#21
Hartley, I reread your post and perhaps I did not address your concerns
completely. My installation was simple. One hole in the fiberglass seat pan as high up as practical. I used a very short large AN bolt (~5/16th). This size bolt was gross overkill strength and weight wise but I did not have a suitable bushing. On the back side I used an AN 970 large area washer and a NA365 nut. On the front was the head of the bolt and the triangular steel belt fitting. When this is good and tight the shear and bearing load on the seat pan is spread out to the big washer size area. I'm sure in my case a good load was transferred to the pan, Not much way to guess the value. Too many variables. Months later when the insurance company sold the glider I offered to help and got a chance to examine the glider. I saw no localized damage at the strap attach point. Hope this helps, Ed Byars "Ed Byars" wrote in message hlink.net... Hi Hartley, The crotch strap remained intact after doing it's job. I'm just lucky that no serious permanent damage was done to my sensitive genitals. I like the ideas presented relative to a six point arrangement. This sure sounds safer, but any sensible arrangement would be virtually impossible to get by the LBA/FAA. It's a shame that it's not likely that any competent person or group would/will develop and offer for sale such a glider system. Our legal system just would not allow it. Maybe such a system designed for another more numerous vehicle, auto probably, might be available for Experimental licensed gliders. From an overall safety standpoint it may be just as important to assure that any belting system is quickly free of the body with one quick push or twist. We must not forget that provision for a quick cockpit egress may be just as important. I'm pleased that this thread seems to have made a few of us review our restraint system and think about possible improvement. Ed Byars "HL Falbaum" wrote in message news ![]() ED Glad you're doing well. I am curious--did the crotch strap attach point fail, or was it intact after the crash? If it did fail, at what estimated load did that occur? Pehaps it does not have to hold the entire load to be effective--your thoughts? Thanks Hartley Falbaum "Ed Byars" wrote in message hlink.net... I sent the following to our magazine nine months ago and didn't receive an acknowledgement or receipt. I guess it was not suitable for them so I thought I would share it with ras to maybe provoke some safety discussion. efb10-11-03-rev.6-5-04 You may be interested in my latest crotch strap experience. I'm still analyzing my June 2003 accident and the cause. More later on this. The role of the crotch strap is significant and worthy of mention. The last half dozen gliders I've had I added a crotch strap (usually available from Wings & Wheels), which easily clicks into the bottom, front or 5th slot of the standard Gadringer belt hardware. I secure the other end, which terminates with the belt into a triangular link, with a quarter inch hole that I bolt to the seat pan with a large "wood" washer behind the seat pan. My gliders are Experimental category so this is legal. I always heard that the main purpose of a crotch strap was to keep the lap belt across the upper thighs and prevent it sliding up to the stomach area. I have since learned better. It of course depends on the direction of the accident loads and the direction of the inertia of the body as to how all restraint straps come into play. Many glider accidents involve "dropping in" vertically wherein the tailbone (in the L-1, L-2 area) or higher are damaged so the belts don't help much. You seldom see accidents with lap belt overload, but it happens. I have a sad memory of helping remove a dead friend from an inverted Ventus cockpit where the lap belts on both sides had pulled lose from the seat pan. Fortunately rare but it happens. In my "incident" the nose of the glider hit hard ground at about a 60 plus degree angle. The "load" was about along the longitudinal axis of the glider. Since in our modern gliders (ASW-28 in my case) we recline (sit supine), the inertia of my body was toward the nose with only the crotch strap to resist. Actually Waibel designed the seat pan to take some of this forward load against the bottom of the thighs. In this seating the knees are bent more upward. The nose of the glider (along with my feet) was crushed in a calculated energy-absorbing manner. Thank you Gerhardt Waibel! I think his design and the crotch strap saved my knees. I was conscious and lucid until the helicopter dropped me off at the Medical College of Georgia Trauma Center. After