Many descriptions have been posted here in several threads on spinning
over the last couple of weeks and I have found all of them to be fascinating. I've been prompted to think through again my own understanding of the stall and the spin in gliders. One description that has been strongly asserted in several threads is that there is a difference in angle of attack on the two wings on an aircraft in a descending turn AND that the difference in AOA is due to the slower horizontal speed of the inside wing as it traverses a shorter circle than does the outside wing in the descending turn. The slower speed of the inside wing thus coinsides with a higher AOA on the inside wing than is experienced by the outside wing. This of course has implications for which wing may reach stall AOA first. I am only a pilot and have no training in aerodynamics whatsoever. For what it's worth (not much probably), I find the above explanation of the cause of different AOA on the left and right wings of an aircraft in a descending turn to be easily understandable and very likely accurate, but incomplete. Many years ago I read in Sammy Mason's book Stalls, Spins and Safety, an additional description of the AOA on the wings of an aircraft in ascending and descending turns. I find that his description is persuasive and illunimating and contributes to a more complete understanding of the stall and spin. Here is a short quote from Sammy Mason's book: "During a level, coordinated turn, once the bank is established, the airplane will continue to turn about the yaw axis and pitch upward about the pitch axis. It will not be rolling about the roll axis. When a stall is encountered in a level turn, the reaction will normally be very little different than during a wings-level stall.." "During a descending turn, or spiral, in addition to pitch and yaw, the airplane will be rolling about the roll axis in the direction of the turn. As the airplane rolls, it induces an upflow of air into the descending wing. This results in the descending wing having the greatest angle of attack. If a stall is encountered, the airplane will likely roll into the turn." pp.40-41. Sammy Mason goes on to describe the opposite differences in AOA on the two wings of an aircraft in an ascending turn. In a descending turn are both wings going down? Of course they are, relative to an outside frame of reference and assuming the rate of aircraft descent is greater than the rate of roll (or however one describes the rate at which wings are going around in a roll). From the frame of reference of the aircraft are the two wings proceeding in opposite rotational directions? Sammy Mason's description of the aircraft rolling about its roll axis in a descending turn describes just such a difference -- and its contribution to the differing AOA on the two wings. This suggests that the difference in AOA on the two wings is not due only to their differences in horizontal speed in their differing size circles. Your milage may vary, of course, and each pilot likely benefits from some image of what is happening to an aircraft in a stall and spin. In my view, Sammy Mason's descriptions add additional insights for me to the nature of stalls and spins. Sammy Mason's flying career is described in the book as having begun in the 1930's, and included WWII, and then working with C.L."Kelly" Johnson of the Lockheed "Skunkworks". He was a jet aircraft test pilot for Lockheed and became Lockheed's authority on stall/spin testing. |
yaw, the airplane will be rolling about the roll axis in the direction of the turn. As the airplane rolls, it induces an upflow of air into the descending wing. This results in the descending wing having the greatest angle of attack. If a stall is encountered, the airplane will likely roll into the turn." pp.40-41. I'm having some trouble visualizing this. Is it possible that Sammy has posited a reference frame that looks only at AOA, ignoring bank and relative speed across the span? If I wanted to keep my model and my math simple, rather than describing the turn as a hollowed cylinder with inner- and outer-walls transcribed by the wings during descent, I could look solely at AOA, in which case the model of a turn would look similar to, if not exactly like, a slow rolling motion. Our reference frame has no horizon. In fact, it is purely scalar. AOA simply has a range of values across the wing. If this is the case, I can see how it would be useful for a snapshot -- such as just prior to the stall, but confusing when describing the dynamics of a turn in its fuller context. This is a kind of partial differential: an alternative way of describing a turn, but only predicts outcomes based on AOA. Good for analysis in a narrow band... Certainly counterproductive if integrated haphazardly into a more intuitive three axis model. So it goes like this maybe. The observed effect of constant sink rate and differential airspeed across the span of a turning airfoil when described in terms of differential AOA can be likened to the rolling motion produced by the ailerons in level flight. The downward moving wing, during the rolling motion, exhibits an increasingly higher AOA as you go out the span (ignoring that part of the wing with deflected aileron) than the rising wing, which shows a descending value of AOA with span. Thus, during a descending spiral, if the airfoil were to stall, this "psuedo-rolling moment" could be said to contribute to the wing drop typically experiended during a turning stall. I'm not sure I see how this changes with level flight or a climb. After all, if we establish the longitudinal axis as the basis for measurement, up or down with respect to the ground shouldn't matter. This seems to me a more useful short cut for the engineer than the aviator. Just remember, similitude is not exact. But it is an interesting concept nonetheless. Maybe someone could do the math for change in AOA for a 15M glider traveling at 100kph and rolling at a rate of 30 degrees per second, ignoring the ailerons, of course. Wow, that was fun. Thanks. Chris O'C |
