Do you crab or forward slip in X wind landings
Old February 26th 17, 03:37 AM posted to rec.aviation.soaring
[email protected][_1_]
Default Do you crab or forward slip in X wind landings
Side slip for all the above reasons, especially for instruction. Translating from crab to slip in the flair or just at touchdown is unnecessarily complex. Establish the forward slip on final and hold that attitude until stopped.
However, I commonly "cheat" whilst flying the tug, crabbing until short final and then establishing the slip. Less pressure on the rudder foot/knee if doing lots of landing in the Pawnee.
Old February 26th 17, 07:06 AM posted to rec.aviation.soaring
Bruce Hoult
I don't know anyone who "transitions from crab to slip in the flair [sic]". You simply straighten up with wings level, and accept whatever minor sideways component the crosswind gives you in the two seconds before you touch down. Either you touch down going very slightly sideways, or you yaw a little past the runway heading to align with the direction the glider is actually going. Or, I guess, you could fly your final with a track slightly upwind of runway heading so that your track gets aligned by the crosswind during the flare.
It doesn't really matter on the wide lush grass runways we fly gliders from.. Maybe it's different if you're landing on a strip of concrete only a couple of meters wide.
Maintaining a slip all the way to the ground isn't a good idea in the long span low wing gliders we train in, especially if the grass is lush and/or uneven. Wings level!!! Again, it may be different in a 2-33.
Old February 26th 17, 04:25 AM posted to rec.aviation.soaring
Andreas Maurer
On Sat, 25 Feb 2017 18:30:11 -0800 (PST), Citrus Soaring
Side slip is the easiest and most powerful form of crosswind correction. Simply use the rudder to keep the nose of the glider parallel to runway center line and lower the upwind wing enough to counter the wind. To much bank and you drift upwind of centerline. Side slip can be maintained all the way to the end of the roll out just by keeping the upwind wing low. If the cross wind is to strong for this method you shouldn't be flying or you should select a different runway.
Crab Requires a transition to a side slip just above the ground and almost guarantees a side loaded landing either from kicking to late or to soon and not getting into the side slip quick enough.
Forward slips are not really for crosswind correction they are more for glide path control.
I wonder about the different methods that are taught - in Europe the
only acceptable method is crab, aligning with rhe runway heading
during the flare, and immediately touching down. Priority is to keep
the wings level all the time to reduce the chances of a ground loop in
case of an outlanding.
Is it grass strips vs. paved runways which we don't have in Europe?
Just a question (since I fly a glider where side slip would always
drag the wingtip on the ground before the main wheel touch down):
How do you cope with one wingtip lower than the other in case of an
outlanding on a field with higher crops? To me the side slip method is
a recipe for disaster in this case...
Do you teach both methods?
Cheers
Andreas
Old February 26th 17, 05:58 AM posted to rec.aviation.soaring
Duster
If you have altitude to burn you can do the the entire pattern using turning slips, and this can be a safer maneuver than the standard coordinated turns. Nevertheless, I prefer to crab when taking off and landing in a crosswind, even though you're performing a dreaded skid at the last moment.
Old February 26th 17, 10:15 AM posted to rec.aviation.soaring
Jonathon May
If
you
almost
and
glide path control.
Cheers
Andreas
I think it depends on what you are flying and the surface you are landing
on
The modern ships like Ventus 3 and arcus seem to have high wing tips as did
the early American stuff so slip makes sense
The kestrel,nimbus generation ships had low tip clearance and a crab was
only way.
I was once told the are only 2 types of Kestrel owners ,those who have
ground looped and those who are going to
Nice soft grass is much more forgiving of a little sideways slide than high
friction paving
Old February 26th 17, 02:27 AM posted to rec.aviation.soaring
Matt Herron Jr.
