#21
In Australia AD177 covers L'hotellier couplings. 1000hr replacement for shanks under 6mm, 3000hr for others on flap and dive brake circuits. 0.1mm max difference between different axes of ball at 90 degrees to each other - like an X through the cross section (best to look at the diagram!). Lubrication each rigging, 50hrs and 6 months. There's a bunch of other stuff in there too, but not sure how much is Oz specific vs out of manufacturer ADs.
Cheers Ben |
Reply to myself - most of that is in the previously linked L'hotellier maintenance instructions. My post was incorrect, replace all balls at 10yrs/3000hrs.
Cheers Ben On Thursday, 14 April 2016 09:22:43 UTC+10, Ben Coleman wrote: In Australia AD177 covers L'hotellier couplings. 1000hr replacement for shanks under 6mm, 3000hr for others on flap and dive brake circuits. 0.1mm max difference between different axes of ball at 90 degrees to each other - like an X through the cross section (best to look at the diagram!). Lubrication each rigging, 50hrs and 6 months. There's a bunch of other stuff in there too, but not sure how much is Oz specific vs out of manufacturer ADs. Cheers Ben |
Ben, it was probably the 10 year thing that Camden Sailplanes flagged my Nimbus on.
Jim |
I have never heard of anyone replacing l'Hotelliers after 10 years (or any other interval). The annual check with measurements tells you when to replace them, if ever. That's condition-based maintenance, or CBM for those who love TLAs.
On Thursday, 14 April 2016 17:43:19 UTC+10, krasw wrote:
I have never heard of anyone replacing l'Hotelliers after 10 years (or any other interval). The annual check with measurements tells you when to replace them, if ever. That's condition-based maintenance, or CBM for those who love TLAs. RBM down here. Cheers Ben |
In the maintenance instructions from l'Hotellier (attached in
http://www2.lba.de/dokumente/lta/1993-001.pdf pages 11 and 12) At 20:47 13 April 2016, Casey wrote: The interval recommended by L'Hotellier (and taken over by several national authorities as mandatory) is ten years or 3000 hours (whichever comes first). Most manufacturers of aircraft who use L'Hotellier balls have specified their replacement during the 3,000 and 6,000 hours and so intervals. IIRC Schempp-Hirth has closer intervals (500 hours?) due to them being fitted in a different way and they have had threaded ends fail. Erik, Where do see that L'Hotellier recommends ten yrs or 3000 hrs? Also my glider manufacturer has no mention of this in the life extensions. I emailed them this morning and all they sent me was the maintenance instruction and there is no mention in that of this recommendation. |
At 07:43 14 April 2016, krasw wrote:
I have never heard of anyone replacing l'Hotelliers after 10 years (or any other interval). The annual check with measurements tells you when to replace them, if ever. That's condition-based maintenance, or CBM for those who love TLAs. Measuring them will indicate wear, not fatigue. On some types of gliders fatigue has been an issue, especially when not properly lubricated, with threaded ends breaking off from the control rod. Typically gliders where the ball is on a 90-dgree angle to the socket and not in line with it. National interpretations of the factory recommended replacement vary from country to country. |
On Thursday, 14 April 2016 14:00:09 UTC+3, Eric Munk wrote:
Measuring them will indicate wear, not fatigue. On some types of gliders fatigue has been an issue, especially when not properly lubricated, with threaded ends breaking off from the control rod. Typically gliders where the ball is on a 90-dgree angle to the socket and not in line with it. National interpretations of the factory recommended replacement vary from country to country. Which types are these? I have a glider that has only 90 degree joints. If national authorities turn expression "recommended" into "mandatory", I would call that something else than interpretation. |
#29
no spray grease. huge mess. gentlemen never use it.
On Wednesday, April 13, 2016 at 9:06:58 AM UTC-4, Casey wrote: Thanks for the comments. I'm wonder what the dimensions of the balls are new. My aileron balls on both wings are 0.02 mm smaller than the spoiler balls on both wings. Dimensions are same on each wing. What is best lubricant? Thicker grease or thiner spray? I know the pro and cons of each but just wonder others thoughts. Casey |
#30
At 12:18 14 April 2016, krasw wrote:
If national authorities turn expression "recommended" into "mandatory", I would call that something else than interpretation. Welcome to Europe, where this is how EASA-rules are interpreted by most national authorities' legal experts. Australia too, and I believe New Zealand. |
Source of L'Hotellier Fittings? | Six-Seven Romeo | Soaring | 2 | September 1st 15 05:33 PM |
Brass Compression Fittings,Fittings for Pex-Al-Pex Sale on good price | valvetom | Piloting | 0 | November 27th 06 05:58 PM |
L'Hotellier | [email protected] | Soaring | 5 | September 9th 05 04:21 PM |
wanted L'Hotellier ball fitting assembly | Udo Rumpf | Soaring | 3 | January 7th 05 03:05 AM |
Hotellier connections | Mike | Soaring | 38 | September 28th 04 04:30 PM |
