#21
On Mon, 12 Jan 2004 20:35:06 +1300, Bruce Hoult
wrote: In article , Martin Gregorie wrote: On Fri, 2 Jan 2004 17:39:28 +1300, "goneill" wrote: We are not talking a huge effect here Agreed. I was watching launches at Auckland a few weeks ago and didn't notice any gross bungee effects. All the launches I saw looked pretty smooth. I took a couple of winch launches at Puhipuhi in a Janus on I think poly rope last week. Seemed pretty smooth, and I didn't notice bad effects from stretching. Not that I got much height from my own pathetic attempt (less than 1000 ft), but it was enough to get away... I cheated last time I flew: poly rope all right, but attached to a Cessna 182, not a winch. We got away too, thanks to being dropped at 2500 on a ridge across the valley from Omarama. I was in the DG-1000 and spent the next three hours learning the first steps to mountain flying from Hugh. Fantastic! Worth every penny. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
Your heights seem to be a bit low off 4000ft on poly ,I would have
expected 1500 as an average On 3300ft we are averaging 1300-1600ft with single seaters Have you adapted the launch profile to take advantage of the rope. gary "Robert Curry" wrote in message om... (Doug Taylor) wrote in message . com... Vectran would not be a very suitable winch rope. It tends to fatigue relatively rapidly with bending. It is useful as standing rigging on sailboats but isn't used for running rigging. Technora is about the same tensile strength and modulus (both have very high modulus) without the fatigue problem. I don't have any proof of this but was told this by someone who appeared to know quite a lot about all the various new fibers being used in rope. Gary, Thanks for the information. Now, if the poly could be spliced ~50/50 or so with something like 1/8" Validator 12 http://www.samsonrope.com/admin/data...dator12_LR.pdf , (Vectran) http://www.pelicanrope.com/peli05c.htm both the bungee and sag effects could be reduced with some cost benefits. This could be a solution for long runs. When we launched with 1000ft of Spectra on the end of the wire rope, we didn't pull the Spectra through the rollers. Two synthetics with a reasonable join might work well as a hybrid solution. Vectran is stronger than Spectra with a higher critical temperature, but with somewhat less abrasion resistence. There are some interesting 1/4" vectran sheathed products http://www.pelicanrope.com/new04.htm for improved abrasion resistence. And Plasma 12 http://www.cortlandcable.com/psrope/...PlasmaRev9.pdf Spectra in a variety of sizes. Frank Whiteley Colorado OK, I can see that their are many ideas & successes on the polyrope. Can anyone give me an idea as to the height advantage. For example. Four thousand foot runway no wind. With wire we usually climbed to 1000 feet and with poly we averaged 1200? Does anyone know of a web site where this info may have been posted? Robert Curry Ohio |
More Spectra Winch Rope | Bob Johnson | Soaring | 0 | December 24th 03 05:45 PM |
Spectra winch rope | Bob Johnson | Soaring | 0 | December 24th 03 04:25 PM |
Tow Rope Freindly Fences | John Spargo | Soaring | 8 | September 2nd 03 04:17 AM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
Using Plasma Rope For Winch Tows | Craig Freeman | Soaring | 56 | August 24th 03 10:55 PM |
