I'm considering replacing the lead-acid tail battery in my LAK-17a with
NiMH batteries. I find D cells rated at 1.2v 10 Ah which would be ideal to build up a 12v 10 Ah pack. I've already checked fitment in the sealed battery box using alkaline D cells. Can anyone tell me if these batteries are actually 1.2v. If so, I'd need to use 11 or 12 of them to get the voltage I want. -- Dan Marotta |
On Wednesday, February 25, 2015 at 6:51:09 PM UTC-5, Dan Marotta wrote:
I'm considering replacing the lead-acid tail battery in my LAK-17a with NiMH batteries.* I find D cells rated at 1.2v 10 Ah which would be ideal to build up a 12v 10 Ah pack.* I've already checked fitment in the sealed battery box using alkaline D cells. Can anyone tell me if these batteries are actually 1.2v.* If so, I'd need to use 11 or 12 of them to get the voltage I want. -- Dan Marotta Dan, NiMH are a really bad choice. I know someone whose battery in a glider got really hot to the point of melting fiber glass. These batteries were put in by a glider manufacturer and properly sized. If you want more information contact me directly. |
PM sent.
On 2/25/2015 4:58 PM, Andrzej Kobus wrote: On Wednesday, February 25, 2015 at 6:51:09 PM UTC-5, Dan Marotta wrote: I'm considering replacing the lead-acid tail battery in my LAK-17a with NiMH batteries. I find D cells rated at 1.2v 10 Ah which would be ideal to build up a 12v 10 Ah pack. I've already checked fitment in the sealed battery box using alkaline D cells. Can anyone tell me if these batteries are actually 1.2v. If so, I'd need to use 11 or 12 of them to get the voltage I want. -- Dan Marotta Dan, NiMH are a really bad choice. I know someone whose battery in a glider got really hot to the point of melting fiber glass. These batteries were put in by a glider manufacturer and properly sized. If you want more information contact me directly. -- Dan Marotta |
On Wednesday, February 25, 2015 at 3:51:09 PM UTC-8, Dan Marotta wrote:
I'm considering replacing the lead-acid tail battery in my LAK-17a with NiMH batteries.* I find D cells rated at 1.2v 10 Ah which would be ideal to build up a 12v 10 Ah pack.* I've already checked fitment in the sealed battery box using alkaline D cells. Can anyone tell me if these batteries are actually 1.2v.* If so, I'd need to use 11 or 12 of them to get the voltage I want. -- Dan Marotta Bad choice: compared to other options the have poor energy density, poor charge performance, can represent a higher fire hazard, require a specific type charger. You should not try to fast charge a NiMh pack in an enclosed space, especially without a thermal monitoring charger/cutoff. There is just much better battery technology available. Especially LiFePO2 batteries. I am also aware of a glider NiMh battery with serious thermal damage caused by improper charging/insufficient manufacturer warnings, etc. |
On Wednesday, February 25, 2015 at 5:56:19 PM UTC-8, Darryl Ramm wrote:
There is just much better battery technology available. Especially LiFePO2 batteries. I am also aware of a glider NiMh battery with serious thermal damage caused by improper charging/insufficient manufacturer warnings, etc. Darryl, Did you mean LiFePO4? Likewise, familiar with the glider that had issues with NiMH batteries. Besides the NiMH relatively high self-discharge rate, when using multiple batteries is keeping things balanced. This is exacerbated if the batteries are not all in the same location, as differing lengths and thus resistance of interconnect wire is enough to pretty much insure things will not go well, with some cells overcharging, deep discharging, or even reversing cell polarity. bumper |
On Wednesday, February 25, 2015 at 9:44:52 PM UTC-8, bumper wrote:
On Wednesday, February 25, 2015 at 5:56:19 PM UTC-8, Darryl Ramm wrote: There is just much better battery technology available. Especially LiFePO2 batteries. I am also aware of a glider NiMh battery with serious thermal damage caused by improper charging/insufficient manufacturer warnings, etc. Darryl, Did you mean LiFePO4? Likewise, familiar with the glider that had issues with NiMH batteries. Besides the NiMH relatively high self-discharge rate, when using multiple batteries is keeping things balanced. This is exacerbated if the batteries are not all in the same location, as differing lengths and thus resistance of interconnect wire is enough to pretty much insure things will not go well, with some cells overcharging, deep discharging, or even reversing cell polarity. bumper Uh yes, LiFePO4. But if anybody can find a LiFePO2 battery call me. |
![]() bumper On Thursday, February 26, 2015 at 12:44:52 AM UTC-5, bumper wrote: Darryl, Did you mean LiFePO4? PO2/PO4, 220/221, "whatever it takes" www.youtube.com/watch?v=iX3kxAA2L4Q |
Hi,
I have a pack of 11 9ah Nimh 1,2 v as a backup battery in the tail of my Lak17. They have the same format as alkaline D cells. I use a RC charger that automatically detects the right number of elements. At end of charge, voltage is arount 16,2 volts, but drops quickly to under 16. Also cable length drops voltage to something usable by instruments (15v). As it is a backup battery, I use it after the main 9ah pb is lowered down, so voltage is ok. I never had any problems with these batteries. But they are old now, and i plan to replace them with lifepo4. also nimh auto discharge force me to derig the tail very often. With Lifepo4, If I do not use the backup, no need to derig. |
Thanks to all.
