#21
On Monday, July 24, 2017 at 10:22:43 AM UTC-7, JS wrote:
Consider cutting a hole in the bottom of the tail (discovering that there is already a wheel well in the LS6) and installing a tail wheel... If your LS6 is Experimental, I have a fender and external fairing that fits if it turns out that it isn't already in there. --Bob K. |
On Tuesday, July 25, 2017 at 9:40:51 PM UTC-4, Bob Kuykendall wrote:
On Monday, July 24, 2017 at 10:22:43 AM UTC-7, JS wrote: Consider cutting a hole in the bottom of the tail (discovering that there is already a wheel well in the LS6) and installing a tail wheel... If your LS6 is Experimental, I have a fender and external fairing that fits if it turns out that it isn't already in there. --Bob K. The inner fender is part of LS-6 aft construction, even when skid is installed, based on the one I worked on. It would require the factory drawing to duplicate the mounting of the axle bolt. FWIW UH |
On Tuesday, July 25, 2017 at 7:24:57 AM UTC-4, wrote:
On Tuesday, July 25, 2017 at 6:49:44 AM UTC-4, Tango Eight wrote: On Tuesday, July 25, 2017 at 2:43:24 AM UTC-4, POPS wrote: Permanent, not coming off, done. And so how does it go when you need to remove the skid, for some reason? best, Evan I've never used 5200 but know boatbuilders don't like it for many applications because it is unpleasant to undo for repairs. The glue on skid idea was always kinda dumb. But it seems *really* dumb to glue the thing on in some fashion that's going to require a sawzall and disk grinder to remove. Contact cement works. The thicker, gap filling solvent based adhesives (the "goo" and "goop" products) work better, are more forgiving prep wise. These can be worried loose when needed, without destroying the skid. It's not necessary to overthink this. best, Evan |
On Wednesday, July 26, 2017 at 8:16:34 AM UTC-7, Tango Eight wrote:
...going to require a sawzall and disk grinder to remove... Mmmmm... Sawzall... |
Like a tuna .... fillet it off with a NEW razor blade, the ones used in utility knifes. Easy. Liquid vise grips, vise grips and epoxy, nothing more needed in this world.
Looking for Wedekind sleeves and tailskid with wheel... | [email protected] | Soaring | 6 | January 30th 15 02:42 AM |
Keep the rubber side down! | Waveguru | Soaring | 1 | September 24th 12 04:57 AM |
Gluing rubber pieces | [email protected] | Home Built | 16 | June 2nd 09 05:32 AM |
Rubber stamp??? | Tri-Pacer | Owning | 13 | January 28th 06 07:04 PM |
Rubber Stamp ??? | Tri-Pacer | Home Built | 7 | January 26th 06 01:34 PM |
