![]() "BHelman" wrote in message m... There is another Tcas that is even smaller and can be battery powered. It seems to have more favorable reviews. www.surecheckaviation.com The Shurecheck TPAS and the Proxalert R5 seem to be at the top of the small heap of these passive devices. Unlike earlier generation devices that only provided approximate range information (and left you guessing if it was an airliner way above you or a chunk of GA aluminum closing on your tail), both these newer units decode the "threat aircraft" transponder reply and display their altitude info. Further, they both give you the ability to limit the "shield volume", both in altitude and range, so as to minimize nuisance alerts in busy areas. Of these two, the R5 has more features, but also costs a couple of hundred more. R5 has a bigger footprint than the VRX (5" X 4.65" compared to 3.6" X 5.3"), but is less obtrusive when mounted atop an aircraft panel. It accomplishes this trick with an "L" shape design that has the base of the "L" dropping down below the panel by about .8" to allow a bigger display without blocking your view. Thus the R5 height above the panel is just 1" compared to the VRX's 2" height. Some other differences between the two: The R5 has no internal batteries, so must be plugged or wired in, the VRX uses AA batteries and can also be plugged in. The R5 displays 3 threat aircraft and tracks up to 10, the VRX displays one. The R5 is the only passive device that displays threat aircraft squawk, and from this you can tell if the threat is not getting ATC advisories (SQ 1200), or talking to ATC and hopefully being told of your presence (discrete SQ code), maybe military (I've heard, but don't know for sure, that they may use unique SQ codes), or a glider (SQ 0440 near Reno, NV). The R5 has a built in speaker for audio alerts in a quiet cabin (glider), VRX has no internal speaker, only audio in/out jacks so has to be hooked to intercom, headset, etc. Both units weigh within an ounce of each other (about 11 oz), in the case of the VRX, that's without batteries installed. Power consumption with the R5 is substantially less (100 ma with backlight off, 140 ma with the light on - - light not needed for daytime ops). The VRX is a bit more thirsty, (claiming 175 ma to 400 ma, with 350 ma listed as "nominal" in the user manual). For those not into such things, 100 ma or milliamps is 1/10 of an amp. I got my R5 four days ago and so far have only done ground testing, "burning the unit in" for much of this time, I jump up and run outside to get a visual when it "alerts" - - so far the accuracy is impressive. I've also taken it to the airport to see how it does in a busy environment. I'll fly with the R5 in my Mooney early next week and compare its alerts with the info I get from NorCal approach . I'll also fly with it in my glider as soon as possible, then will post a full review. The R5 is relatively new, being available now for only a couple of months in the US - - that's why you won't find many comparos on the internet yet. One of the French developers must be a glider pilot as there's a glider on their website and the text specifically refers to ops in a glider. The US distributor is Proxalert in Phoenix, AZ phone 602 992-3120. So far, the distributor's price ($1295) is less that advertised by Eastern Avionics ($1495). -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." |
The problem with the prox device in my opinion is two-fold. Overall
size is huge, the readouts are tiny, and the screen is cluttered. Power consumption is little concern for the Vrx if you plug it in. since the prox unit doesn't take batteries anyway, the Vrx has a clear advantage. The other problem is their approach of spamming the web with "3rd party" reviews. Given their reputation so far, foreign design, and lack of product experience, I can't think of a good reason to spend the extra $ on the prox. The review I have seen from a pilot who flew with the prox has not been too favorable thus far either. "bumper" wrote in message ... "BHelman" wrote in message m... There is another Tcas that is even smaller and can be battery powered. It seems to have more favorable reviews. www.surecheckaviation.com The Shurecheck TPAS and the Proxalert R5 seem to be at the top of the small heap of these passive devices. Unlike earlier generation devices that only provided approximate range information (and left you guessing if it was an airliner way above you or a chunk of GA aluminum closing on your tail), both these newer units decode the "threat aircraft" transponder reply and display their altitude info. Further, they both give you the ability to limit the "shield volume", both in altitude and range, so as to minimize nuisance alerts in busy areas. Of these two, the R5 has more features, but also costs a couple of hundred more. R5 has a bigger footprint than the VRX (5" X 4.65" compared to 3.6" X 5.3"), but is less obtrusive when mounted atop an aircraft panel. It accomplishes this trick with an "L" shape design that has the base of the "L" dropping down below the panel by about .8" to allow a bigger display without blocking your view. Thus the R5 height above the panel is just 1" compared to the VRX's 2" height. Some other differences between the two: The R5 has no internal batteries, so must be plugged or wired in, the VRX uses AA batteries and can also be plugged in. The R5 displays 3 threat aircraft and tracks up to 10, the VRX displays one. The R5 is the only passive device that displays threat aircraft squawk, and from this you can tell if the threat is not getting ATC advisories (SQ 1200), or talking to ATC and hopefully being told of your presence (discrete SQ code), maybe military (I've heard, but don't know for sure, that they may use unique SQ codes), or a glider (SQ 0440 near Reno, NV). The R5 has a built in speaker for audio alerts in a quiet cabin (glider), VRX has no internal speaker, only audio in/out jacks so has to be hooked to intercom, headset, etc. Both units weigh within an ounce of each other (about 11 oz), in the case of the VRX, that's without batteries installed. Power consumption with the R5 is substantially less (100 ma with backlight off, 140 ma with the light on - - light not needed for daytime ops). The VRX is a bit more thirsty, (claiming 175 ma to 400 ma, with 350 ma listed as "nominal" in the user manual). For those not into such things, 100 ma or milliamps is 1/10 of an amp. I got my R5 four days ago and so far have only done ground testing, "burning the unit in" for much of this time, I jump up and run outside to get a visual when it "alerts" - - so far the accuracy is impressive. I've also taken it to the airport to see how it does in a busy environment. I'll fly with the R5 in my Mooney early next week and compare its alerts with the info I get from NorCal approach . I'll also fly with it in my glider as soon as possible, then will post a full review. The R5 is relatively new, being available now for only a couple of months in the US - - that's why you won't find many comparos on the internet yet. One of the French developers must be a glider pilot as there's a glider on their website and the text specifically refers to ops in a glider. The US distributor is Proxalert in Phoenix, AZ phone 602 992-3120. So far, the distributor's price ($1295) is less that advertised by Eastern Avionics ($1495). |
Plane-crashes because of collision with bees ??? | Dan Simper | Piloting | 18 | February 13th 05 07:37 PM |
Airspeed of military planes | Tetsuji Rai | Piloting | 100 | April 24th 04 02:27 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
"China blamed in '01 air collision" | Mike Yared | Naval Aviation | 8 | September 15th 03 05:07 PM |
"China blamed in '01 air collision" | Mike Yared | Military Aviation | 2 | September 14th 03 06:08 PM |
