Winching - Reverse Auto Tow
Old November 7th 03, 05:00 PM
F.L. Whiteley
"Chris Nicholas" wrote in message
Frank Whiteley wrote [snip] " we pulled all of the
wire from the drum and found it to be collapsing inward under the strain
of
launching the Twin Astir and L-13 under more power than the winch had
been
designed for."
This happened to another club, and I am concerned it might to us too.
What did you do do to fix it - could the ATC-type drum be suitably
reinforced to prevent it, or did it need a new drum which would no doubt
be of heavier material or with added stiffeners inside?
Chris N.
It was repaired with steel pipe of a suitable diameter and thickness by the
late Robyn Pierce-Boby and Larry Green(e?). Since Enstone GC is defunct, I
have no idea how to contact Larry. Someone like Ken Sparkes may be able to
help with contacting Larry. I don't have the specific details, but the pipe
was cut to a suitable length and split into two halves and clamshelled
around the existing drums. Once welded into place, it was turned true and
balanced. Seemed to do the trick though I originally thought it inelegant
and perhaps trickier than just making new drums.
Frank Whiteley
Old November 8th 03, 12:50 PM
Frank Dobbs
"W.J. \(Bill\) Dean \(U.K.\)." wrote in message ...
The initial acceleration for a car or reverse pulley launch is no worse than
for an aerotow; it is flown in the same way. There is of course no tug
slipstream to contend with.
A car launch starts like an aerotow, and turns into a winch launch when you
are airborne.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
message ...
Initial acceleration is certainly much slower with autotow (whether
pulley or direct) than with winching. At both North Weald and Aston Down
there was more than one runway, so most launches were broadly into-wind.
Such cross wind as there was could be handled. The initial ground run
was a phase of flight in its own right - the pilot had to learn to
balance on the wheel and taxi straight until flying speed was achieved.
Wingdrop was not normally a problem, but training people to taxi was a
feature. The same considerations apply when landing, in any case, so
they got two lots of taxi training in one flight.
On tarmac or concrete the F250 trucks had adequate power and grip. F100's
were not bad, but we didn't have such heavy gliders in those days.
Aston Down tried a variety of tow vehicles over the years, including
some home-built diesel dragsters, but I believe they ended up with
factory-built trucks, as we did, and as Lasham (using straight autotow
at one time) also did. I worked for Ford then, and helped to get some
advantageous prices for imported US-built vehicles for two if not all
three clubs IIRC - Ford used gliders at North Weald as background for
some advertisements, and did us a favour in return.
My club used LPG rather than petrol/gasoline, which made it a comparable
fuel cost to diesel winching, per launch/cable-retrieve. Total
depreciation/financing cost was probably about comparable, but needed
less cash flow up front. Trucks were cheaper capital cost than new
winches, though not as durable - ours lasted for about 50,000 launches
each and were not fully worn out - we recycled one old powertrain into a
winch when we had to adopt that method for our Ridgewell site.
The key features for us at North Weald were that on hard runways we had
to use piano wire (single strand steel cable), not stranded, to avoid
too much wear and cable cost, and pulley/autotow lends itself to that
better, with pulley giving also the benefit of fast launch rate when
well organised. We did about 9,000 launches a year, and added
considerably to our cash flow, when we had optimised the system.
Chris N.
It was the Dublin Gliding Club which used reverse pulley launching in
Ireland up to the early 1970s.
I flew there, from Baldonnel airfield. The pulley was about 3feet in
diameter and very simple with hardly any fairing. It was mounted on
the back of a large Chrysler car which had a tow-beam coming out of
the front with a heavy metal spike at right angles that was embedded
in the ground to anchor it. The mount for the pulley allowed it to
rotate to any angle to follow the line of the cable. The cable was
single strand piano wire. The concrete runways would have worn out
stranded cable too quickly.
The tow car, a large American automatic transmission car, had a
standard cable release mechanism welded to a lever which compressed a
small plastic football filled with water connected to a clear plastic
tube leading in to the top of the dashboard. The water rose in the
tube as the tension in the cable increased. Marks indicated the right
pressure for single seaters and two seaters (we flew K7, K13, K8, K6
mainly). The launch driver technique was very simple. Accelerate
rapidly to the correct tension once the glider was established in
climb. Slow down or speed up to keep the tension on the mark. I don't
remember ever having to signal too slow or too fast from the glider.
