XCSoar and Wind
Old November 15th 15, 03:39 PM posted to rec.aviation.soaring
Dan Marotta
Default XCSoar and Wind
Hello XCSoar users. I love my XCSoar/Streak combo in my glider and I
installed a second Streak in the Pipistrel Sinus. In the Sinus there is
no computer/GPS to feed the Streak and so the XCSoar relies on the
internal GPS of the Streak. With the solo setup, I never see winds.
I've flown zig-zags and circles and never get a wind presentation. In
the settings under Config System Glide Computer Wind, I have Auto
Wind - Both selected. Any ideas.
Dan, 5J
Old November 15th 15, 11:32 PM posted to rec.aviation.soaring
TND
Instead of "Both", try "Circling". That worked on my Streak before I had a vario connected to it.
On Monday, November 16, 2015 at 2:39:20 AM UTC+11, Dan Marotta wrote:
Hello XCSoar users.* I love my XCSoar/Streak combo in my glider and
I installed a second Streak in the Pipistrel Sinus.* In the Sinus
there is no computer/GPS to feed the Streak and so the XCSoar relies
on the internal GPS of the Streak.* With the solo setup, I never see
winds.* I've flown zig-zags and circles and never get a wind
presentation.* In the settings under Config System Glide
Computer Wind, I have Auto Wind - Both selected. * Any ideas.
Dan, 5J
This message is intended for the addressee named and may contain
confidential information. If you are not the intended recipient, please
delete it and notify the sender. Views expressed in this message are those
of the individual sender, and are not necessarily the views of their
organisation.
Old November 16th 15, 05:35 PM posted to rec.aviation.soaring
Dan Marotta
Thanks - I'll try that on the next flight.
I installed a second Streak in the Pipistrel Sinus. In the Sinus
on the internal GPS of the Streak. With the solo setup, I never see
winds. I've flown zig-zags and circles and never get a wind
presentation. In the settings under Config System Glide
Computer Wind, I have Auto Wind - Both selected. Any ideas.
Dan, 5J
Dan, 5J
Old November 17th 15, 02:59 AM posted to rec.aviation.soaring
Dan,
Make sure you enable XCsoar to use the internal GPS device. You must do this explicitly. ConfigDevices then A: Built-in GPS & sensors....make sure it is enabled
Old November 19th 15, 05:37 AM posted to rec.aviation.soaring
Dave Rolley
Dan, 5J
See if this makes sense...
http://forum.xcsoar.org/viewtopic.php?f=2&t=2382
Dave
Old November 19th 15, 05:48 AM posted to rec.aviation.soaring
Ramy[_2_]
Thanks. Sound like it is using external wind unless you select one of the other options (circling or zigzag). It was indeed a bit confusing so glad this got simplified. I assume there is also still the option to enter wind manually as well.
Ramy
Old November 19th 15, 05:50 AM posted to rec.aviation.soaring
Dan, 5J
Dave
Reading that (again), the best interpretation I have is that if you choose Manual for wind calculation, then you get External Wind if it's available.
But if so, how do you override External with Manual if you want to do that?
I don't know.
David
Old November 19th 15, 08:24 AM posted to rec.aviation.soaring
David Salmon[_3_]
You could always try LK8000, wind works fine in that, though now I use
external from the SN10. Before that though, the LK wind and SN10 wind were
always very similar Again however you have to configure it correctly, but
it is only one setting.
Dave
Hello XCSoar users.=A0 I love my XCSoar/Streak combo in my glider and
I installed a second Streak in the Pipistrel Sinus.=A0 In the
Sinus
relie=
s
on the internal GPS of the Streak.=A0 With the solo setup, I
never
see
winds.=A0 I've flown zig-zags and circles and never get a wind
presentation.=A0 In the settings under Config System Glide
Computer Wind, I have Auto Wind - Both selected. =A0 Any ideas.
=20
=20
--=20
=20
Dan, 5J
=20
=20
http://forum.xcsoar.org/viewtopic.php?f=3D2&t=3D2382
=20
Dave
choose
available.
that?
I don't know.
David
Old November 19th 15, 03:16 PM posted to rec.aviation.soaring
Dan Marotta
Last time I looked LK8000 does not run on Android.
Dave
Sinus
relie=
s
never
see
=20
=20
--=20
=20
Dan, 5J
=20
=20
=20
Dave
choose
available.
that?
I don't know.
David
Dan, 5J
Old November 19th 15, 06:26 PM posted to rec.aviation.soaring
Ramy[_2_]
If Manual means external than those who use external wind can no longer set it manually. This is a problem since occasionally you want to manually enter expected wind instead of current wind to get realistic final glide calculation when you know the wind at lower altitude is different. I don't understand why not simply add "external" option.
Ramy
XCSoar and V7 [email protected] Soaring 8 January 17th 14 09:19 PM
XCSoar wind calculation Martin Gregorie[_5_] Soaring 11 October 8th 09 05:26 AM
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (1/1) JR[_2_] Aviation Photos 0 August 13th 08 09:36 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (0/1) JR[_2_] Aviation Photos 0 August 13th 08 09:35 PM
