1-34 Rudder
Old February 15th 04, 04:11 PM
Eric Greenwell
Roy Bourgeois wrote:
I think that the difference is that my original post focused on "rudder
response" and others are focusing on "yaw stability" - which are different
and somewhat opposite. The 1-34 is quite stabile in yaw but as Doug noted
in his first post, it's response (time to desired effect) to your stepping
on the pedal is pretty bad.
It sounds like you are saying it has plenty of rudder power, but the
response is slow. So...
If you are flying straight and level, then step on the rudder (no
ailerons), are you saying it is slower to yaw than most/many gliders
(i.e., slow response time)? But if you are patient (wait 2-3 seconds
more than you do in most/many gliders) it will have plenty of yaw (i.e.,
plenty of power)?
I flew several 1-34s about 250 hours (and
still occasionally). It doesn't have a problem with adverse yaw in a
turn.
No glider has problem with adverse yaw once it's settled in a turn,
because very little aileron is required to hold a turn. It's always
during the turn entry/exit that adverse yaw is a problem.
But when you step on the pedal (say, to begin a slip) - nothing much
happens (compared to other gliders). I was suggesting to Doug (and still
believe) that the lack of rudder "response" is a function of the
extraordinary fuselage length and that he would need a much bigger rudder
to solve that problem.
The kind of response you need when entering a turn is force to
counteract the adverse yaw, not a rapid change in direction. During the
initial turn entry, the fuselage mainly rolls, not yaws.
Your concern about the length of the fuselage would be appropriate for
aerobatic maneuvers that involve rapid yawing, which is why aerobatic
aircraft typically are small. A Pitts is a good example of this. Short
wings and tails reduce the moment of inertia and the changes in angle of
attack due to motion about the axes, allowing rapid response. A glider
turn entry isn't rapid in yaw, so these effects aren't important, but
rudder force is, and a long boom makes it more effective.
Now - if somebody will show me how to make my Nimbus 3 do ANYTHING
responsively - I'll be eternally grateful
Can't help you there, but at the convention, it was interesting
listening to Dick Butler talk about cutting off the tail of his ASW 22
so he could graft on a longer boom and a new fin (and maybe new rudder -
I'm not sure about that) to improve the handling with the longer wing
tips he also installed. JJ might be able to help you, as a long time
Nimbus 3 owner, and I think he also has replaced a tail or two on them.
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Old February 15th 04, 07:44 PM
Dave Nadler YO
Roy - beg to differ - the 1-34 has inadequate yaw stability.
If you hold neutral rudder at moderate cruise speed in any
turbulence, it often does a very notable cha-cha in yaw.
Not as bad as some V-tail Bonanzas, but to me uncomfortable.
OK, find cha-cha in your textbooks...
Best Regards, Dave
Roy Bourgeois wrote in message ...
on the pedal is pretty bad. I flew several 1-34s about 250 hours (and
turn. But when you step on the pedal (say, to begin a slip) - nothing much
Roy
Old February 16th 04, 03:35 AM
Andy Blackburn
This is a pretty amusing conversation from an engineering
point of view - lots of opinions and a smattering of
facts - some of them even true!
Vertical tail volume is in fact the appropriate design
paramerter for determining static directional stability
for any aircraft. A longer moment arm and/or a larger
surface area (fin plus rudder) will increase stability.
Gliders have long tail booms because you get a better
drag tradeoff by making the boom longer than by making
the fin bigger. In addition, gilders generally need
more tail volume because their high aspect ratios generate
considerable adverse yaw. I have not looked at the
Genesis planform in detail, but I suspect (as has been
already observed) that it has a longer tail arm than
at first appears because of the forward sweep and wide
root chord. Even so, that vertical stab looks pretty
puny so I'd be curious to hear if it has the 'cha-chas'.
In terms of yaw authority (responsiveness), the size
of the rudder relative to the tail volume and yawing
inertia of the aircraft is the relevant attribute to
consider (airfoil matters too). By deflecting the rudder
you generate a sideways lift vector that creates a
yawing moment proportional to the tail arm. This moment
has to overcome the yawing inertia of the aircraft
to yield a yaw rate. The yaw rate (plus any dihedral)
will pickup the outside wing, which is why you often
lead a bit with rudder when initiating a turn, or to
pick up the inside wing when recovering from a turning
stall.
I flew a 1-34 for a few years before transitioning
to glass long ago. I don't particularly remember it
being underdamped in yaw, but I do remember it being
slow to enter a turn. I suspect the issue is that
it has a relatively small rudder and a lot of yaw inertia
(those wings are HEAVY). I also remember the ailerons
being quite stiff. I built up good biceps by the end
of the season.
in any
yaw.
Best Regards, Dave
Roy Bourgeois wrote in message news:...
focused on 'rudder
response' and others are focusing on 'yaw stability'
adverse yaw in a
to Doug (and still
believe) that the lack of rudder 'response' is a function
of the
3 do ANYTHING
Roy
Old February 16th 04, 04:36 AM
Bill Daniels
"Andy Blackburn" wrote in message
It doesn't.
Bill Daniels
Air Bus 300 crash in NY now blamed on co-pilot's improper use of rudder Corky Scott Piloting 30 October 28th 04 04:10 AM
B2 Split Rudder Emilio Military Aviation 8 April 12th 04 10:43 AM
P-51 Rudder Aerodynamics Hawkeye Hughes Home Built 1 March 15th 04 09:24 AM
A lesson learned - Invisible rider with foot on right rudder Dave Butler Piloting 2 October 16th 03 09:58 PM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