that I really was not with it for a couple of weeks, but after that time I suddenly noticed that my groin area was still quite swollen. I realized that my crotch area had sustained a significant load and that all things considered had kept my body from moving more forward and no doubt helped minimize the leg/knee damage. I had no shoulder strap or lap belt marks or soreness. Since my guess is that a significant number of glider accidents impose loads and body reactions similar to mine, I recommend a crotch strap. Trying to distribute the load to the pelvic area by wearing an athletic "cup" may be good for some flights, but for some flights there are other disadvantages. Many contest pilots regularly wear a male external catheter and I don't think both would work. With just the crotch strap I always had to be careful that the strap was adjusted somewhat to the right, was not too tight, and did not interfere with the flow from the catheter that was to the left. I suggest reading Chip Bearden's posting which appeared in the rec.aviation.soaring newsgroup on Nov.20 1998 which outlines a more complex but better seat belt design. I hope this discussion will create more thought about glider accident safety. Ed Byars |
![]() "Robertmudd1u" wrote in message ... Tony Segal published a later article, which concluded six point harnesses were superior to five point harnesses. I'll bet they are but does this not provide two more straps to un-fasten when the need for a quick egress arises? Or am I missing something? Robert Mudd Hi Robert.... All the belts on my SCHROTH harness disconnect when the release is punched on the buckle/latch. The operating mechanism's are very user friendly and are meant to be operated by excited people wearing gloves who are probably on fire. I wouldn't be worried in the least about the possibility of entanglements. All connections happen at the buckle/latch, one place to hookup and/or release. ABSOLUTELY BULLETPROOF and completely reliable. If I were to hazard a guess, I'd bet that the motorsport standards exceed the TSO for aircraft belts by a very wide margin. Scott Correa |
Further to my posting yesterday I have identified the
6 point harness in our Std Cirrus as as Luke PRO6F designed for single seat race cars. See: http://www.lukeracing.co.uk/rec.php?cat=17 Flying with it today was the most comfortable I have ever been in a glider as I felt totally secured with the lap strap held low and no tendency to slide forward in the seat pan with the lap strap rising as happens in so many gliders. Even a deep seat pan like the front seat of a Duo comes nowhere near in terms to achieving that feeling. It may be non approved but I really don't care as the benefits for comfort and safety are so clear cut. John Galloway |
John Galloway wrote:
Further to my posting yesterday I have identified the 6 point harness in our Std Cirrus as as Luke PRO6F designed for single seat race cars. See: http://www.lukeracing.co.uk/rec.php?cat=17 Flying with it today was the most comfortable I have ever been in a glider as I felt totally secured with the lap strap held low and no tendency to slide forward in the seat pan with the lap strap rising as happens in so many gliders. Even a deep seat pan like the front seat of a Duo comes nowhere near in terms to achieving that feeling. It may be non approved but I really don't care as the benefits for comfort and safety are so clear cut. John Galloway Could you double check and repost the URL. I am getting a blank page when I try to load the page. Thank-you. |
At 18:12 07 June 2004, Jc Cunningham wrote:
John Galloway wrote: Further to my posting yesterday I have identified the 6 point harness in our Std Cirrus as as Luke PRO6F designed for single seat race cars. See: http://www.lukeracing.co.uk/rec.php?cat=17 Flying with it today was the most comfortable I have ever been in a glider as I felt totally secured with the lap strap held low and no tendency to slide forward in the seat pan with the lap strap rising as happens in so many gliders. Even a deep seat pan like the front seat of a Duo comes nowhere near in terms to achieving that feeling. It may be non approved but I really don't care as the benefits for comfort and safety are so clear cut. John Galloway Could you double check and repost the URL. I am getting a blank page when I try to load the page. Thank-you. Thats odd because when I click on the link in your reply I go straight to it. If all else fails go to www.lukeracing.co.uk main site and click on the main link for 'race and rally safety harnesses' and then on 'Recommended' it will take to the page with a list of