Cobra Trailer lights converting to 4-way flat--Help
Old October 26th 17, 04:49 PM posted to rec.aviation.soaring
Retting
Default Cobra Trailer lights converting to 4-way flat--Help
Got a new Cobra with a 7-blade. My vehicles use 4-way flat.
I was initially going to cut and install a 4way on the trailer, but hate to cut brand new plus thought if I install a combi on the vehicle I could tow others if a need arise. So, I find a vehicle combi at Lowe's, connect everything and ....only the left side works.
Tips, ideas, hammer size?
Thanks
R
Old October 26th 17, 04:53 PM posted to rec.aviation.soaring
Retting
Email direct if you like...
R
Old October 26th 17, 05:10 PM posted to rec.aviation.soaring
JS[_5_]
Hook up both the black and brown wires to your vehicle's tail lights.
Cobra Trailer wiring:
COLOR CODE: USE:
White Ground
Black / Brown Tail / Side
Red Brake
Yellow Left Turn
Green Right Turn
Blue Aux
I just wired a new car which had the lousy American standard tail lights to work with International standard lighting, as used in the Cobra. Used a Curt 2- to 3-wire converter available from E-Trailer.com. The trailer lighting is now fully functional.
http://www.curtmfg.com/part/56196
Old October 26th 17, 05:37 PM posted to rec.aviation.soaring
Retting
So, I need to power both Black/Brown blades on the 7blade via the Brown on my vehicle combi to power the trailer lights?
Using a jumper.
R
Old October 26th 17, 05:41 PM posted to rec.aviation.soaring
Retting
Plus, no red wire on the vehicle combi.
R
Old October 26th 17, 05:45 PM posted to rec.aviation.soaring
JS[_5_]
R
Correct. The Curt box provides the red (brake) wire out.
Old October 26th 17, 06:16 PM posted to rec.aviation.soaring
Retting
So, forget jumper...I put the Black/Brown together on the Cobra blade that is powered by the Brown wire on the car blade.
Now I have lights, but select left or right blinker operates both Cobra blinker.
R
Old October 26th 17, 06:18 PM posted to rec.aviation.soaring
Retting
Thank you JS
The Cobra plug has two red wires to the center post...(?)
Old October 26th 17, 06:22 PM posted to rec.aviation.soaring
Retting
I don't have time to order a Curt Box....gotta pull tomorrow.
If I can get the brake lights working, I can put on the flashers before turning.
Then fix correct it at home.
R
Old October 27th 17, 01:25 AM posted to rec.aviation.soaring
“inquiring minds want to know” does the new trailer have something new in it?
Cobra trailer tail lights replacement? John Bojack J4 Soaring 20 November 30th 16 12:26 AM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
looking for used Cobra trailer Brad[_2_] Soaring 3 July 1st 11 02:58 AM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
Cobra Trailer [email protected] Soaring 22 December 7th 06 11:38 PM