On Saturday, February 25, 2017 at 1:04:02 PM UTC-8, Jonathan St. Cloud wrote:
Do you crab or forward slip landing in x-winds and why? When I was taught how to fly an airplane the crab method was used when I transitioned to gliders my instructor emphasized forward slip over crab. Years later I have established my procedures, but I thought this might be a useful discussion for newer pilots.
slip will bleed off more energy than a crab. If you are low, a crab would be better. I tend to use slip as you can keep lined up on the approach and it is easy to adjust the slip for wind shear.
Old February 26th 17, 11:55 AM posted to rec.aviation.soaring
Jim Kellett
On Saturday, February 25, 2017 at 4:04:02 PM UTC-5, Jonathan St. Cloud wrote:
Do you crab or forward slip landing in x-winds and why? . .
I teach both (a requirement of the FAA Pilot Test Standard), but recommend and almost always use a slip (in the US, that'd be the oxymoronically labelled "side slip", not a "forward slip") in moderate crosswinds. If the xwind is too strong, I switch to as much of a slip as is comfortable to avoid wingtips dinging the runway, then crab.
These procedures are more important on paved runways than grass, because the side loads on the gear with even a slightly botched crabbed landing on pavement can cause significant damage.
As to "why", it's because the properly executed "side slip" permits a stabilized approach that continues right down into the flare (easier to teach as well), and reduces the risk of side loads on the landing gear.
Finally, when the issue of ground loops, grass vs. pavement, or off-airport landings is raised, then the answer changes to "it depends", and the pilot should be skilled in using whatever procedure fits the circumstances.
Old February 26th 17, 06:25 PM posted to rec.aviation.soaring
Tango Eight
This thread is more interesting that I would have guessed. I thought standard practice was to teach both. That's what we did when I was a student pilot. Crabbing was emphasized as the better technique for managing larger cross winds (and we students figured it out, just fine).
It's obvious to any pilot proficient with both slips and crabbing approaches that the cross wind limits of the crabbing approach are vastly higher than what you can manage with slipping alone. About 50%, I'd reckon.
see also: Peter Schiff, The Proficient Pilot.
best,
Evan Ludeman / T8
Old February 26th 17, 07:10 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
This thread is more interesting than I would have guessed. I thought
I no longer remember if I was taught both. Learning in a (slab-sided) 2-33, I
was *certainly* taught slips as a means to increase sink, and I remember them
being useful/great-fun in early-model, top-only-spoilered, 1-26's. Upon
transitioning into flaps-only single-seaters, I found slipping approaches
unnecessary/not-realistically-worth-practicing due to (in the case of the
wimpily-ruddered) HP-14, full flaps resulting in something less than a 4/1
L/D, and, in the case of the (less-powerfully-flapped) Zuni, slips with full
flaps actually *reducing* the sink rate.
As for the actual touchdowns, I always sought to 2-point-on the HP-14 (easy to
do), while simultaneously (if possible) angling into any "significant
crosswind" by way of minimizing drift at touchdown; I can't recall ever
landing the HP on pavement in a crosswind. OTOH, in the Zuni (especially on
pavement) I routinely wheeled-on the ship with partial flaps in significant
crosswinds, just because it was easier to do gracefully than attempt an
easily-ballooned flare-to-a-2-point attempt. (The HP also wheeled on nicely,
but I thought it counterproductive - in a "useful most often" skills sense -
to routinely do so.)
Does it go without saying all flaps-only skills were self-taught (i.e.
reading, thinking, doing)? Definitely a good idea (and challenging fun if
approached with the right mindset) to continually attempt to increase the
variety/competency of skills in one's collection...
Bob W.
Old February 26th 17, 08:00 PM posted to rec.aviation.soaring
best,
Evan Ludeman / T8
I teach both but find most end up preferring slip. I do insist on slip when teaching in the Cub. My airplane- my rules.
UH
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
Crab, slips, and crossed controls Amine Piloting 190 September 27th 08 07:59 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (0/1) JR[_2_] Aviation Photos 0 August 13th 08 09:35 PM
video of cross-wind landings jbaloun Home Built 0 June 2nd 06 01:56 AM
Got some neeed help with cross-wind landings... Ekim Piloting 13 October 23rd 04 04:40 PM
