Spin
Old February 5th 04, 11:50 PM
Jon Meyer
At 23:12 05 February 2004, David Pye wrote:
Please would someone post a url if this clip is online.
http://www.fsv-unterjesingen.de/DnLoads/Seilriss.avi
Old February 8th 04, 09:57 AM
ir. K.P. Termaat
Did some simple calculations to get an idea of what caused the spin of
the DG500.
If the glider flew initially with an IAS of 100km/h and had a headwind
of say 25 km/h then its speed relative to the ground is 75km/h. If
after making the 180° turn back to the airfield the glider flew again
with an IAS of 100km/h but now with a tailwind of 25km/h, then its
speed relative to the ground is 125km/h. This means that during the
180° turn the glider had to be accellerated from 75km/h to 125km/h
relative to the ground.
For a banking angle of 45° and an IAS of 100km/h one finds from simple
mathematics that a 180° turn takes 8.9 secs when properly flown. The
forward accellaration of the glider during the 180° turn must then be
(125-75)/(3.6)/8.9=1.56m/s2 to come out at the same speed of 100km/h.
Suppose the mass of the glider (including the pilot) is 650kg, then
the force needed to accelarate the glider with 1.56m/s2 is 650x1.56 =
1014kgm/s2 or 1014N.
Where does this force come from. Indeed, from gravity. The glider must
pitch down to keep its IAS up. With a glider mass of 650kg, its weight
is 650x9.8=6370N. The pitch down angle must then be
arc(sin)1014/6370=9.2°. Add to this a normal glide angle of 1.4° (for
a glide ratio of 40), then the total pitch down angle during the 180°
turn of the DG500 should have been over 10°.
If the pilot does not move his stick quite a bit forward to achieve
this relative large pitch angle, the glider will loose its IAS, then
stall and spin. This looks to me what happened unfortunately with the
DG500 at Magdenburg.
Karel, NL
Old February 8th 04, 01:05 PM
tango4
Looking at the windsock I'd say there was also a considerable wind gradient.
The aircraft had one wingtip within 1 span of the ground and the other a
good 15 to 20 m above that.
This little clip really is a classic, so many things wrong in one 10 second
period!
Ian
"ir. K.P. Termaat" wrote in message
om...
the DG500.
Karel, NL
Old February 8th 04, 06:19 PM
Shawn Curry
the DG500.
Karel, NL
You need to have a good long talk with your instructor.
Old February 9th 04, 07:01 PM
ir. K.P. Termaat
Hi Shawn.
Since 1978 I am an instructor myself and teach aerodynamics to new
pilots as
well as new instructors since then. Next month we will have a
discussion in
our instructor's team on the matter of spinning and especially on how
to
avoid this killing phenomenon when happening at low altitude. If you
don't
understand my wordings please let me know; I am quite willing to
elucidate
on what I sayd. If you think my interpretation of the Magdenburg crash
with the DG500 is wrong please explain, I am quite willing to listen
to better theories about this. Something like "you need .... " doesn't
help much Shawn.
Karel, NL
Shawn Curry wrote in message hlink.net...
the DG500.
Karel, NL
Old February 9th 04, 11:05 PM
I'm certainly not speaking for Shawn, but what feels wrong-headed to
me about your description of acceleration RELATIVE TO THE GROUND,
and the need then to find forces to account for that apparent
acceleration, is that, in my view of things, no such acceleration of
the glider is occurring at all and thus no forces need be conjured.
The changes in groundspeed are not accompanied by changes in airspeed
and are a result of the movement over the ground of the air in which
the glider is turning.
On 9 Feb 2004 11:01:42 -0800, (ir. K.P. Termaat) wrote:
Hi Shawn.
pilots as
discussion in
to
don't
elucidate
help much Shawn.
Karel, NL
the DG500.
Karel, NL
Old February 9th 04, 11:26 PM
Shawn Curry
the DG500.
Karel, NL
Hi Shawn.
pilots as
discussion in
to
don't
elucidate
help much Shawn.
Karel, NL
Your description of the situation sounded naive. If you were
considering wind shear (decreasing wind velocity with altitude) you
didn't note that. As Robert noted in another response a turn is a turn,
as far as the aircraft is concerned, whether at 80 meters or 2000 unless
the wind changes during the turn.
I assumed you did not understand this, and figured a "usenet education"
is a poor (perhaps deadly) substitute for time spent with an instructor.
Thus my response.
Shawn
Old February 8th 04, 01:08 PM
Z Goudie
caused the spin of
the DG500.
and had a headwind
is 75km/h. If
glider flew again
then its
that during the
to 125km/h
That old red herring again!
The glider is flying in an airmass which is moving
over the ground at a constant rate. No additional
acceleration is required apart from that normally needed
in a turn to supply the turning force.
There may be some effect caused by descending/putting
the lower wing down through any wind gradient but this
actually improves the situation as the air is moving
'away' from the path of the glider more slowly and
will consequently cause some increase in airspeed.
(You can try the opposite of that effect by pulling
up from a downwind racing finish through a strong wind
gradient; watch the airspeed decay at an alarming rate).
The biggest problem is that the apparent speed over
the ground in say a 15kt wind jumps by 30kts and results
in people trying to reduce the ground rush by raising
the nose with no reference to the ASI.
Old February 9th 04, 02:17 PM
Rich Carr
There is also the potential of poor turn coordination caused by the
perceptual changes that occur when maneuvering below pivotal altitude,
although that didn't appear to be the case in the video. The
suddenness of the departure was a bit surprising, but it seemed to be
triggered by the opening of the spoilers rather than by any obvious
lack of coordination.
- Rich Carr
Old February 10th 04, 04:07 PM
ir. K.P. Termaat
Z Goudie wrote in message ...
We have very nice herring in NL, not red however.
Indeed I made a wrong supposition in my calculation of a 10° pitch
angle required during the turn back curve of the DG500 to the
airfield.
A steeper pitch angle then the pilot obviously applied would have
helped him a lot though to keep the glider from stalling and spinning
in.
The comment of one of our aerobatic pilots is that the DG-pilot flew
to slow in the last part of the flight and a full spin with crossed
controls (right rudder and left stick) evolved. The air may have been
very turbulent in the lower layer because of several obstructions on
the field.
Karel
SR22 Spin Recovery gwengler Piloting 9 September 24th 04 07:31 AM
Spin Training Captain Wubba Piloting 25 April 12th 04 02:11 PM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 01:27 PM
