C0ZN
C0DD
Good:
C0GZ
0327
0440
Have two more I might be able to check today.
Old November 28th 14, 05:59 PM posted to rec.aviation.soaring
CLewis95
yep .. I waited until each had solid lock.
Old November 28th 14, 07:04 PM posted to rec.aviation.soaring
Peter von Tresckow
Looms like I'm batting .500. The model 20 is fine but the volkslogger is
firmly in the 1990s :-(
Pete
Old November 30th 14, 01:36 AM posted to rec.aviation.soaring
Tim Taylor
Finally got a chance to pull my glider out and test the 302 today. I don't have a 303 anymore and use the 302 as my backup logger and vario so don't look at the files very often.
Using the Cambridge Utility on my iPAQ, I checked the files and there were files from July through September showing, but my last two flights in October and November were not listed at all.
I switched over to ConnectMe and it did not show all the flights back to July, but did show two flights from 1995, not a good sign.
If you are checking the files use ConnectMe to look for the miss dated files, you may not see them with the Cambridge utility program.
  #29
Old November 30th 14, 10:12 PM posted to rec.aviation.soaring
HGXC[_2_]
Mine 30checks out OK for now its COJH and I don't know how old it is. What should I be doing...plug iy\t in every few weeks? send it out even if its ok?
Any way I can find out its age?
Dennis
  #30
Old December 4th 14, 02:18 AM posted to rec.aviation.soaring
David Kinsell[_2_]
if its ok?
I don't see much future in the recharge-frequently option. Once
batteries start to fail, they go downhill rapidly.
If you intend to use it long-term, I'd say go ahead and send it in.
If anyone missed the richard@craggyaero posting recently, it has lots of
good info on any logger using the Garmin GPS25 module.
ClearNav CNv Vario Owners - Important News Paul Remde Soaring 0 February 20th 14 11:25 PM
Big News from Cambridge and ClearNav Paul Remde Soaring 4 January 30th 14 10:49 PM
Important News from the USA # 711 reporting. Tomnkeylargo@aol.com Soaring 5 May 16th 05 05:02 PM
Great news for Cambridge GPS-NAV owners! Paul Remde Soaring 1 September 11th 04 02:07 AM
Important news For all webmaster,newsmaster Bruce A. Frank Home Built 0 November 1st 03 01:16 AM
