Libelle spoilers
Old September 29th 17, 07:39 PM posted to rec.aviation.soaring
Bob Kuykendall
Default Libelle spoilers
On Tuesday, September 13, 2016 at 2:06:01 PM UTC-7, Martin Gregorie wrote:
DU?
Please, Herr Gregorie, I hardly know you.
But seriously, I was wondering that myself. The last time I heard of DU in the context of materials, it was the _depleted uranium_ used for 30mm cannon shells of the A10 Warthog and the mass balances in early Boeing jetliners.
--Bob K.
Old September 29th 17, 09:13 PM posted to rec.aviation.soaring
Sorry I don't have a Libelle any more, but I'd drill the 2mm hole in the middle of the gear boxi (visible from the root rib). Much too earl in the year to start the annual discussion about lubricants, but I'm still using WD-40 ...........or other suitable spray lubricants of your choice!
JJ
Old September 30th 17, 04:56 AM
OregonGliderPilot OregonGliderPilot is offline
Junior Member
First recorded activity by AviationBanter: Sep 2009
Quote:
JJ
I have the drawings for the Kestrel gearbox and there are no separate bearings DU or otherwise as such in the gearbox, just Glasflugel's standard ptfe tape and resin mix embedded in the shells of the gearbox. I think the stiffness comes from both the contraction of the resin over the years and the corrosion of the unprotected steel shaft. My Kestrel air brakes can get stiff, and I use a light ptfe lubricant half way along the shaft to creep into the pure bearings, as per JJ's method, and by taking off the small cap on the external end of the drive dogs (is this on Libelles? I think not...) I can inject some heavier weight oil onto the gears themselves. Needs to be done ever two or three years sadly but it makes the brakes usable. I keep thinking of a major rework and replacing the gearbox with a modern right angle drive.
Old September 30th 17, 07:27 AM posted to rec.aviation.soaring
AS
DU?
--Bob K.
Bob,
DU is a brand name or type designation of a bushing made by IGUS.
Uli
Old September 30th 17, 11:48 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
DU?
Hi Bob,
I've just back from a club expedition to Eden Soaring, where I had fun
ridge running with my Libelle on the Pennines around Cross Fell. We had
three good days despite the prevailing S - SSE wind and the inevitable
messy result of many sheep camping overnight on the airfield.
However, I don't remember mentioning DU (could it have been a mis-
spelling?) in connection with a Libelle and all earlier posts in this
thread have now been eaten by the Chronophage so I can't see the context.
My brakes are currently as silky smooth as they've ever been, largely
thanks to judicious application of a medium viscosity machine oil to the
airbrake bearings in the wing root.
jetliners.
Same here, though I didn't know about the Boeing mass balances, and lets
not even mention the rectangular lumps of iron in the nose of a Slingsby
Vega.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Spoilers, no spoilers? Amine Piloting 39 February 14th 08 02:37 AM
Flaps/spoilers on which sailplanes? [email protected] Soaring 11 December 31st 06 01:12 AM
spoilers vs. ailerons [email protected] Piloting 36 August 8th 05 11:24 AM
Frozen spoilers stephanevdv Soaring 0 November 4th 04 05:24 PM
L-13 Spoilers Scott Soaring 2 August 27th 03 06:08 AM