their harnesses. At the bottom is the link for PRO6F which looks identical to what is in our Std Cirrus except that instead of the bolt clips at the aircraft attachment end of the lap and shoulder straps we have normal glider buckles. Also the attachment points of the 2 thigh straps under our seat pan is a flat hook/clip instead of the bolt clip. Our central quick release buckle also looks to be an older less sleek model (our straps must be 12 years old but hardly used). Otherwise the picture gives a good idea of how the straps work - except that in practice the upper ends of the thigh loops pull at the lowest point of the shoulder straps and not a few inches higher as shown in the non-tensioned photographs. BTW it would be more difficult to attach the straps to a glider in which the lap straps attach to the seat pan rather than - as in the Std Cirrus - to a fuselage mounted metal point with a hole in the seat pan. This allows access to the mounting point for the lap straps from above the seat pan and for the thigh straps from beneath the seat pan. In other gliders I would envisage extra mounting points being required forward on the seat pan - perhaps bonded to the bottom of the seat pan under the upper thighs. John Galloway |
There are quite a few 6 point harness suppliers in the UK. Just google '6
point harness' Best price I found on the Luke 6 point PRO6F was £103 including VAT and shipping from www.rallynuts.com Ian |
"Kilo Charlie" wrote in message news
I remember Chip showing us his system years ago when flying at Mid Atlantic Soaring. My only concern is the same that was posted back when this all was discussed in 1998....that is if the belts will withstand the loads placed upon them at angles that they were not designed for when using the system described by Chip. Does anyone have any further info about this? You out there Chip? I know that he was concerned re the liability issue of non-approved applications in the past so may not be willing to discuss this publicly. I still use my 6-point harness, the details of which I discussed in a previous posting. Ed Byars' thoughtful email prompted me to look for it. Cut and paste this URL into your browser window. You may have to remove any hard carriage returns that have been inserted into the long address: http://groups.google.com/groups?q=gr...aol.com&rnum=1 My concern about modifying harnesses in a certified aircraft remains, not just for regulatory reasons but also because you're touching a piece of safety-related equipment that can carry high loads and has the potential to save your life and/or injure you, as Tim Mara has previously noted on this forum. As Casey notes, many 6-point installations (including mine) use the seat belt attach points to anchor the thigh straps, too. I agree this raises a question about loads being applied with different vectors than they were designed for. On the other hand, approximately 50% of the load on the extra harness straps is fed into the central buckle which has the shoulder harness restraining it, so it's not as bad as it first seems. I'd welcome any comments from more authoritative sources. In one update since I wrote the above email, several pilots have assured me that their 6-point harnesses work just as well as a 5-point harness (i.e., with a crotch strap) for turbulent ridge running. I was a little dubious but, having never used a crotch strap, I have no first-hand knowledge. Chip Bearden |
At 18:12 07 June 2004, Jc Cunningham wrote: John Galloway wrote: Further to my posting yesterday I have identified the 6 point harness in our Std Cirrus as as Luke PRO6F designed for single seat race cars. See: http://www.lukeracing.co.uk/rec.php?cat=17 Flying with it today was the most comfortable I have ever been in a glider as I felt totally secured with the lap strap held low and no tendency to slide forward in the seat pan with the lap strap rising as happens in so many gliders. Even a deep seat pan like the front seat of a Duo comes nowhere near in terms to achieving that feeling. It may be non approved but I really don't care as the benefits for comfort and safety are so clear cut. John Galloway Could you double check and repost the URL. I am getting a blank page when I try to load the page. Thank-you. Thats odd because when I click on the link in your reply I go straight to it. If all else fails go to www.lukeracing.co.uk main site and click on the main link for 'race and rally safety harnesses' and then on 'Recommended' it will take to the page with a list of their harnesses. At the bottom is the link for PRO6F which looks identical to what is in our Std Cirrus except that