500 foot rule and pilot opinion poll
Old September 19th 03, 12:17 PM
Jonathan Gere
Eric Greenwell wrote in message ...
As I understand the rule, it's not just a matter of popping above the
500' agl floor of the cylinder. You'd have to thermal up, go back to
the outside of the 2 mile cylinder, and fly from there to the 1 mile
cylinder while staying above 500' agl. In the the situation you
describe, would you still be likely to try that weak thermal, or would
you just go ahead and land?
Bad rules proposal!
As they do out on course, pilots will stop trying to get somewhere,
and start trying to get back up to avoid losing their speed points at
some personally determined altitude.
That includes the pilots that could be making a safe, routine rolling
finish for speed points under the present rules!
Some pilots will fly safely whatever the rules. Other pilots will
break their gliders trying to get home just for the convenience (and
safety) of avoiding a field landing. If you think that pilots will
stop trying to finish and outland safely if they have no shot at
getting points, you haven't thought much about the long history of
guest pilots breaking their gliders at contests.
Jonathan Gere
Old September 19th 03, 01:56 PM
Brian Case
Personally, I would go ahead and land. Most likely it would only mean
the difference between last place and next to last place for me
anyway.
No matter where you put the limit, the greater the point penalty for
missing it the more likely the competitive pilots might be to try and
climb back up to it. Especially since if they are only going to get
distance points if they don't make it work they have nearly all day to
try to get back up to the finish, since their speed won't count unless
the do make it to the finish.
Brian
CFIIG/ASEL
says...
Let say I am 3 miles out a 700 feet in calm air. Since where i fly we
have a 2 mile long runway and the finish cyilnder is typically
centered on the center of the runway the end of the runway is only 2
miles away. However I just miss the 500 foot finish at 2 miles out
(or am not sure if I hit it) At that point I hit a weak thermal (Which
can happen quite often at low altitudes) I am only 400 ft, but if I
can work this thermal to gain only 100 feet it is worth the 400 point
differnence between being scored only distance as opposed to speed.
(that is if I understand the rules correctly) Now you have a glider
thermalling between 400-600 feet AGL with other gliders finishing at
the 500ft level.
Old September 19th 03, 06:59 PM
Todd Smith
John,
I would support a rule that was a lot simpler.
I just worked through the "donut" part of the rule and
that is not good.
It seems that finish at 500 ft at 1 mile would work just
as well and be much more simple.
I also would prefer 1000 ft to 500 ft. 500 ft is still pretty low.
Todd Smith
"3S"
Old September 19th 03, 07:39 PM
Marc Ramsey
"Todd Smith" wrote...
It's worked very well at the contests I've participated in that used it. After
pulling up, I'll have plenty of time to tidy up the cockpit, listen on the gate
frequency for other gliders finishing, listen on the airport frequency for
traffic, double check that the water is gone, get the gear down, make a few 360s
for a visual check of the pattern, and make a nice leisurely landing. All
without feeling like I'm giving up a huge number of points to the speed racers.
Don't go there, you'll only start some people frothing at the mouth!
Seriously, 500 feet is actually excessive at typical finishing speeds (80+
knots). If you're going slower, an abbreviated pattern or a straight-in should
still be quite doable. But, there's nothing that says you have to cut your
finishes that close. I don't...
Marc
Old September 21st 03, 12:29 AM
Andy Blackburn
It is different Tom.
Yes, there are always climbing and cruising sailplanes
in the mix. The difference is that the closer you are
to the finish the more likely it is that gliders will
be converging on each other (horizontally AND vertically)
and the more likely it is that the cruising sailplanes
will be doing something approaching redline rather
than 75-100 knots.
The logic for the difference is simple. If you know
you can't make it home you are likely to be making
outlanding preparations somewhere around 700-1,200
feet - depending on terrain and availability of landable
fields. In the 'final glide gone bad' scenario you
would come to this decision 5-10 miles out and either
find a thermal or land (at least most pilots I know
will - unless they're flying over a terrain so benign
that it's like one big putting green). At this distance
the higher speed traffic is well higher and hasn't
started to burn off the extra altitude they are carrying
as a buffer. The climbing glider won't likely climb
up to them anyway unless it finds a real corker of
a thermal (somewhat unlikely under 'low save' circumstances).
The reason you don't often find gliders making low
saves at less than 5 miles out today is that they've
all landed out by then or made it home - put another
way not many pilots set up for a landout from 500'.
Under the proposed rule you can find yourself at 2.5
miles from home and 700' AGL with not enough altitude
for a speed finish, but enough altitude to get home.
