Use of ridge lift for tow - review of procedure/protocol
Old June 26th 15, 05:38 PM posted to rec.aviation.soaring
son_of_flubber
Default Use of ridge lift for tow - review of procedure/protocol
What are the best practices for using ridge lift when towing?
What is different when the ridge altitude is increasing?
Should the tow plane approach the ridge perpendicular at the saddle (rather than at a 45)? What if circumstances force you to release at this point (pointed straight at the ridge, close and below)?
Is it okay to tow below the top of the ridge and utilize slope lift? (With the wind coming from the right or the left?)
Assuming that the wind is coming from the left, is it okay to release, uncrab and drift downwind to clear towplane rather than circling right and ending up low and on the leeward side of the ridge.
If you're above the ridge and the wind is coming from the right, is it okay to release and make the towplane go onto the leeward sink side of the ridge?
Other things to keep in mind?
PowerFLARM protocol 71? kirk.stant Soaring 1 May 10th 15 04:46 PM
Who Knew? (dipping protocol) CupCaked Piloting 0 April 26th 11 04:59 PM
Bizjet protocol JS Soaring 5 September 4th 06 06:29 AM
A fine ridge day in PA - the Ridge Soaring Irregulars ride again QT Soaring 0 April 6th 06 04:01 PM
Looking for Ridge Lift/Turbulence Diagram DrJack Soaring 22 November 14th 03 08:49 PM