instead of the bolt clips at the aircraft attachment end of the lap and shoulder straps we have normal glider buckles. Also the attachment points of the 2 thigh straps under our seat pan is a flat hook/clip instead of the bolt clip. Our central quick release buckle also looks to be an older less sleek model (our straps must be 12 years old but hardly used). Otherwise the picture gives a good idea of how the straps work - except that in practice the upper ends of the thigh loops pull at the lowest point of the shoulder straps and not a few inches higher as shown in the non-tensioned photographs. BTW it would be more difficult to attach the straps to a glider in which the lap straps attach to the seat pan rather than - as in the Std Cirrus - to a fuselage mounted metal point with a hole in the seat pan. This allows access to the mounting point for the lap straps from above the seat pan and for the thigh straps from beneath the seat pan. In other gliders I would envisage extra mounting points being required forward on the seat pan - perhaps bonded to the bottom of the seat pan under the upper thighs. John Galloway It must have been my browser that was having a problem. I use Opera. When I used internet explorer it came up fine. |
#29
![]() -- Hartley Falbaum "Ed Byars" wrote in message hlink.net... Hartley, I reread your post and perhaps I did not address your concerns completely. My installation was simple. One hole in the fiberglass seat pan as high up as practical. I used a very short large AN bolt (~5/16th). This size bolt was gross overkill strength and weight wise but I did not have a suitable bushing. On the back side I used an AN 970 large area washer and a NA365 nut. On the front was the head of the bolt and the triangular steel belt fitting. When this is good and tight the shear and bearing load on the seat pan is spread out to the big washer size area. I'm sure in my case a good load was transferred to the pan, Not much way to guess the value. Too many variables. Months later when the insurance company sold the glider I offered to help and got a chance to examine the glider. I saw no localized damage at the strap attach point. Hope this helps, Ed Byars "Ed Byars" wrote in message hlink.net... Hi Hartley, The crotch strap remained intact after doing it's job. I'm just lucky that no serious permanent damage was done to my sensitive genitals. I like the ideas presented relative to a six point arrangement. This sure sounds safer, but any sensible arrangement would be virtually impossible to get by the LBA/FAA. It's a shame that it's not likely that any competent person or group would/will develop and offer for sale such a glider system. Our legal system just would not allow it. Maybe such a system designed for another more numerous vehicle, auto probably, might be available for Experimental licensed gliders. From an overall safety standpoint it may be just as important to assure that any belting system is quickly free of the body with one quick push or twist. We must not forget that provision for a quick cockpit egress may be just as important. I'm pleased that this thread seems to have made a few of us review our restraint system and think about possible improvement. Ed Byars "HL Falbaum" wrote in message news ![]() ED Glad you're doing well. I am curious--did the crotch strap attach point fail, or was it intact after the crash? If it did fail, at what estimated load did that occur? Pehaps it does not have to hold the entire load to be effective--your thoughts? Thanks Hartley Falbaum "Ed Byars" wrote in message hlink.net... I sent the following to our magazine nine months ago and didn't receive an acknowledgement or receipt. I guess it was not suitable for them so I thought I would share it with ras to maybe provoke some safety discussion. efb10-11-03-rev.6-5-04 You may be interested in my latest crotch strap experience. I'm still analyzing my June 2003 accident and the cause. More later on this. The role of the crotch strap is significant and worthy of mention. The last half dozen gliders I've had I added a crotch strap (usually available from Wings & Wheels), which easily clicks into the bottom, front or 5th slot of the standard Gadringer belt hardware. I secure the other end, which terminates with the belt into a triangular link, with a quarter inch hole that I bolt to the seat pan with a large "wood" washer behind the seat pan. My gliders are Experimental category so this is legal. I always heard that the main purpose of a crotch strap was to keep the lap belt across the upper thighs and prevent it sliding up to the stomach area. I have since learned