What happens if a sailplane has no horiz stabilizer or elevator?
Old January 15th 04, 03:03 PM
Denis Flament
Bill Daniels wrote:
Denis, you should read up on the French designer Charles Fauvell and his
flying wings. They flew pretty well although I think Jim Marske's designs
are showing higher performance.
Tailless designs fly quite well and the performance really doesn't suffer.
They would be perfect for small jet engine self launchers.
Hi Bill
Yes I know that Fauvel "ailes volantes" like the glider AV36, and other
flying wings like Horten's fly quite well.
But I still doubt that suppressing the tail means suppressing the trim
drag of an airplane. Flying wings have to use stable wing profiles (with
positive pitching moment) and these produce more extra drag than a
tailplane.
Things are not so simple...
Denis
R. Parce que ça rompt le cours normal de la conversation !!!
Q. Pourquoi ne faut-il pas répondre au-dessus de la question ?
Old January 18th 04, 06:53 PM
Mark James Boyd
Andreas Maurer wrote:
On 14 Jan 2004 20:15:24 -0700, (Mark James Boyd)
Just imagine what forces your movable weight will exert under a g load
different than 1? For example, when you are flying through a vertical
gust?
I'd imagine it will behave the same as an attached one pound ballast
weight on the upper part of the rudder of the glider used to
balance the rudder. Perhaps I'm missing your point here...
This is precisely the cause why your idea cannot work - and why the
pilot of a hang glider is hanging so far *below* his wing.
Now this a very interesting point. Whether the weight is above
or below the C.G. seems to also have an effect. Thank you
Andreas...
The biggest safety feature would be ensuring the weight didn't
come loose during a critical phase of flight (near the ground)
and your supplementary "weight" cables don't hinder
the original controls in any way...
A weight right in the tail which moves maybe 3 feet forward
when the auxiliary stick is moved might do it. Hmmm...
Have you ever thought about what is regarded as the most important
invention of the Wright brothers?
You name it - aerodynamical control around all three axes.
It seems this weight shift idea is just a very fine refinement.
It's intention is to reduce that tiny bit of additional
drag caused by moving surfaces or trim. I agree this is
not anywhere near "the most important invention," but just a
fun winter mind-teaser.
There's a good cause why there was never such a system that ever
worked on an aircraft, although thousands of designers have tried it
in the pas 120 years.
Well, it has worked to improve the efficiency in cruise of
modern jet airliners, and has helped my fuel efficiency in
my 172 across the country, but perhaps, as you point out, not
as a primary control (for pitch in these cases). Except for
ultralights and powered parachutes (which have a low hanging weight)
we don't see it used in modern aircraft.
Perhaps you are right, the standard glider design
(with no low hanging weight) doesn't lend itself well
to this means of control...
Andreas
Thanks for your thoughts!
Mark
Old January 18th 04, 06:57 PM
Mark James Boyd
Bill Daniels
There are some obvious reasons not to use a canard (towrope tangling,
landout damage, creates turbulence before the wing) but this
seems an option as well... I've only flown one canard aircraft,
(and never a flying wing) so I may delve into this more...
Old January 19th 04, 04:40 PM
Andreas Maurer
On 18 Jan 2004 11:53:31 -0700, (Mark James Boyd)
gust?
You are correct - but you have the horizontal stab that dampens the
motion (remember that the whole fuselage and tail acts as a weight!).
This is the cause why you need something aerodynamical to control your
pitch, and why weight shifting does not work.
It does not matter whether the damping is done by a horizontal
stabilizier or the airfoil/wing design of a flying wing.
Yes - and don't forget that the control authority of hang gliders is
extremely limited. If the gravity vector is not pointing "downwards"
(seen from the pilot's coordinate system) they have absolutely no
control at all. Inverted flight is out of question, and they are able
to fly their loopings only with some tricks.
This is what is already being done - by water ballast in the tail that
fixes the CG at a position that is close to perfect for all flight
situations.
There have already trials been made (with ASH-25) to determine the
influence of performance of different CG positions in different
situations (cruise, climb, thermalling), and the inluence was nearly
immeasurably if the CG was moved to a supposedly "more optimum"
forward position during cruise.
The performance gain in a glider with rearward CG is (as you point out
for Cessan and airliners) often dramatic, especially in climb rate.
Bye
Andreas
Old January 19th 04, 05:51 PM
Roy
"Andreas Maurer" wrote in message
gust?
Twaddle !
There are guys who fly HG inverted (they are complete nutters, but the point
is, it can be done)
Looping a HG requires 2 things,
1) speed
2) balls
fly very very, very fast, allow the bar to come forwards _slowly_ then
accelerate towards a full aft CofG position in a _controlled_ manner. (that
way you can do 54 consecutive loops in a HG) ((if you start high enough))
The CofG on a tailess aircraft (i.e. hangglider) is only secondary in the
control of VNE and stall, CofG is used for trimming but the primary speed
control of the wing is performed by the washout at the tips and on older
gliders through "luff lines" acting as "up elevator" as the speed built up
(not really used much these days)
bottom line, with a swept wing platform you can _make_ it operate within a
set airspeed range by limiting it's AUW and setting the AofA along the wing
section.
regards
Roy
Old January 20th 04, 12:38 AM
Francisco De Almeida
Mark Boyd wrote:
Hmmm...anyone have data about forces provided by the
elevator is flight?=20
For the lift on the tail of an LS7 (standard class), see the last column =
of the table below. In a nutshell, in very slow flight the tail provides =
about 8 kgf (18 pounds) upward force, and at VNE, about 60 kgf (130 =
pounds) downward force.
