air extractor for asw19 and asw20
Old October 21st 17, 04:02 AM posted to rec.aviation.soaring
Darryl Ramm
Default air extractor for asw19 and asw20
Hopefully he had some documentation of that, evidence of construction or sale... which could invalidate the Jonkers patent.
Old October 21st 17, 07:58 AM posted to rec.aviation.soaring
krasw
Ok, probably all similarities are purely coincidental then.
But regarding air extractors, I find it surprising that mainly US audience of ras does not mention Will Schuemann's work, predating JS or DG, what 35-40 years?
Old October 24th 17, 05:53 PM posted to rec.aviation.soaring
Wil was certainly a pioneer. IIRC, his 301 Libelle captured ventilation air using the leading edges of the gear doors as a scoop (the belly just ahead of the doors was flattened a bit so the doors protruded--probably not the best idea in the event of a gear up landing).
Thus pressurized, the gear box fed ventilation air into the cockpit through two outlets over the shoulders of the pilot. I don't think these could be modulated, at least initially, which was a problem when it got cold.
Air exited the glider at the base of the rudder through an expanded opening and "splitter" at the bottom of the rudder based on Wil's experiments to find the ideal low-pressure location. Jim Indrebo had a really nice version of that exit vent on his 301 in the early 80s.
Chip Bearden
Old October 24th 17, 06:35 PM posted to rec.aviation.soaring
JS[_5_]
Chip Bearden
The exit vent in Dick Brandt's Nimbus 3 is at the bottom of the rudder like that. Moved a lot of air.
It was a nice mod to have in Australia.
Old October 24th 17, 07:55 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Chip Bearden
A subsequent owner used Nerf balls to plug the air vents when not needed. A red one on the left, and a green one on the right. Got a heck of a scare one day when on a fast final glide, they both blew out into the cockpit at the same time!
Steve Leonard
ASW19 for sale [email protected] Soaring 2 September 12th 16 10:07 PM
ASW19 Inner Tube [email protected] Soaring 1 September 21st 15 03:54 PM
Air extractor for sustainer and motor gliders? [email protected] Soaring 12 August 26th 15 07:41 AM
Air Extractor: Better than a Plastic Jesus? [email protected] Soaring 23 December 18th 13 08:48 AM
asw19 airbrake kit steve[_2_] Soaring 2 April 7th 11 08:32 PM
