HVLP Paint Sprayer Recommendations
Old March 24th 18, 01:06 AM posted to rec.aviation.soaring
[email protected][_1_]
Default HVLP Paint Sprayer Recommendations
Anyone used the 3M Accuspray gun? Seems like a great tool for spraying gel coat and polyester topcoats. Spray head is disposable and they come in 3-4 diameters. I am going to try one
Old April 10th 18, 04:27 PM posted to rec.aviation.soaring
For a dryer, either pick low humidity days, or.......
https://www.grainger.com/category/co...fm%26sst%3DAll
I will guess most smaller shops/homes are looking at 125PSI @5CFM or so.
Pick a dessicent dryer or small refrigerated dryer.
Granger.com sells a number of units in North America.
Long copper pipe runs from the compressor to use helps cool the air so more water drops out.
A water filter can remove more.
A water to air intercooler can also drop more water out.
A dryer removes even more water.
Everything you do to help limit entrained water makes tools work better and lessens water in paint/gel coat finishes.
Axis Products Citation HVLP Filter Change Andy[_7_] Restoration 0 May 29th 08 06:07 PM
Recommendations for paint shops & avionics shops near NW Ohio [email protected] Owning 0 May 20th 06 12:23 PM
corrosion x sprayer paul Home Built 0 July 31st 05 07:52 PM
paint shop recommendations wanted (SE) Stephen N Mills Owning 0 January 29th 04 03:44 PM
Cleaning the sprayer Michael Horowitz Home Built 2 August 26th 03 03:12 AM