When the wind was strong, it was possible to reverse down the runway,
paying out the cable, as the glider kited upwards. My highest launch
was 4500 feet using this approach.
Cable breaks took rather a long time to disentangle as the cable
sprang back and tied itself in knots. Good heavy gloves were useful.
Splices were carried out by two people standing opposite each other
and winding the free ends back over the wire by hand.
The end came when the Army Air Corps installed VASI instrument landing
lights at the ends of the runways. The runway lights had been
expensive to replace if hit by flying rings, but the VASI lights were
£20,000 each and would have meant bankruptcy.
The Dublin Gliding Club still launches by (straight) car tow from
beaches in County Kerry each year on their wave safaris, using parafil
cable.
Frank Dobbs
Ulster Gliding Club, Northern Ireland
Old July 18th 16, 05:58 AM posted to rec.aviation.soaring
Default Winching - Reverse Auto Tow
Has anyone had experience with a reverse pulley system on asphalt runways and using a rope, rather than piano wire or cable? I am considering the feasibility of 1/4" Dacron rope on an 8,000' runway in Hobbs, NM. My concern is that the rope will wear out too fast, being drug at launch speeds (45-55 mph) down the runway. We do straight auto tow now with steel wire, but there are power lines in the area, and we couldn't risk 4,000+ feet of conductive cable being in the air in case of a break, or even a decent crosswind.
Spectra rope makes more sense, but I would like to use Dacron to prove the concept without as much investment. If it works, Spectra would likely make more sense for performance and longevity.
Stephen Layton
Hobbs, NM
Old July 18th 16, 03:11 PM posted to rec.aviation.soaring
Gen Shib
I have about 2,000 winch flights. Most damage to rope/cable is done after glider release when rope hits ground and being reeled in fast at the same time, not launch. Synthetic materials are great because they are light and impact themselves less on ground.
Old July 18th 16, 06:24 PM posted to rec.aviation.soaring
Bruce Hoult
Yeah but on a regular winch launch the cable is off the ground along its entire length pretty quickly. There won't be anywhere near enough tension with a reverse pulley system to keep the cable between the pulley and the car off the ground, especially as the length of cable increases as the glider gets higher and the tension becomes less.
Interesting pics he
http://www.coloradosoaring.org/think...ey/default.htm
Old July 18th 16, 08:06 PM posted to rec.aviation.soaring
Tony[_5_]
Suggest you consider a 2:1 pulley launch. Gets the rope up off the concrete during the launch very quickly.
We've done 10 or so at Sunflower. 4000 feet of rope on a 7000 ft runway. Easy 1500 ft launches in our nose hook equipped 2-33.
Only time the rope drags on the runway is when (very slowly) resetting the rope after the launch.
Old July 19th 16, 04:21 PM posted to rec.aviation.soaring
I'm not sure I see much advantage of a 2:1 system (assuming you mean the reverse-driving vehicle has a pulley as well). Wouldn't you still be dragging 4,000 ft of rope behind the tow vehicle (from the fixed pulley)? It hardly seems worth the extra rigging trouble...but I've never done it either. My primary concern is rope wear, and I'm not seeing much improvement with that. Please let me know what I am missing.
Stephen
Old July 19th 16, 05:07 PM posted to rec.aviation.soaring
JS
We've done 10 or so at Sunflower. 4000 feet of rope on a 7000 ft runway.. Easy 1500 ft launches in our nose hook equipped 2-33.
Stephen
Stephen, if runway markers allow and you have the luxury of grass, park the pulley in the grass at the side of the runway and drive on the grass.
  #29
Old July 19th 16, 05:25 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Stephen
End of rope is anchored to the ground. Rope goes around pulley on the launch car, then back to the glider. Car travels half the speed of the glider (2:1 system). The only rope moving relative to the ground during the launch is the rope between the pulley and the glider. And similar to a winch launch, all that rope becomes airborne pretty quickly.
Steve Leonard
  #30
Old July 19th 16, 05:27 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Hobbs, NM, Jim. There is no grass alongside their runway! :-)
Steve Leonard
vortex ring state at any point during an auto?? Greg Johnson Rotorcraft 18 August 30th 04 09:12 PM
Auto Fuel Residue Stu Gotts Restoration 4 May 12th 04 08:52 PM
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 06:19 PM
Arrow auto gear extension oddness Roy Smith Owning 10 March 8th 04 02:27 AM
VOR & Reverse Sensing mrwallace Piloting 1 August 21st 03 03:08 AM