These numbers are approximate, as the major influence is caused by the =
main wing pitching moment, which I estimated using xfoil and a single =
section approximation of the wing profile.
Francisco de Almeida
"C1" and "7"
IDA [33.3 daN/m2]
=20
Flight param @ min weight
=20
Wing
=20
for "111-1024"
=20
Drag
=20
=20
=20
=20
Horizontal tail
=20
=20
LD
s
Drag IDA
Power
V
=20
Pd
Rewing
CLW
a
CdW
CmW
Cdi
LD
profile
induced
parasite
Drag
s
M
CLH
LH
=20
ms-1
N
kW
kmh-1
ms-1
Pa
deg
N
N
N
N
ms-1
Nm
N
=20
23.9
0.84
144
2.9
72
20.1
247
921,632
1.346
7.5
0.0200
-0.116
0.0270
26
48
65
9
122
0.76
-279
0.30
78
=20
32.7
0.68
106
2.3
80
22.2
302
1,019,787
1.100
5.3
0.0090
-0.110
0.0180
36
26
53
11
91
0.62
-324
0.21
67
=20
39.7
0.63
87
2.2
90
25.0
383
1,147,260
0.869
3.4
0.0070
-0.105
0.0112
39
26
42
15
82
0.64
-391
0.13
50
=20
41.5
0.67
83
2.3
100
27.8
473
1,274,734
0.704
2.0
0.0059
-0.101
0.0074
41
27
34
18
79
0.68
-464
0.06
32
=20
40.2
0.76
86
2.6
110
30.6
572
1,402,207
0.582
1.0
0.0056
-0.099
0.0050
40
31
28
22
81
0.77
-551
0.02
10
=20
38.3
0.87
90
3.0
120
33.3
681
1,529,680
0.489
0.3
0.0054
-0.097
0.0036
38
36
24
26
85
0.88
-642
-0.02
-13
=20
35.4
1.02
98
3.5
130
36.1
799
1,657,154
0.416
-0.3
0.0051
-0.095
0.0026
36
40
20
30
90
1.01
-738
-0.04
-37
=20
33.0
1.18
105
4.1
140
38.9
926
1,784,627
0.359
-0.8
0.0049
-0.093
0.0019
33
44
17
35
97
1.16
-838
-0.06
-62
=20
30.6
1.36
113
4.7
150
41.7
1063
1,912,100
0.313
-1.2
0.0050
-0.092
0.0015
30
52
15
40
107
1.38
-952
-0.08
-90
=20
28.0
1.59
124
5.5
160
44.4
1210
2,039,574
0.275
-1.5
0.0050
-0.091
0.0011
27
59
13
46
118
1.62
-1071
-0.10
-120
=20
24.9
1.9
139
6.6
170
47.2
1366
2,167,047
0.244
-1.7
0.0053
-0.090
0.0009
24
70
12
52
134
1.95
-1196
-0.11
-151
=20
20.1
2.49
172
8.6
180
50.0
1531
2,294,521
0.217
-2.0
0.0057
-0.089
0.0007
21
84
10
58
153
2.36
-1326
-0.12
-184
=20
17.7
2.98
195
10.3
190
52.8
1706
2,421,994
0.195
-2.2
0.0057
-0.088
0.0006
19
95
9
65
169
2.75
-1461
-0.12
-218
=20
=20
=20
=20
200
55.6
1890
2,549,467
0.176
-2.3
0.0057
-0.088
0.0005
17
106
8
72
186
3.19
-1619
-0.13
-257
=20
=20
=20
=20
210
58.3
2084
2,676,941
0.160
-2.4
0.0075
-0.088
0.0004
14
152
8
79
239
4.31
-1785
-0.14
-298
=20
=20
=20
=20
220
61.1
2287
2,804,414
0.145
-2.6
0.0090
-0.087
0.0003
11
200
7
87
294
5.55
-1936
-0.14
-336
=20
=20
=20
=20
250
69.4
2954
3,186,834
0.113
-2.8
0.0090
-0.086
0.0002
9
259
5
112
376
8.07
-2472
-0.15
-470
=20
=20
=20
=20
270
75.0
3445
3,441,781
0.097
-3.0
0.0089
-0.085
0.0001
7
298
5
131
=20
=20
-2849
-0.16
-565
=20
  #29
Old January 20th 04, 03:12 AM
Steve Bralla
Andreas Maurer writes:
Remember, with weight-shift control, if you are weightless, you are out of
control. That's why it gets very "interesting" in a hang glider whenever you
go weightless.
Steve
  #30
Old January 20th 04, 10:14 PM
Andreas Maurer
On Mon, 19 Jan 2004 17:51:30 +0000 (UTC), "Roy"
Twaddle !
is, it can be done)
I'm talking about a *sustained* inverted flight, not a 4g loop where
the inverted part takes one second.
The loops you describe can also be done with a paraglider (where
inverted flight is obviously a little... problematic).
Bye
Andreas
Sailplane Rides - Gifts Michael Rotorcraft 0 December 7th 04 06:20 PM
Sailplane Rides - Gifts Michael Products 0 December 7th 04 06:19 PM
Any sailplane pilots? Larry Dighera Soaring 99 January 7th 04 03:46 AM
Sailplane Homebuilders Association workshop "report" Eric Greenwell Soaring 0 September 12th 03 06:07 AM
Electro-self-launching sailplane clement Soaring 5 September 12th 03 05:03 AM