better. It of course depends on the direction of the accident loads and the direction of the inertia of the body as to how all restraint straps come into play. Many glider accidents involve "dropping in" vertically wherein the tailbone (in the L-1, L-2 area) or higher are damaged so the belts don't help much. You seldom see accidents with lap belt overload, but it happens. I have a sad memory of helping remove a dead friend from an inverted Ventus cockpit where the lap belts on both sides had pulled lose from the seat pan. Fortunately rare but it happens. In my "incident" the nose of the glider hit hard ground at about a 60 plus degree angle. The "load" was about along the longitudinal axis of the glider. Since in our modern gliders (ASW-28 in my case) we recline (sit supine), the inertia of my body was toward the nose with only the crotch strap to resist. Actually Waibel designed the seat pan to take some of this forward load against the bottom of the thighs. In this seating the knees are bent more upward. The nose of the glider (along with my feet) was crushed in a calculated energy-absorbing manner. Thank you Gerhardt Waibel! I think his design and the crotch strap saved my knees. I was conscious and lucid until the helicopter dropped me off at the Medical College of Georgia Trauma Center. After that I really was not with it for a couple of weeks, but after that time I suddenly noticed that my groin area was still quite swollen. I realized that my crotch area had sustained a significant load and that all things considered had kept my body from moving more forward and no doubt helped minimize the leg/knee damage. I had no shoulder strap or lap belt marks or soreness. Since my guess is that a significant number of glider accidents impose loads and body reactions similar to mine, I recommend a crotch strap. Trying to distribute the load to the pelvic area by wearing an athletic "cup" may be good for some flights, but for some flights there are other disadvantages. Many contest pilots regularly wear a male external catheter and I don't think both would work. With just the crotch strap I always had to be careful that the strap was adjusted somewhat to the right, was not too tight, and did not interfere with the flow from the catheter that was to the left. I suggest reading Chip Bearden's posting which appeared in the rec.aviation.soaring newsgroup on Nov.20 1998 which outlines a more complex but better seat belt design. I hope this discussion will create more thought about glider accident safety. Ed Byars |
#30
That's the info. Thanks ED.
My thought was that if it failed at say half to 2/3 of the total potential load it would mitigate the damage to the " soft tissues " and restrain enough to help--the "progressive crush" idea. BTW - Motorcyclists and their accidents demonstrate that the genitalia are tougher than you may think---Thank the Lord! Thanks Again -- Hartley "KF" Falbaum USA "Ed Byars" wrote in message hlink.net... Hartley, I reread your post and perhaps I did not address your concerns completely. My installation was simple. One hole in the fiberglass seat pan as high up as practical. I used a very short large AN bolt (~5/16th). This size bolt was gross overkill strength and weight wise but I did not have a suitable bushing. On the back side I used an AN 970 large area washer and a NA365 nut. On the front was the head of the bolt and the triangular steel belt fitting. When this is good and tight the shear and bearing load on the seat pan is spread out to the big washer size area. I'm sure in my case a good load was transferred to the pan, Not much way to guess the value. Too many variables. Months later when the insurance company sold the glider I offered to help and got a chance to examine the glider. I saw no localized damage at the strap attach point. Hope this helps, Ed Byars "Ed Byars" wrote in message hlink.net... Hi Hartley, The crotch strap remained intact after doing it's job. I'm just lucky that no serious permanent damage was done to my sensitive genitals. I like the ideas presented relative to a six point arrangement. This sure sounds safer, but any sensible arrangement would be virtually impossible to get by the LBA/FAA. It's a shame that it's not likely that any competent person or group would/will develop and offer for sale such a glider system. Our legal system just would not allow it. Maybe such a system designed for another more numerous vehicle, auto probably, might be available for Experimental licensed gliders. From an overall safety standpoint it may be just as important to assure that any belting system is quickly free of the body