MKIV "high tech" yaw string (tech note)
Old July 31st 15, 07:03 AM posted to rec.aviation.soaring
bumper[_4_]
Default MKIV "high tech" yaw string (tech note)
I recently heard from an owner having installed a MKIV yaw string on a FES (front, electric, self-launch/sustainer) equipped glider. He said that the MKIV was not indicating straight back centered in level flight, being slightly off to the side and deflection in turns was "not even, more sensitive in one direction" (my words).
Since all MKIV yaw strings are carefully obedience trained and calibrated before leaving my shop (g), there had to be something affecting the flow over the canopy. I suspected the culprit might be the folded prop, given the ship's rigging apparently checked fine. I suggested installing temporary yaw strings further back on the canopy to determine how far aft the string would need to be located to behave in an acceptable manner - then mark that spot for the warranty* replacement. I think that worked and all is well (I hope).
If installing a MKIV on a FES equipped glider, please determine suitability of chosen location by test flying with temporary yarn/s prior to installing the MKIV.
MKIV's and Quiet Vents are available on-line at Craggy Aero, Cumulus, and Wings & Wheels!
*For warranty replacement - please contact me directly. IF you read the installation instructions and still goof, that's covered too (once!), warranty coverage is at my sole discretion (but I'm easy).
all the best,
bumper
bumperm at frontier dot
com
Old August 9th 15, 12:29 PM posted to rec.aviation.soaring
Tony[_5_]
Been flying all week in the Electro with a brand new Mark IV. My yaw string must be more obedient than that other guys...its nice and straight all the time
Old August 9th 15, 10:31 PM posted to rec.aviation.soaring
2KA
Or maybe an installation error. Perhaps taped at both ends?
Old August 10th 15, 05:44 AM posted to rec.aviation.soaring
Dan Marotta
Hey! I just installed a MK-4 on my LAK-17a and it seems to fly
straighter than before. Do you think I made that same double tape mistake?
I also installed Bumper's quiet vent mod and am very pleased with the
smoother, quieter air coming in the vent.
Dan Marotta
Old August 10th 15, 08:17 AM posted to rec.aviation.soaring
Bryan Searle
Default MKIV
Beat this, I heard of a pilot (!) who drilled a hole in the canopy for the
yaw string!
Doh..
mistake?
Dan Marotta
Old August 10th 15, 12:09 PM posted to rec.aviation.soaring
PBA
Default MKIV
So wait, were do I download the firmware update for the yaw string?
Old August 15th 15, 11:02 AM posted to rec.aviation.soaring
Peter von Tresckow
Well Tony did install it backwards with the pointy but facing back.
Apparently Tony didn't RTFM ;-)
Peter
Old August 11th 15, 08:01 PM posted to rec.aviation.soaring
pstrzel
Has the problem with the yaw string not being coordinated with inputs been addressed? It doesn't stay coordinated with either rudder or aileron inputs. It only works when both are applied somewhat simultaneously. Not beginner friendly at all!
There should be something like a beginner or intermediate setting on every yaw string.
Old August 11th 15, 08:44 PM posted to rec.aviation.soaring
David Hirst
I fitted a turn-o-matic feature to my yaw string. It's water-activated. Just fly fast through rain and hey presto! All your turns for the next 5 minutes become perfectly co-ordinated.
Send no money now, folks!
Old August 11th 15, 10:41 PM posted to rec.aviation.soaring
Sounds like mid winter "cabin fever" here..... but in August (in the northern hemisphere)......
Maybe some need to get a life, or a different job......
[Picking, not slamming....]
Newest High Tech Audio Vario Papa3[_2_] Soaring 2 July 5th 13 04:53 PM
Mountain High EDS Regulator Tech Svc Notice nimbus[_2_] Soaring 0 February 13th 12 07:49 PM
High Tech Meeting before the SSA Convention Paul Remde Soaring 0 February 2nd 08 05:32 PM
High-tech gizmos propel aviation into the future Omega Piloting 3 June 11th 05 06:48 AM
Duo Discus Tech note Thomas Knauff Soaring 25 August 9th 03 10:10 PM
