What is the best point to jack up a Cobra Trailer ?
Old November 15th 18, 07:47 PM posted to rec.aviation.soaring
Default What is the best point to jack up a Cobra Trailer ?
I, too, had a flat on the trailer driver side. I 70, just starting rain, on a curve and just over a hill top. I called and waited for the Illinois State police to show up. It took a while and dusk was settling in. Nothing like having those flashing lights to slow things down. No way I was going to try it without him there. It was a quick change and he didn't even want my name when it was all over.
Old November 19th 18, 01:03 AM posted to rec.aviation.soaring
AS
On Wednesday, November 14, 2018 at 9:14:26 PM UTC-5, AS wrote:
On Wednesday, November 14, 2018 at 2:13:07 PM UTC-5, wrote:
There is a bracket for AL-KO trailers that Cobra uses. This is for a caravan. Should work.https://www.youtube.com/watch?v=bux1kg7wxCg
Interesting! Looks sturdy but I guess one would need a special jack which 'slots' into the bottom of that bracket. I wonder if a standard jack could be used on the upper horizontal part of the bracket.
I will check the frame on my Cobra trailer this weekend.
Uli
'AS'
Ok - went out to the airport today after almost week of solid rain in the Carolinas to check on the trailer and the frame underneath. There is nothing like the frame shown in the video under my trailer. Maybe it is because I have a double-axle trailer? Anyhow, I guess I will have to place the jack right under the axle tube should I have a flat. However, since I have a TPM-system, that chance is greatly reduced to a sudden, total blow-out. :-)
Uli
'AS'
Old November 19th 18, 12:23 PM posted to rec.aviation.soaring
RR
If you have a double axle traler, you dont need to mess with Jacks at all. I have a double axle airstream, and some "leveling blocks". I just make a ramp with the blocks and drive or back the trailer up the ramp on the good wheel an you are good to go. I still carry a jack just in case, but have never needed it.
Old November 19th 18, 02:39 PM posted to rec.aviation.soaring
Tango Whisky
Le lundi 19 novembre 2018 13:23:20 UTC+1, RR a écritÂ*:
If you have a double axle traler, you dont need to mess with Jacks at all.. I have a double axle airstream, and some "leveling blocks". I just make a ramp with the blocks and drive or back the trailer up the ramp on the good wheel an you are good to go. I still carry a jack just in case, but have never needed it.
I too have a twin axle trailer. Changing the front wheels is plain simple - just raise the hitch with the front dolly wheel...
Doesn't work with the rear wheels, though. But then, no need for road side work as the trailer will run well on the 3 remaining wheels to the next shop. Last year I towed mine on 3 wheels on the highway for about 30 km, and the deflated tire didn't heat up at all.
Old November 19th 18, 03:59 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Can you believe people ask me why I have a double axle trailer for an 18 meter bird.
Old November 28th 18, 04:07 AM posted to rec.aviation.soaring
2G
You really only need a 4x4 block to drive the good tire on - that lifts the flat tire so it can be changed. Works for either tire.
Tom
Cobra Trailer Screw Jack [email protected] Soaring 0 November 20th 12 04:18 PM
Cobra Trailer Screw Jack JS Soaring 0 November 20th 12 02:01 AM
Cobra Trailer Screw Jack Mike McCarron[_2_] Soaring 4 July 31st 12 09:07 PM
Cobra Trailer Screw Jack Mike McCarron[_2_] Soaring 0 July 30th 12 07:27 PM
WTB: Cobra Trailer Ramp Jack - US Gary Emerson Soaring 1 June 21st 09 01:34 AM
