#21
"Janusz Kesik" wrote: Użytkownik Janusz Kesik w wiadomości do grup dyskusyjnych ... Also gaining height (in order to shorten the tow) by a towplane with glider behind is much, really much easier and less stressing when using a short 20-30m rope. I meant gaining height in a towplane with a glider behind, by using the thermal to support the tug's climb rate. If the combo has found a thermal, why wouldn't the glider just release and save money? Therre have been plenty of times that I've intended to tow to 2000 or 2500 ft but then released in a thermal at 1000 - 1500 ft. -- Bruce |
Użytkownik Bruce Hoult w wiadomości do grup
dyskusyjnych ... In article , If the combo has found a thermal, why wouldn't the glider just release and save money? When the combo (now I know the word for it ![]() 70m, it's too low I think... ![]() JK |
Andreas Maurer wrote: On 5 Dec 2003 10:53:17 -0700, (Mark James Boyd) wrote: A lot of different techniques - little consensus Bruce - Hi to slow and get slack out, then match speeds by diving Brian - Yaw to reduce snappiness when line comes taut Janusz - Shorter rope so tug and glider are in the same air Michel - Low tow and avoid slack line Let me add the standard procedure that I was told and that all pilots I know of are using: Extend the airbrakes (carefully - only about one inch) to get the slack out. Don't let the speed difference between glider and tow plane get too big. And if it does, what do you do then? That's why if I'm going faster than the towplane I prefer to store the energy by climing a little, rather than by simply throwing it away using the brakes, or a slip, or a yaw. The slack isn't going to come out until you're going slower than the towplane, and you need a way to get back to about the same speed again. -- Bruce |
I know of are using: Extend the airbrakes (carefully - only about one inch) to get the Try this in a Janus. Extending isn't a problem, but I wish you luck closing them again during the tow. Chances are that after successfully closing them, slack is much bigger than before. Stefan |
![]() Użytkownik Bruce Hoult w wiadomości do grup dyskusyjnych ... In article , That's why if I'm going faster than the towplane I prefer to store the energy by climing a little, rather than by simply throwing it away using the brakes, or a slip, or a yaw. But there's a risk that the towplane gets "out of the screen" because You got higher than it, and then You have a problem... JK |
On Sat, 06 Dec 2003 16:59:44 +1300, Bruce Hoult
wrote: Extend the airbrakes (carefully - only about one inch) to get the slack out. Don't let the speed difference between glider and tow plane get too big. And if it does, what do you do then? Pray that I don't break the cable. That's why if I'm going faster than the towplane I prefer to store the energy by climing a little, rather than by simply throwing it away using the brakes, or a slip, or a yaw. The slack isn't going to come out until you're going slower than the towplane, and you need a way to get back to about the same speed again. Basically a good idea - but higher than the tow plane, especially in gusty conditions, is a place where I try not to be. Bye Andreas |
On Sat, 06 Dec 2003 11:35:46 +0100, Stefan
wrote: Try this in a Janus. Extending isn't a problem, but I wish you luck closing them again during the tow. Chances are that after successfully closing them, slack is much bigger than before. Why? I haven't flown the Janus that often, but to me its airbrakes didn't feel extraordinary to me? Bye Andreas |
#29
Andreas Maurer wrote: On Sat, 06 Dec 2003 16:59:44 +1300, Bruce Hoult wrote: Extend the airbrakes (carefully - only about one inch) to get the slack out. Don't let the speed difference between glider and tow plane get too big. And if it does, what do you do then? Pray that I don't break the cable. I think perhaps if there is some room to go down without dramatically pulling down the towplane tail, a slight dive might work, perhaps a little off to the side to add some yaw/dampening effect That's why if I'm going faster than the towplane I prefer to store the energy by climing a little, rather than by simply throwing it away using the brakes, or a slip, or a yaw. The slack isn't going to come out until you're going slower than the towplane, and you need a way to get back to about the same speed again. Basically a good idea - but higher than the tow plane, especially in gusty conditions, is a place where I try not to be. So if you start at low tow or right in the propwash, pulling up a little won't get you above the towplane as quickly. But we are agreed that so high one can't see the towplane is bad (immediate release) but that same angle lower than the towplane is not as sketchy (although now we have the new worry of possible slack rope around the wing or a much more exciting rope break). Bye Andreas So again, in this thread I was mostly talking about rope breaks in wave instead of thermals. So I suppose it would be nice to know how standard tows through rotor go. I imagine one starts under/before the rotor and the first thing the tug hits is negative shear or a downdraft. If the tug drops, and glider doesn't drop too, glider is too high and uh oh. So the glider can either nose down, slip, or use spoilers to lose altitude and stay with the tug. Nosing down, if done wrong (too much) means now you've introduced slack, and when the glider hits the same downdraft/tailwind a few seconds later, the rope comes taut and snaps. Now in the rotor, the tug maybe hits an updraft/positive shear. If the glider pitches up and stays in position, then when the glider hits the same updraft/headwind a few seconds later, the glider will be too high and have to use spoilers/slip/nose down to maintain position. Spoilers are tricky to use. We tried them during some of our slack rope practice and the difference between closed and cracked is dramatic. Diving the nose seems like it might take a lot of skill to do right. On the other hand, using a slip to lose altitude is simply, easy to take out, and has the added inherent "yaw" benefit. So perhaps flying low tow or right in the wake, and using slips is the simplist (but not most elegant) technique. Then watching what the tow plane does and anticipating the same thing happening to the glider a few seconds later would help. Eevn on low tow it seems there is some room to dive a little to get airspeed at the last second if needed. I plan to go to the Sierras at some point for some wave fun, and perhaps will try both high and low tows and see how they compare. Should be fun ![]() Mark PS. The dramatic difference between closed and cracked also came up from a 10 foot rope break. With the fence coming up, slowing down is important. I couldn't forward slip (wings too long close to the ground), so I cracked spoilers. The plane bounced fairly gently once, and then I closed the spoilers and landed (although a little long). It seems at 60-70 mph at 10 feet on rope break, I was better off pitching up to climb and slow down, and opening spoilers during the pitch up climb. Cracking spoilers at high speeds has a dramatic effect (perhaps not surprisingly now that I think about it in my armchair). It seemed pretty clear that spoilers are designed for losing altitude, not for slowing down. If they were designed for slowing down, there would be a pitch up change when deployed, right? "rec.aviation.soaring - BS free since Dec 6, 2003 11:45 PST" ;-p |
#30
Why? I haven't flown the Janus that often, but to me its airbrakes didn't feel extraordinary to me? The last time I flew a Janus, I needed both hands to close the airbrake. THE girl who flew it the next day even couldn't close them at all, she needed the help of the copilot. Stefan |
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 07:28 PM |
(PIREP, long) Cherokee 180 from Bay Area to Bishop, CA | Dave Jacobowitz | Piloting | 15 | June 24th 04 12:11 AM |
Flight test update - long | nauga | Home Built | 1 | June 5th 04 03:09 AM |
SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 03:02 PM |
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS | MT. DIABLO HIGH SCHOOL PHOTOS | Home Built | 1 | October 13th 03 03:35 AM |