with one quick push or twist. We must not forget that provision for a quick cockpit egress may be just as important. I'm pleased that this thread seems to have made a few of us review our restraint system and think about possible improvement. Ed Byars "HL Falbaum" wrote in message news ![]() ED Glad you're doing well. I am curious--did the crotch strap attach point fail, or was it intact after the crash? If it did fail, at what estimated load did that occur? Pehaps it does not have to hold the entire load to be effective--your thoughts? Thanks Hartley Falbaum "Ed Byars" wrote in message hlink.net... I sent the following to our magazine nine months ago and didn't receive an acknowledgement or receipt. I guess it was not suitable for them so I thought I would share it with ras to maybe provoke some safety discussion. efb10-11-03-rev.6-5-04 You may be interested in my latest crotch strap experience. I'm still analyzing my June 2003 accident and the cause. More later on this. The role of the crotch strap is significant and worthy of mention. The last half dozen gliders I've had I added a crotch strap (usually available from Wings & Wheels), which easily clicks into the bottom, front or 5th slot of the standard Gadringer belt hardware. I secure the other end, which terminates with the belt into a triangular link, with a quarter inch hole that I bolt to the seat pan with a large "wood" washer behind the seat pan. My gliders are Experimental category so this is legal. I always heard that the main purpose of a crotch strap was to keep the lap belt across the upper thighs and prevent it sliding up to the stomach area. I have since learned better. It of course depends on the direction of the accident loads and the direction of the inertia of the body as to how all restraint straps come into play. Many glider accidents involve "dropping in" vertically wherein the tailbone (in the L-1, L-2 area) or higher are damaged so the belts don't help much. You seldom see accidents with lap belt overload, but it happens. I have a sad memory of helping remove a dead friend from an inverted Ventus cockpit where the lap belts on both sides had pulled lose from the seat pan. Fortunately rare but it happens. In my "incident" the nose of the glider hit hard ground at about a 60 plus degree angle. The "load" was about along the longitudinal axis of the glider. Since in our modern gliders (ASW-28 in my case) we recline (sit supine), the inertia of my body was toward the nose with only the crotch strap to resist. Actually Waibel designed the seat pan to take some of this forward load against the bottom of the thighs. In this seating the knees are bent more upward. The nose of the glider (along with my feet) was crushed in a calculated energy-absorbing manner. Thank you Gerhardt Waibel! I think his design and the crotch strap saved my knees. I was conscious and lucid until the helicopter dropped me off at the Medical College of Georgia Trauma Center. After that I really was not with it for a couple of weeks, but after that time I suddenly noticed that my groin area was still quite swollen. I realized that my crotch area had sustained a significant load and that all things considered had kept my body from moving more forward and no doubt helped minimize the leg/knee damage. I had no shoulder strap or lap belt marks or soreness. Since my guess is that a significant number of glider accidents impose loads and body reactions similar to mine, I recommend a crotch strap. Trying to distribute the load to the pelvic area by wearing an athletic "cup" may be good for some flights, but for some flights there are other disadvantages. Many contest pilots regularly wear a male external catheter and I don't think both would work. With just the crotch strap I always had to be careful that the strap was adjusted somewhat to the right, was not too tight, and did not interfere with the flow from the catheter that was to the left. I suggest reading Chip Bearden's posting which appeared in the rec.aviation.soaring newsgroup on Nov.20 1998 which outlines a more complex but better seat belt design. I hope this discussion will create more thought about glider accident safety. Ed Byars |
eScrew zen story | [email protected] | Owning | 0 | December 20th 04 07:19 AM |
Funny story about naval | [email protected] | Naval Aviation | 0 | December 20th 04 03:37 AM |
Funny story about piloting | [email protected] | Piloting | 0 | December 20th 04 12:34 AM |
Amazing, True Story and Lessons | jsmith | Piloting | 5 | March 24th 04 03:32 PM |
PFC Lynch gets a Bronze Star? | Brian | Military Aviation | 77 | August 2nd 03 11:15 AM |
