Ventus B, Discus ect aileron connecting rod/slide lube
Old February 1st 15, 03:26 PM posted to rec.aviation.soaring
Default Ventus B, Discus ect aileron connecting rod/slide lube
Hi folks, I'm in the process of installing new connecting rods in my Ventus B would like to know what everyone is using if any for the slide lube where those connecting rods like to ride. The material that the slide is made out of seems to be impervious to wear so that's good but the rods are wearing is there any thing you have found that will not collect dust and still give good wear resistance?
CH
Old February 1st 15, 07:34 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Believe those push-rod guides should be kept completely dry. I have seen ware at the guides caused by the push-rod banging around in the trailer. I know the LS-3a has this problem and it is best to tape the push-rod to the aft lift fitting before trailering (use the wing tape you just pulled off). Don't believe this applies to automatic control hook ups, unless you have an A model which have manual hook-ups on the ailerons.
Go Patriots!!!!
JJ
Old February 2nd 15, 02:29 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Search "ventus aileron stiff" and find Dick Jonson's thoughts on the subject, he used 2 drops of WD-40 yearly in a hole he drilled to access the problem area. He also talked about sanding the aileron gap between wing skin and aileron...............all good stuff!
RIP Dick,
JJ
Old February 2nd 15, 11:52 PM posted to rec.aviation.soaring
HGXC[_3_]
On Monday, February 2, 2015 at 3:00:05 PM UTC-5, Don Johnstone wrote:
Ventus=
wher=
o=
wearin=
gi=
CH
If Schempp Hirth thought that the rods needed a lubricate I am sure they
would have mentioned it in the service manual or instructions for replacing
the rods. I do not believe that they forgot and it is perfectly clear that
they intended that the rods should be as they originally assembled them,
lubricant free. Does that give you a clue at all on what should be used?
I own a Ventus and I have mine lubed at the annual, I have the openings in the wing like Dick Johnson suggested. If Schempp Hirth didn't want this to be lubed then they would have used a different bushing when they made the glider. All gliders have short comings. The glider has been flown over 30 years and like all popular gliders over time, pilots find ways of addressing imperfections and every glider has some.
Dennis
Old February 3rd 15, 12:31 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
Ventus=3D
wher=3D
mad=
e
o=3D
wearin=3D
still
gi=3D
CH
=20
they
replaci=
ng
tha=
t
them,
used?
in
to
g=
ye=
addressing
Dennis
Why is it that some glider pilots feel they know better that the qualified
engineers and designers who design and build the machines they fly. Maybe
using an unapproved lubricant on material that you do not know the
composition of, which might be damaged is unwise but drilling a hole in the
structure to do it, that is stupidity of the highest order, such is life I
suppose. I doubt that the "opening" made was properly sealed to unsure that
moisture could not damage the GRP structure which is hygroscopic, my
advice. Do NOT purchase a glider owned by these people.
It is true pilots have a long history of finding incorrect ways of
addressing imperfections, proves the old maxim I suppose, if flying was
difficult engineers would do it.
Old February 3rd 15, 01:47 PM posted to rec.aviation.soaring
John Galloway[_1_]
in my
Ventus=3D
slide lube
wher=3D
slide is
mad=
e
o=3D
rods are
wearin=3D
an
still
gi=3D
CH
=20
am sur
they
for
replaci=
ng
clear
tha=
t
assemble
them,
b
used?
opening
in
want thi
to
they made the
g=
over 30
ye=
addressing
Dennis
qualifie
fly. Mayb
hole in th
unsure tha
hygroscopic, m
wa
I recall corresponding with a pilot who wanted to move forward the
C of G of his GRP glider and found that there was some lead
attached to the leading edge of the rudder. He didn't know why it
was there so he removed it. Next he planned to cut holes in the
rudder and cover them with fabric. I told him that it was the mass
balance and warned him about flutter but he replied that it was OK
as the glider was "Experimental".
John Galloway
Old February 3rd 15, 02:15 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
Some judicious snippage...
in
to
g=
ye=
addressing
Dennis
Evidently, the original question touched upon "a topic of religion." One
church believes that gliders as-received from manufacturers cannot possibly be
improved by mere humanity unassociated with the original design process (and
to attempt improvement places one in the category of the devil's spawn). The
other church believes that use-/age-related issues will inevitably appear, and
might (if not should) be reasonably addressed by subsequent owners. True - at
least in the U.S. - for sailplanes licensed with (see below) an Approved Type
Certificate or licensed Experimentally.
In my view, there's sound reasons for both views, and in an ideal world, both
can peacefully co-exist. Full disclosu I'm a(n aerospace) degreed
(U.S.-based) engineer, but one who's convinced original designers were NOT
(all apply): all-knowing; incompetent. In other words, designers and the
design team are humans like the rest of us, though with (perhaps) some
specialized training, and (definitely) some specialized interests...again
normal human conditions.
The U.S. is fortunate to have a healthy, vibrant, amateur-built aircraft
licensing category, from which - perhaps - some cogent conclusions about this
particular religious topic may be drawn. As I type, approximately 20% of the
U.S. power, single-engine, 4-or-less seats general aviation fleet is licensed
"Experimental Amateur Built" (a presently increasing proportion), the rest
having Approved Type Certificates. Taken as a whole, the EAB category accident
frequency is (statistically and) significantly higher than the ATC category as
measured against fleet/licensing numbers. Unsurprisingly (in my view) the
percentages have a significant first-/early-flight bias (for engine/fuel and
loss of control reasons, mostly); thoughtful readers can probably make
accurate guesses why (an exercise and validation beyond the point I'm trying
to make with this post). Once beyond that bubble, EAB and ATC accident rates
are (arguably) identical. I expect (but am not certain) accident *causes* are
similar as well (when comparing similar classes of pilots/flight, e.g. Visual
Flight Rules piloting).