What would you do in this situation? EXACTLY - you
will hunt around the edge of the donut for lift. aHopefully,
as you get lower you drift towards the airport to keep
the landing option open (not sure if the rule allows
for catching a thermal below 500' right over the airport,
climbing up to enough height to go out to 2 miles and
back above 500'). I suppose we could make a rule that
if you EVER get below 500' AGL in a flight you're done,
but it would probably only be enforceable in the flatlands
of Kansas.
So there you are climbing up at 2.5 miles out, trying
to get enough altitude to make it to the inside edge
of the donut at 500'. Say you'll accept a Mc=2 glide.
Well at 2 miles the difference between a Mc=2 glide
and a Mc=6 glide is 150'. So all the guys coming steaming
home - now at close to redline will be more or less
at your altitude. Under the current rules this is unlikely
to happen at less than 6 miles out - where the differential
altitude margin is three times as great and the speed
differentials are somewhat lower.
If you want some really interesting and action-packed
finishes with a few poor pilots stuck outside the donut
- able to glide to the airport but unable to finish
for speed points - floating around at low altitude
and mixing it up with gliders at redline - all within
view of spectators - then this is your best shot.
Wait, I forgot the best part! The guys at redline will
have their heads in the cockpit, looking at their glide
computers, because 500' up on a two mile radius has
no visual reference to fly against.
Democracy is a great thing, but without goodwill towards
others it offers the potential for 51% to inflict pain
on 49%. If you want to finish at 500' go ahead - you
don't need a rule for it and it costs you only a minute
or so. I personally carry 1,000' of extra until I'm
5-7 miles out.
While I believe it is 100% well intentioned, I don't
think this proposal actually helps and it has some
very funky potential side effects.
Vote away!
9B
At 20:30 20 September 2003, Tom Seim wrote:
Andy Blackburn wrote in message news:...
I shold have been clearer on this point Eric.
If you are at 700' and 4 miles, you will not make
it
to 500' at 1 mile, you will have to stop and climb.
A Mc=0 glide to the inner edge of the donut in my
ship
requires 886' (by the factory polar). If I climb to
a Mc=3 or Mc=4 glide, I am at 997' to 1053'. You might
climb even higher if you want any buffer.
I believe that the optimal finish for pilots who have
adequate altitude for a speed finish will be to shoot
for the top outside edge of the donut (with some buffer)
and then bleed airspeed to the inner edge to hold
altitude.
A pilot shooting for this on a 120 knot glide Mc=6
will be at 908' at 4 miles, which is below the guy
making a save and wanting to make a flatter glide
to
the inner part of the donut.
The simple point here is that all of this climbing
and mixed traffic happens at 4-5 miles from the field
rather than 8-10 miles under the current rules. This
is because the ground forces the issue later with
extra 500' built into the finish altitude. Since altitude
separation (difference in glide angle times distance)
goes up linearly with distance and the amount of horizontal
separation goes up with distance as well, the potential
for mixed climbing and highspeed traffic would likely
increase under the 500' rule. You can make different
assumptions about what altitude you might stop and
climb, but the difference due to the rules remains
the same.
I don't see how this is any different; we have to see
and avoid other
sailplanes from the time we start the flight to the
time that we have
come to a full stop. There can be gliders thermally
anywhere on
course, including directly over turn points. And even
if you don't
have the 500 ft rule there can mixing of gliders thermally
and
high-speed gliders in-bound to finish.
I feel that those low altitude finishes add nothing
to the sport
except for some broken gliders (and pilots!) and some
very anxious
crews. Furthermore, it encourages violation of FARs
for minimum
altitude. There may be some pilots who think they may
have some
competitive edge because they are willing to push it
lower than the
others, and this may be the case. I say cast your vote,
let democracy
function and accept the result.
Old September 22nd 03, 05:55 PM
Michael Stringfellow
Andy has it exactly right.
Yesterday, on the last leg of an ASA 150-mile task, I found myself low at
the end of the day as thermals died. Just under 10 miles out, I had the
last decent strip before flying over hills and unlandable desert. My flight
computer said I had 350 feet over a 2-knot glide. Since 500-foot sink in
that distance isn't impossible, I decided to land. I was 1,300 feet above
the ground and, with luck, could have scraped back. I took the safer
option.
No finish donut would have had me decide any differently, this was purely a
safety issue for me. Those that finished were 500 to 1000 feet above me.
Another point is the scoring penalty for landing out. I had managed a quite
respectable 70 mph up to that point and would probably have got close to 900
points if I had finished the task. What do I get for landing 9 miles short
after completing 94% of the task? Not 94%, that's for sure - more like 30%
to 40%.
Any economist will tell you that this high rate of taxation for landing out
will encourage the risk takers to push on for a better reward.