Just think about the relative air flow in relation
to all the aero dynamic surfaces. It is then quite clear. Remember that in a spin there is pitch, roll and yaw so the raf changes. Think about what happens when it reaches the aerodynamic limit of the relevant surface. If it makes it easier just think about the raf in a straight stall first where no attempt at recovery is made. What happens? Then add rolling and yawing. At 22:42 10 February 2004, Chris Ocallaghan wrote: 'During a descending turn, or spiral, in addition to pitch and yaw, the airplane will be rolling about the roll axis in the direction of the turn. As the airplane rolls, it induces an upflow of air into the descending wing. This results in the descending wing having the greatest angle of attack. If a stall is encountered, the airplane will likely roll into the turn.' pp.40-41. I'm having some trouble visualizing this. Is it possible that Sammy has posited a reference frame that looks only at AOA, ignoring bank and relative speed across the span? If I wanted to keep my model and my math simple, rather than describing the turn as a hollowed cylinder with inner- and outer-walls transcribed by the wings during descent, I could look solely at AOA, in which case the model of a turn would look similar to, if not exactly like, a slow rolling motion. Our reference frame has no horizon. In fact, it is purely scalar. AOA simply has a range of values across the wing. If this is the case, I can see how it would be useful for a snapshot -- such as just prior to the stall, but confusing when describing the dynamics of a turn in its fuller context. This is a kind of partial differential: an alternative way of describing a turn, but only predicts outcomes based on AOA. Good for analysis in a narrow band... Certainly counterproductive if integrated haphazardly into a more intuitive three axis model. So it goes like this maybe. The observed effect of constant sink rate and differential airspeed across the span of a turning airfoil when described in terms of differential AOA can be likened to the rolling motion produced by the ailerons in level flight. The downward moving wing, during the rolling motion, exhibits an increasingly higher AOA as you go out the span (ignoring that part of the wing with deflected aileron) than the rising wing, which shows a descending value of AOA with span. Thus, during a descending spiral, if the airfoil were to stall, this 'psuedo-rolling moment' could be said to contribute to the wing drop typically experiended during a turning stall. I'm not sure I see how this changes with level flight or a climb. After all, if we establish the longitudinal axis as the basis for measurement, up or down with respect to the ground shouldn't matter. This seems to me a more useful short cut for the engineer than the aviator. Just remember, similitude is not exact. But it is an interesting concept nonetheless. Maybe someone could do the math for change in AOA for a 15M glider traveling at 100kph and rolling at a rate of 30 degrees per second, ignoring the ailerons, of course. Wow, that was fun. Thanks. Chris O'C |
Where I'm having trouble is seeing why there is any difference between
sinking, level, and climbing. From the point of view of raf, these should all be same. I choose to set my longitudinal reference based on the fuselage, not the horizon. If I do this, the aircraft always has a sink rate, not relative to the ground, but relative to the projection of the fuselage centerline at a given time (T=0) and proportional to the angle of attack -- that is, the rate at which the aircraft "falls" away from this projection (dT). Since it shouldn't matter which reference frame I use to make my observations, my confusion arises with the suggestion that the pseudo-rolling moment reverses beetween sink and climb. As for the approach, it remains interesting. To help my understanding, I've been using a train. Imagine a sensor on a rail that only measures side force. A train going straight on level ground registers zero side force. As the rail bends though, the sensor would measure a side force proportional to the train's acceleration. However, a straight rail with a side pitch would register a force as well. When viewed this way, a train rolling on a straight rail with several degrees of side inclination could be said to be "turning." Of course, it isn't. Unlike a curved rail, no additional power is needed to maintain speed. (Note the limitations of my reference frame. I only see side force on the rail, not total force.) It's not exactly analogous, but it's a step in the right direction. |
Chris OCallaghan skrev den 20 Feb 2004 05:53:14