My conclusions:
1) "Sound airplane design practices" are not limited solely to factories and
their design teams.
2) The weakest link is generally the nut at the top of the stick.
Stated another way, pretty much every form of human design screwup/oversight
possible in general aviation flying machines (e.g. sailplanes) has been made
long, long ago, and "best practices" are pretty much available (and arguably
well known) to anyone inclined to learn from others' experiences. We're well
beyond the "secret guild stage" of aircraft structural design knowledge, and
the "smoke and mirrors" of ignorance-based myths.
That knowledge availability, along with the tendency of those geekily inclined
(most engineers, and many non-degreed people as well) is why I'm OK with
belonging to the Church of Future Improvement is Possible.
On the other hand, the World Wide Web has made it easier for everyone (e.g.
via YouTube) to easily see that Darwinism remains a potent human genealogical
force. Ignorance is potent, often more quickly than knowledge. Hence I'd never
try to convince members of the Church of Don't Mess With Factory Stuff to
change their beliefs.
Clint Eastwood was right: A man's got to know his limitations.
Further, who hasn't heard the truism: All generalizations are
false...including this one. In my view, there's at least one truism that is
NOT false: Perfection is never an option.
True in glider design, too. The trick is to know - or at lest to remain within
- one's limitations.
YMWV
Bob W.
P.S. I believe Dick Johnson was a degreed aeronautical engineer. His entire
working life was spent in the engineering field, and his extracurricular
soaring-and-sailplane-design-and-testing-related body of work was prodigious.
He likely passed on from heart failure in his mid-eighties while flying the
Ventus he owned for decades - the one in which he drilled lube access holes.
Make of all that what works for yourself!
Old February 3rd 15, 04:07 PM posted to rec.aviation.soaring
Dan Marotta
Imagine: Dick Johnson and "stupid" in the same sentence. That's not
unlike hearing Derek Piggot and "lousy instructor" in the same sentence.
Nice post, Bob.
Dan
in
to
made the
g=
over 30
ye=
addressing
Dennis
qualified
Maybe
in the
life I
unsure that
One church believes that gliders as-received from manufacturers cannot
possibly be improved by mere humanity unassociated with the original
design process (and to attempt improvement places one in the category
of the devil's spawn). The other church believes that use-/age-related
issues will inevitably appear, and might (if not should) be reasonably
addressed by subsequent owners. True - at least in the U.S. - for
sailplanes licensed with (see below) an Approved Type Certificate or
world, both can peacefully co-exist. Full disclosu I'm a(n
aerospace) degreed (U.S.-based) engineer, but one who's convinced
original designers were NOT (all apply): all-knowing; incompetent. In
other words, designers and the design team are humans like the rest of
us, though with (perhaps) some specialized training, and (definitely)
some specialized interests...again normal human conditions.
aircraft licensing category, from which - perhaps - some cogent
conclusions about this particular religious topic may be drawn. As I
type, approximately 20% of the U.S. power, single-engine, 4-or-less
seats general aviation fleet is licensed "Experimental Amateur Built"
(a presently increasing proportion), the rest having Approved Type
Certificates. Taken as a whole, the EAB category accident frequency is
the percentages have a significant first-/early-flight bias (for
engine/fuel and loss of control reasons, mostly); thoughtful readers
can probably make accurate guesses why (an exercise and validation
beyond the point I'm trying to make with this post). Once beyond that
bubble, EAB and ATC accident rates are (arguably) identical. I expect
(but am not certain) accident *causes* are similar as well (when
comparing similar classes of pilots/flight, e.g. Visual Flight Rules
piloting).
My conclusions:
factories and their design teams.
screwup/oversight possible in general aviation flying machines (e.g.
sailplanes) has been made long, long ago, and "best practices" are
pretty much available (and arguably well known) to anyone inclined to
learn from others' experiences. We're well beyond the "secret guild
stage" of aircraft structural design knowledge, and the "smoke and
inclined (most engineers, and many non-degreed people as well) is why
I'm OK with belonging to the Church of Future Improvement is Possible.
(e.g. via YouTube) to easily see that Darwinism remains a potent human
genealogical force. Ignorance is potent, often more quickly than
knowledge. Hence I'd never try to convince members of the Church of
Don't Mess With Factory Stuff to change their beliefs.
that is NOT false: Perfection is never an option.
remain within - one's limitations.
YMWV
Bob W.
entire working life was spent in the engineering field, and his
extracurricular soaring-and-sailplane-design-and-testing-related body
of work was prodigious. He likely passed on from heart failure in his
mid-eighties while flying the Ventus he owned for decades - the one in
which he drilled lube access holes. Make of all that what works for
yourself!
Dan Marotta
Discus Aileron Seals Peter F[_2_] Soaring 8 August 20th 13 05:07 PM
left aileron for Discus CS wanted [email protected] Soaring 0 September 28th 12 01:31 AM
New Ventus 2 and Discus Winglets - M&H Alpha Eight Soaring 11 February 21st 12 04:41 PM
Looking for Left Outer Aileron for Ventus C Bob Gibbons[_2_] Soaring 0 June 30th 09 02:12 AM
Ventus 1 - anyone have experience w/o aileron centering spring? Gary Emerson Soaring 0 November 1st 08 02:36 PM