Maybe we should use a carrot and not a stick and look at a scoring system
that rewards distance and speed and doesn't punish landouts so severely.
This makes more sense to me than messing with tried and tested finish
procedures.
Mike ASW 20 WA
"Andy Blackburn" wrote in message
than 75-100 knots.
of Kansas.
5-7 miles out.
Vote away!
9B
it
ship
altitude.
to
the same.
and avoid other
time that we have
anywhere on
if you don't
and
to the sport
very anxious
for minimum
have some
lower than the
let democracy
Old September 24th 03, 08:35 PM
Dale Kramer
John
I have flown quite a few contest days with the 2 mile 500 foot finish.
Here are my comments:
1. On a purely emotional level, I miss (and I'm sure the spectators
do too) the 50 foot speed pass finish line. I know that you can still
do one after you cross the ring but in practice most people just come
in and land.
2. On a practical basis, it leads to more heads down flying. Most
people do a 50 foot speed pass finish completely heads up (maybe an
airspeed check once in a while). The ring puts your head in the
cockpit. The optimum finish is still at 501 feet and max airspeed.
You just can't judge this 2 miles out without a lot of heads down
work.
3. On a global perspective, this rule is just a bandaid that
necessitates more bandaids. I did not like it when Charlie started
adding 3 minutes to your time for rolling finishes under the ring and
now you are adding another bandaid by saying you don't get speed
points if you go under the ring. The bandaids go on and on. What
about the contestant that has the fastest speed, crosses the ring at
110 knots but does it at 499 feet. Distance points only? The harsh
100 point turnpoint penalty had to have its own bandaid for missing
the turnpoint by 15 feet, that will have to happen here too. The
bandaids keep going on and on for the finish ring.
As you can see I am against the finish ring.
I do, however propose a different solution for low energy finishes.
Bring the exciting heads up speed pass finish line back and solve the
low energy problem with some sort of finish line groundspeed minimum
or minimum altitude to achieve after the finish line. Don't have
harsh point penalty steps in the solution either. After all the main
reason people are tempted to do a low energy finish is the harsh point
penalty associated with a landout. Maybe thats what should be
addressed!
Just my 2 cents
Dale Kramer
K1
Old September 28th 03, 03:16 PM
Cliff Hilty
Gary, I disagree with your scenaro. there are many
ways to massage this to make it happen not the least
of which would base the landout guy score on time as
well as distance ie if he was faster than the slowest
finisher he would still score less than him. Therefore,
his incentive would be to finish not to landout. You
also assume that there will be a place to land right
off the airport. If the last place to land is 20 miles
away on a 200 mile task it is only 90% or 900 points
in your scenaro. I don't know of any of the racing
pilots I fly with that will settle for that! Assume
another scenaro where the day dies after just one finisher
and all of the pilots are at the last air field and
land there in order thaey all would not score the same
it would or could be based on time around the course
to that point and still less than the finisher. In
this scenaro you could do away with devauleing a day
as well. Anyway its good to have these discussions.
Some changes can be good, some can be bad and the more
we talk about it the better options we can come up
with.
Cliff Hilty Ventus B
At 14:18 27 September 2003, Gary Ittner wrote:
Did you see the movie 'A Beautiful Mind' (Oscar winner
for Best Picture
of 2001)? There's a wonderful scene in which mathematician
John Nash
introduces the concept of the 'Nash equilibrium' to
his fellow grad
students, using the example of how their collective
individual
tendencies to go for the prettiest girl in the bar
will inevitably
result in none of them getting laid that night.
Here's the result I get when I apply the Nash equilibrium
principle to
your scoring scheme: one pilot gets 1000 points and
the rest each get
999 points. Each pilot's individual tendency to go
for the highest score
that he can get will inevitably result in one pilot
finishing and all
other pilots deliberately landing just short of the
finish line.
To most easily see why this is so, imagine an Assigned
Task with all the
pilots starting together in a big furball. Pilot A
is the first, and
therefore the fastest, finisher and gets 1000 points.
As pilot B
approaches the finish, he calculates that his speed
will be 95% of the
winner's speed, earning 950 points. Ah, but if there
is only one
finisher, the fastest finisher is also the slowest
finisher. In that
case, pilot B would get 999 points if he landed just
short of the finish
line, so that is what he does.
If pilot C comes along and finishes with 90% of the
winner's speed,
pilot B would be bumped down to 899 points, so pilot
B would have done
better to finish for 950 points, right? True, but that
assumes that
pilot C would screw himself by finishing for 900 points
when he too
could have landed short for 999 points. And so on,
down the list.
The reason we have scoring systems with a high 'landout
penalty' is
precisely to eliminate these situations in which a
pilot might get fewer
points for finishing than he would get for deliberately
landing short of
the finish line.
