Can anyone familiar with the WinPilot product tell me whether my DeLorme
Earthmate GPS Receiver (with DB-15 serial interface) will work with it? If not, what advice would you offer regarding iPac (or other pocket PC) models, and portable GPS devices to use with WinPilot? -ted |
Ted Wagner wrote:
Can anyone familiar with the WinPilot product tell me whether my DeLorme Earthmate GPS Receiver (with DB-15 serial interface) will work with it? Actually, the Earthmate has a DE9 (a.k.a. DB9) serial connector, and it is not compatible with WinPilot (or any other glide software), as it emits only Rockwell binary protocol, not the more common NMEA. If not, what advice would you offer regarding iPac (or other pocket PC) models, and portable GPS devices to use with WinPilot? If you don't need to send GPS data to any other devices, the simplest combination is a Dell Axim X5 combined with a CompactFlash GPS unit. See the following websites for possible setups: http://www.soarmn.com/cumulus/index.htm http://www.craggyaero.com/ Marc |
On Fri, 26 Dec 2003 17:47:37 GMT, Marc Ramsey
wrote: Ted Wagner wrote: Can anyone familiar with the WinPilot product tell me whether my DeLorme Earthmate GPS Receiver (with DB-15 serial interface) will work with it? Actually, the Earthmate has a DE9 (a.k.a. DB9) serial connector, and it is not compatible with WinPilot (or any other glide software), as it emits only Rockwell binary protocol, not the more common NMEA. If not, what advice would you offer regarding iPac (or other pocket PC) models, and portable GPS devices to use with WinPilot? If you don't need to send GPS data to any other devices, the simplest combination is a Dell Axim X5 combined with a CompactFlash GPS unit. See the following websites for possible setups: http://www.soarmn.com/cumulus/index.htm http://www.craggyaero.com/ Marc Be a little careful what you use as a GPS source. I've seen two Colibri loggers where the GPS altitude was heavily filtered. In one case it lagged the pressure latitude by 30 seconds in the other by 10 seconds. This can do interestingthings to final glide computers. When using unknown GPS receivers you really don't know necessarily how the receiver has been configured which is why I prefer Garmin 35 or 15 receivers which are completely user configurable. Mike Borgelt |
The Garmin 35 is inexpensive (often available on eBay) and works well.
It can be mounted below the instrument cover on many models such as our LS-1. Power draw is low, but watch the voltage requirements since there are several configurations of the Garmin 35 available (the 35 is actually an OEM device). Skip Guimond |
Mike Borgelt wrote:
The G35HVS is the one you want. Connect straight to 12 volts. For use with PDAs, the new Garmin GPS 18 LVC is worth a look. Supports WAAS/EGNOS, under 2 1/2" in diameter and 3/4" high, needs 5 VDC (but so does the PDA), street price is $80US. Downsides are the fact that it isn't available yet (1st quarter 2004), and has a non-removable magnetic base, like just about every other cheap mouse-style receiver... Marc |
The iPaq H5xxx models have a larger display than any of the other
current iPaqs. However they have inadequate audio sound level. The H3xxx models also had the large display and had good audio. Look for a H3950 or the new H5150. ' Regardless of the iPaq model you will need one of the Boxwave "Cleartouch" antireflective films as sold by Craggyaero.com, along with an efficient 5v power supply from the glider battery. A mouse type GPS could be useful, like the Garmin G35HVS (12 volts). Paul Remde has a good selection of bits and advice on his site http://www.soarmn.com/cumulus/ Cheers, Jim Kelly. "Ted Wagner" wrote in message news:8eZGb.14436$7D3.11470@fed1read02... | Can anyone familiar with the WinPilot product tell me whether my DeLorme | Earthmate GPS Receiver (with DB-15 serial interface) will work with it? | | If not, what advice would you offer regarding iPac (or other pocket PC) | models, and portable GPS devices to use with WinPilot? | | -ted | | |
Since my original posting on this topic, I've purchased an HP iPaq 5555 and
a NavMan 4400 wireless GPS. I've got those two working great together on the ground, but have yet to test them in the air. I haven't yet flown with them because I currenty fly rental sailplanes, usually a Pilatus B-4, where there's no mount for the iPaq. It's easy to tuck the GPS receiver somewhere (or even leave it in my pocket), but I have no place to put the iPaq. Does anyone make a device that lets me wear it on my leg, above me knee? What have other pilots done in this situation? -ted "Jim Kelly" wrote in message u... The iPaq H5xxx models have a larger display than any of the other current iPaqs. However they have inadequate audio sound level. The H3xxx models also had the large display and had good audio. Look for a H3950 or the new H5150. ' Regardless of the iPaq model you will need one of the Boxwave "Cleartouch" antireflective films as sold by Craggyaero.com, along with an efficient 5v power supply from the glider battery. A mouse type GPS could be useful, like the Garmin G35HVS (12 volts). Paul Remde has a good selection of bits and advice on his site http://www.soarmn.com/cumulus/ Cheers, Jim Kelly. "Ted Wagner" wrote in message news:8eZGb.14436$7D3.11470@fed1read02... | Can anyone familiar with the WinPilot product tell me whether my DeLorme | Earthmate GPS Receiver (with DB-15 serial interface) will work with it? | | If not, what advice would you offer regarding iPac (or other pocket PC) | models, and portable GPS devices to use with WinPilot? | | -ted | | |
On Thu, 08 Jan 2004 17:36:19 GMT, "Ted Wagner"
wrote: Since my original posting on this topic, I've purchased an HP iPaq 5555 and a NavMan 4400 wireless GPS. I've got those two working great together on the ground, but have yet to test them in the air. I haven't yet flown with them because I currenty fly rental sailplanes, usually a Pilatus B-4, where there's no mount for the iPaq. It's easy to tuck the GPS receiver somewhere (or even leave it in my pocket), but I have no place to put the iPaq. Does anyone make a device that lets me wear it on my leg, above me knee? I made a mount (for GPS, not an IPAQ but the principle is the same) from 6mm (1/4") ply that attached to the camera mount in a club glider and that worked just fine. A fellow club member made a thigh mount (again for GPS but should be quite possible for an IPAQ too) from 6mm (1/4") ply, a little scrap wood, some webbing and Velcro. She said it worked really well. You could make either in well under a day plus a little time for the paint to dry. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
WinPilot Offers Free WinPilot XP for your Desktop Computer | Richard Pfiffner | Soaring | 0 | November 8th 03 04:44 PM |
Declaring a flight in WinPilot to the Volkslogger | JohnD | Soaring | 0 | October 1st 03 11:55 PM |
Airdropped Fusion Devices | Blinky the Shark | Military Aviation | 4 | September 17th 03 05:34 PM |
WinPilot Now Supports Ipaqs with Pocket PC 2003 Ipaqs 2200, 5510, 5400, 5500 Series. | rhpf | Soaring | 0 | August 15th 03 01:21 AM |
WinPilot and Bluetooth on iPAQ 3970 anyone? | Al | Soaring | 7 | August 7th 03 03:10 PM |
