Pre-Preg
Old December 5th 16, 07:16 PM posted to rec.aviation.soaring
kirk.stant
Default Pre-Preg
On Friday, December 2, 2016 at 6:48:16 AM UTC-6, Bruce Hoult wrote:
Most gliders work out at about 6 (30 kg/m^2) dry with a 240 lb pilot, don't they?
My LS6 runs around 8psf (39 kg/m2) dry with me in it (240 on a good day). I would think you would have to get into open class or older std gliders to get as low as 6 psf...
Works great for no-ballast (Beer ballast?) contests...
Kirk
66
Old December 5th 16, 07:23 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Pre-Preg
For the guys with an engine weight does make a difference. Imagine if the 100 pounds of engine and fuel were offset by construction methods that lowered the empty weight of the glider by even 50-70 pounds. YOu would functionally have the same wing loading range as a pure glider.
Just saying.
On Thursday, December 1, 2016 at 4:09:14 PM UTC-8, wrote:
4 Pretty much nobody cares much about weight, except the little gliders. For all the rest we just want to know how much water can we get in it.
Old December 5th 16, 09:58 PM posted to rec.aviation.soaring
Casey[_2_]
Default Pre-Preg
Just saying.
4 Pretty much nobody cares much about weight, except the little gliders.. For all the rest we just want to know how much water can we get in it.
Different building methods in same factory brings several issues I could think of.
Cost of buying and storing different materials, cost of process, possible mistakes in manufacturing, return on investment, different flying characteristics. Just throwing this out there.
Old December 6th 16, 12:59 AM posted to rec.aviation.soaring
Casey[_2_]
Default Pre-Preg
Just saying.
Maybe this is why GP decided to put the batteries in the wings. Removal for light days without changing CG. All other FES gliders have batteries behind cockpit and have to fly with batteries.
Old December 6th 16, 02:57 AM posted to rec.aviation.soaring
Dan Daly[_2_]
Default Pre-Preg
Just saying.
4 Pretty much nobody cares much about weight, except the little gliders. For all the rest we just want to know how much water can we get in it..
Aren't the light days the ones where you most need the batteries?
Old December 6th 16, 07:38 AM posted to rec.aviation.soaring
Fraser Wilson[_2_]
Default Pre-Preg
Three further points with pre preg;-
1-Uni directional (UD) pre-preg, which is extensively used in wings, is
difficult
to form into compound curves;- it wrinkles
2-stray fibres, with pre-preg stray fibres can puncture the vac bag. The
wing
skins don't come out of the moulds until after the wings have been fully
glued
together. It's a bad day to discover a single stray fibre has killed the
vacuum
during the cure of a skin and you've just glued it to a good
spar/skin/installed
controls etc
3 - wet lay up wings post cure at 60C, normally out of mould. Pre-Preg
cures
at least 80C maybe hotter but this must be done in the mould. This means
the part and mould thermal expansion must be closely matched and the
longer the part , the more compound curves, the more difficult this
becomes.
Dry fibre resin infusion probably offers the best way forward as it can
provide
similar fibre fractions to pre preg but without the above and earlier
mention
drawbacks.
Fraser
th=
lo=
funct=
=20
Just saying.
gliders=
th=
ink of.
m=
characteri=
Old December 6th 16, 10:58 AM posted to rec.aviation.soaring
Ross[_3_]
Default Pre-Preg
difficult
wing
glued
vacuum
spar/skin/installed
controls etc
cures
becomes.
provide
mention
drawbacks.
Fraser
I tend to disagree with most of that.
UD is difficult on complex shapes yes, but what is complex about a wing? It is basically straight. If you can laminate it with wet laminate, you can do it with prepreg.
You would cure the skins then glue the rest in. Well, this would be my approach. The spar can be co-cured in there if you like. Makes for easy small steps in manufacturing.
Similar way to the concept behind a F1 car. Outersking, honeycomb and inserts, innerskin.
Don't see the issue with postcure. No need for it to be done in the mold with Prepreg. We were postcuring suspension to 180-220 deg C out of the mold and had no issues. They were cured at 130 to start with.
As far as thermal expansion goes, why not make your molds out of tooling prepreg? Works like a charm, and if you have a decent glider you will make plenty of gliders out of the mold and you will always have the same shape. Beats having to rework your molds every couple of years
Old December 6th 16, 11:05 AM posted to rec.aviation.soaring
Casey[_2_]
Default Pre-Preg
I was thinking of a comp. Motor only used to prevent land out and longer day. But I suppose on a rec flying day one could take out on a light day as well. I would think that flying a light day and booming day are no different other than more turns and less aggressive speed, but a lighter craft would benefit. I'm not even sure what the GP batteries weigh.
  #29
Old December 6th 16, 02:10 PM posted to rec.aviation.soaring
Luke Szczepaniak
Default Pre-Preg
Just saying.
Probably has more to do with allowable max weight of non-lifting parts...
Luke Szczepaniak
  #30
Old December 6th 16, 05:15 PM posted to rec.aviation.soaring
Default Pre-Preg
Just saying.
Putting the batteries in the wings reduces the weight of non lifting parts which means the wing spars and root area don't have to be made as heavy.
UH