Gary Ittner P7
'Have glider, will race'
Old September 29th 03, 11:20 PM
John Galloway
Pure undiluted common sense.
John Galloway
At 22:06 29 September 2003, Chip Bearden wrote:
I agree with Dale (below). I was waiting for someone
to voice the
'hey, it's fun' rationale for traditional high-speed
finishes and it's
amazing that it took nearly 50 postings:
the spectators
Dale Kramer
K1
I also agree with Kirk Stant that part of the appeal
(and challenge)
of soaring is that it allows us to incur whatever level
of risk we
intelligently elect. 'Adrenaline junky' is a harsh
term but I'll be
honest in admitting that the part of the 'thrill' (another
harsh term
used in this context) of soaring is the element of
risk and how we as
pilots manage it.
There was a provocative article in (I believe) Gliding
Kiwi about ten
years ago that said, in effect, let's quit trying to
convince everyone
that soaring is 100% safe. It's not, and therein lies
some of the
appeal. Certainly competition soaring involves an element
of that.
Those who know me also know that, at age 52 with a
wife and 9-year-old
twin daughters, and with a father and a best friend
who were both
killed in soaring accidents, I certainly don't have
a death wish. Far
from it. I WANT to be as safe a pilot as I can be.
But I also want to
enjoy this sport the way I always have, and contest
finishes still
have the same appeal they did when I first starting
flying contests in
1968.
As for the less emotional arguments for/against, they've
been made.
The most persuasive, to me, is that whatever penalty
is imposed for
busting the floor of the finish donut will, perversely,
act as an
incentive to thermal at low altitudes trying to 'save'
a flight, even
a flight that, ironically, could be concluded quite
safely be simply
gliding to the finish line sedately from one or two
miles out and 499
feet. Yeah, it might make some pilots or flights 'safer'
but I can see
how it will make certain other situations 'less safe.'
A lot depends
on what the meaning of the word 'safe' is.
Based on my experience with the donut, I also agree
with Dale that you
tend to spend more time heads down to make sure you
don't bust the
hard deck at the last minute. After all, you can't
actually SEE it,
unlike the traditional finish line. My biggest fear
is learning after
the flight that my flight recorder shows I missed the
donut by, say,
20 feet even though my altimeter indicated I was 50
feet above when
the GPS said 1.0 mile. Given the number of turnpoints
that pilots have
missed by a few meters, do we really need another way
of screwing up a
flight?
I'm from the old school. I check out fields under the
glide path from
likely finish directions BEFORE final glide. I keep
500 feet dialed in
as a final glide margin and often take more than that.
And when I'm
not sure I can make it back safely, I land. I may make
that decision
10 miles out at 2000 feet (or even higher) or one mile
out at 200 feet
depending on the fields, the weather, etc.
But it's MY decision, not someone writing rules that
attempt to level
the playing field for pilots with vastly different
amounts of skill
and experience. No matter how noble the rationale,
that's a
troublesome way of thinking to me, even in the name
of 'safety.'
The low finish isn't something an inexperienced pilot
should try
without proper preparation. And it isn't something
anyone should try
under improper conditions. But, as for many other things
we do in
sailplanes that the uninitiated think are dangerous,
the cure for this
'problem' seems to be better training, better qualification
of
contestants, and better judgment rather than blanket
prohibitions. The
increasingly popular regional competition clinics are
great places to
address this.
Chip Bearden
Old September 30th 03, 06:29 AM
Andy Blackburn
Well put Chip.
9B
to voice the
finishes and it's
the spectators
Dale Kramer
K1
(and challenge)
of risk we
term but I'll be
harsh term
risk and how we as
pilots manage it.
Kiwi about ten
convince everyone
some of the
of that.
wife and 9-year-old
who were both
a death wish. Far
But I also want to
finishes still
flying contests in
1968.
been made.
is imposed for
act as an
a flight, even
safely be simply
miles out and 499
but I can see
A lot depends
with Dale that you
don't bust the
actually SEE it,
is learning after
donut by, say,
feet above when
that pilots have
of screwing up a
flight?
glide path from
500 feet dialed in
And when I'm
that decision
out at 200 feet
attempt to level
amounts of skill
that's a
of 'safety.'
should try
anyone should try
we do in
the cure for this
of
prohibitions. The
great places to
address this.
Chip Bearden
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Can a Private Pilot tow gliders and get paid? zatatime Piloting 3 October 17th 04 01:35 AM
FAA has temporarily withdrawn the proposed Sport Pilot rule Larry Dighera Piloting 2 March 27th 04 06:23 AM
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. Larry Dighera Piloting 0 February 22nd 04 03:58 PM
