Cobra Trailer brakes
Old July 15th 04, 09:18 PM
Eric Greenwell
Paul Repacholi wrote:
Has anyone had a trailer come off the ball while hooked up like Tom
describes, and how did it work out?
You cross the chains over. Left chain to right shakle on the tow bar,
and visa versa. This keeps the trailer centred when it comes off the
tow ball. Bit of noise, and slow down *SLOWLY*. You dont want your
trailer chewing on the boot!
If you rub the chains straight, it can whip around like a demeted dog!
I've seen this advice many times in the RV group, but the alleged
purpose is always to the tongue off the pavement, without much comment
of reducing disconnected stability. Perhaps keeping the tonque off the
pavement increases the stability of the combination, even it the people
repeating the advice don't realize it.
So, two questions now:
1) Has anyone had a trailer come off the ball while hooked up like Tom
describes (chained and with handbrake cable connected), and how did it
work out?
2) has anyone had a trailer come off the ball with the chains crossed,
Eric Greenwell
Washington State
USA
Old July 19th 04, 04:51 PM
Duane Eisenbeiss
I have had two trailers come off the ball over the years. The first was
with a trailer with NO brakes. After hooking up, the trailer was driven at
least a half mile over a very rough dirt road leaving the airport (the old
Marfa airport). And then it did not come off until 30 - 40 miles. The
second was with a trailer that had a cable actuated brake. Again, a rough
dirt road was used to exit the airport. After about 10 miles the trailer
came loose. The brake did get set, but not strongly (lack of adjustment for
previous wear).
The solution for both cases was the same. I was able to feel that the
trailer had come loose. In a motor home this might not be possible. I then
slowed the car until the trailer came into contact with the rear bumper.
The car was then slowly braked to a safe stop. The trailer stayed stable
while trying to "push" the car (both cases).
This procedure may scratch the rear of the car, but, that is much better
than scratching the sides and top in a roll over. And is much preferable to
having the trailer break away and possible go into another car.
Duane
Cobra Trailer Axel Replacement Carter Soaring 7 July 7th 04 02:06 PM
Cobra Trailer Question Deputy Dog Soaring 7 January 3rd 04 03:11 PM
Trailer brakes Bert Willing Soaring 1 October 31st 03 07:55 AM
Cobra Trailer Soaring 1 September 28th 03 01:14 PM
Cobra trailer fittings for different glider makes & models John W Soaring 4 September 24th 03 03:21 PM