It looks like NiMH batteries are out of the question for me. I have a 10 Ah LiFePO4 drop-in replacement as my main battery and am very happy with its performance. I'm looking for LiFePO4 cells (and BMS) for protection that can fit in my tail battery box. The dimensions of the drop-in box a Length = 58 cm Width = 3.5 cm Height = 6.5 cm No luck so far, but I'm continuing the search. I could also build up a pack for a separate box which I've installed behind the seat back. Its dimensions a Length = 36 cm Width = 4.8 cm Height = 10.8 cm Any suggestions would be most welcome. I've been searching the net, but nothing yet satisfies my specific needs. Dan On 2/26/2015 8:16 AM, Pierre Vav wrote: Hi, I have a pack of 11 9ah Nimh 1,2 v as a backup battery in the tail of my Lak17. They have the same format as alkaline D cells. I use a RC charger that automatically detects the right number of elements. At end of charge, voltage is arount 16,2 volts, but drops quickly to under 16. Also cable length drops voltage to something usable by instruments (15v). As it is a backup battery, I use it after the main 9ah pb is lowered down, so voltage is ok. I never had any problems with these batteries. But they are old now, and i plan to replace them with lifepo4. also nimh auto discharge force me to derig the tail very often. With Lifepo4, If I do not use the backup, no need to derig. -- Dan Marotta |
It looks like this will fit the bill for me:
*http://www.bioennopower.com/products...tery-pvc-pack*. It's a 12v 12 Ah soft pack with BMC and charger. It appears it will slide right into my tig welded covered aluminum box where it will be padded with foam and secure from any stresses. It will be a simple matter to pull it out and take it home for charging. I'll simply reload the (mostly) dead lead batteries back into the tail box for weight and balance purposes. They won't be connected any more. On 2/26/2015 10:13 AM, Dan Marotta wrote: Thanks to all. It looks like NiMH batteries are out of the question for me. I have a 10 Ah LiFePO4 drop-in replacement as my main battery and am very happy with its performance. I'm looking for LiFePO4 cells (and BMS) for protection that can fit in my tail battery box. The dimensions of the drop-in box a Length = 58 cm Width = 3.5 cm Height = 6.5 cm No luck so far, but I'm continuing the search. I could also build up a pack for a separate box which I've installed behind the seat back. Its dimensions a Length = 36 cm Width = 4.8 cm Height = 10.8 cm Any suggestions would be most welcome. I've been searching the net, but nothing yet satisfies my specific needs. Dan On 2/26/2015 8:16 AM, Pierre Vav wrote: Hi, I have a pack of 11 9ah Nimh 1,2 v as a backup battery in the tail of my Lak17. They have the same format as alkaline D cells. I use a RC charger that automatically detects the right number of elements. At end of charge, voltage is arount 16,2 volts, but drops quickly to under 16. Also cable length drops voltage to something usable by instruments (15v). As it is a backup battery, I use it after the main 9ah pb is lowered down, so voltage is ok. I never had any problems with these batteries. But they are old now, and i plan to replace them with lifepo4. also nimh auto discharge force me to derig the tail very often. With Lifepo4, If I do not use the backup, no need to derig. -- Dan Marotta -- Dan Marotta |
NIMH batteries - slightly OT | Martin Gregorie[_4_] | Soaring | 13 | April 15th 09 03:17 AM |
NIMH Batteries | K M | Soaring | 23 | December 9th 08 09:27 PM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
C & D NiMH Best Deal | Larry | Home Built | 6 | October 1st 04 01:41 PM |
AA NiMH Best Deal | Jim Weir | Home Built | 27 | September 29th 04 08:39 PM |