-0800: Where I'm having trouble is seeing why there is any difference between sinking, level, and climbing. From the point of view of raf, these should all be same. I choose to set my longitudinal reference based on the fuselage, not the horizon. If I do this, the aircraft always has a sink rate, not relative to the ground, but relative to the projection of the fuselage centerline at a given time (T=0) and proportional to the angle of attack -- that is, the rate at which the aircraft "falls" away from this projection (dT). Since it shouldn't matter which reference frame I use to make my observations, my confusion arises with the suggestion that the pseudo-rolling moment reverses beetween sink and climb. When turning, the only rotation is about the vertical (earth-fixed) axis. Then take it to the extreme case of diving straight down (here defined as the longitudinal axis vertical). In that situation, all of the rotation will be around the longitudinal axis of the aircraft - i e roll. In turning flight with the fuselage level (longitudinal axis horizontal), all of the rotation will be around the yaw axis of the aircraft. In all the cases between these two extremes, part of the rotation will be around both the longitudinal and the yaw axis of the aircraft. The bank will mean some of it is around the pitch axis as well, which is a problem to be considered in, among other things, turn rate gyros. As for the approach, it remains interesting. To help my understanding, I've been using a train. Imagine a sensor on a rail that only measures side force. A train going straight on level ground registers zero side force. As the rail bends though, the sensor would measure a side force proportional to the train's acceleration. However, a straight rail with a side pitch would register a force as well. When viewed this way, a train rolling on a straight rail with several degrees of side inclination could be said to be "turning." Of course, it isn't. Unlike a curved rail, no additional power is needed to maintain speed. The equivalent to a banked railway track would be straight slipping flight. And in both cases, the normal force on the rail (the lift) will have to be larger if it is to keep the train/aircraft from accelerating downwards, and there will have to be a lateral (train/aircraft frame of reference) force as well, assuming that there are no other forces perpendicular to the direction of travel than the normal and lateral (to the wings/rail). Both these forces will add friction/induced drag and require additional power. Cheers, Fred |
Then take it to the extreme case of diving straight down (here defined as the longitudinal axis vertical). In that situation, all of the rotation will be around the longitudinal axis of the aircraft - i e roll. Remember, we're talking about Sammy's model. When diving there is no rotation, about the longitudinal or yaw axis. (There is no aileron input.) Same thing going straight up. The orientation of the lift vector (positve values) would rotate the glider about the lateral axis. In turning flight with the fuselage level (longitudinal axis horizontal), all of the rotation will be around the yaw axis of the aircraft. Again, not according to the model as I understand it. If the aircraft is sinking, the one wingtip is travelling faster than the other, and therefore there is a difference in angle of attack, and in model, this is accounted for as a roll. I'm waiting for the book to show up, but I suspect that we're all taking this too literally, trying to justify it in the real world. As for the train, the only force of importance is the side force on the rail. There is no friction (or better said, it is unabserved). The point is that a leaning train looks like a turning train to a sensor that simply measures force acting in a single direction. |
In article , Todd Pattist
writes: The first time I tried this in my Ventus, I was flying along sideways with full rudder and level wings and heard a loud "BANG!" After my heart stopped thumping, I figured out that one of the gear doors had sucked open into the sideways airflow. :-) That happened to me once.Scared the hell out of me. Another scarey bang was in a Puchacz on the winch when the cover, which is over the rear seat adjustment bar, could not have been secure and flicked down and hit the side of the fuselage. This was about six inches from my left ear and was magnified by the megaphone shape of the hollow fuselage. A third was in a Bocian, also on a winch when the rear canopy, which slid backwards on rails, came unlocked, slid back and hit the rear stop. This one was probably the worst because, a) we were about 100ft and starting to rotate into full climb, b) in addtion to the "bang" as it hit the stop, there was a huge, disorientating rush of air, and c) it took a while to work out what had happened, take over from the pupil, (only his second or third winch take off) and get the nose down etc. However, one of the the worst I know of these type of incidents was a pilot at my club who owned a Carmem and lost the complete canopy at about 4000ft agl. It departing it caught his skull which bled profusely and a combination of blood and the wind causing his eyes to run, made it extremely hard for him to see. Once he worked out what had happened, his big concern was what else the canopy had hit, tailplane for example. He considered baling out but, having checked all controls decided to ride it down to the nearest field, successfully I am pleased to say. The farmers reaction to this bllod covered figure arriving at his door was, I understand, unprintable. Needlesss to say, all of the above (except U/c doors) occurred either as a result of poor take off checks or mechanical faults. Barney UK |
| Thread Tools | |
| Display Modes | |
| Puchaz Spinning thread that might be of interest in light of the recent accident. | Al | Soaring | 134 | February 9th 04 04:44 PM |
| Stalling and spinning generally | Ian Strachan | Soaring | 0 | February 1st 04 09:40 PM |
| Spinning or the after effects of stalling. | Dave Martin | Soaring | 0 | January 30th 04 12:24 AM |
| Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 02:35 AM |
| Dynamic stalling of delta wing a/c (wrt MiG 21) | drake | Military Aviation | 12 | August 26th 03 07:37 PM |
