Undershoot Vs. Overshoot airport landing accidents
Old April 18th 19, 08:40 PM posted to rec.aviation.soaring
Piet Barber
Default Undershoot Vs. Overshoot airport landing accidents
Go and try that with a DuoDiscus.
Pfft.
https://youtu.be/Yc-oTfr5Zwc?t=525
Old April 18th 19, 08:42 PM posted to rec.aviation.soaring
[email protected][_2_]
‘No 360s please. That has disaster written all over it.’ T8
Disagree once the pilot is proficient and not a student. I consider a 360 circling pattern to an off field landing preferable, especially when field elevation is unsure.
S K makes a mistake, to ‘Preach’ to him not to use a proven technique to improve knowledge of the field condition because some can’t make a coordinated turn below 1000’ agl a bit of snake handling.
R
Old April 18th 19, 08:54 PM posted to rec.aviation.soaring
Tango Eight
R
Hi Henry:
There's nothing wrong with a 360 degree pattern (that is, one that completely encloses the landing area). The 360 I am taking issue with is the tight 360 that happens on final because the pilot thinks he's hopelessly high. As previously noted, better solutions exist.
best,
Evan
Old April 18th 19, 09:05 PM posted to rec.aviation.soaring
Tango Whisky
Yes. Anytime.
Old April 18th 19, 09:16 PM posted to rec.aviation.soaring
Tango Whisky
What's your point? That was an easy situation.
How about you're too high on a field 700 ft long? 750 ft is about what I can expect as a field where I fly. And I've got away with 300 ft.
Bert TW
Old April 18th 19, 11:14 PM posted to rec.aviation.soaring
Paul Agnew
Lots of great insight to digest...Dive and Drag is an interesting solution, if you have enough runway to scrub off the excess speed and/or your spoilers are effective. My ASW19 stock spoilers are just not effective enough for me to try the Dive and Drag method.
Reverse Base Method = 180° turn to reverse + 90° turn to final = 270° (two turns & wind corrections).
Why not just make a stable, descending 270° turn when crossing the final? In powered, fixed-wing aircraft, it's not unusual to get assigned a right or left 270 to final by tower to improve spacing on departing aircraft. It's a basic ground reference maneuver that could be adapted for gliders so you roll out aligned with the runway.
We're supposed to be able to turn back to land above 200ft with a rope break, which is based on our collective understanding that we can safely execute a turn, maintain speed, and align with the runway from that minimum altitude. That requires 180° of turn, if the towplane drifted downwind and you turn into the wind (ideal, but our guys don't). Or, 210-270° total if you have to reverse course, angle for the runway, then turn back to align with the runway. The second scenario requires multiple, low-altitude turns. Is that ideal?
Performing a stable, 270° or 360° turn for altitude correction should be within out skillset, but only if the excessive altitude is above a certain threshold for your ship. 100-200ft high? Maybe not the best option. Clear knowledge of your ship's descent rate in a turn is critical for decision making.
That said, I've always been successful with a little slip to correct for any excess altitude. Starting the correction on the base leg and performing a slipping turn to final burns off a lot of excess altitude. (I learned to do this with Phil Beale on my CFI-A checkride back in 1986.)
Paul A.
Jupiter, FL
Old April 18th 19, 11:26 PM posted to rec.aviation.soaring
Jonathon May
solution,=
and/or your
spoile=
enough
for=
me to try the Dive and Drag method.=20
Reverse Base Method =3D 180=C2=B0 turn to reverse +
90=C2=B0 turn to final
=3D 270=C2=B0 (two turns & wind corrections).
Why not just make a stable, descending 270=C2=B0 turn when
crossing the
fin=
assigned a
ri=
aircraft.=
for gliders
s=
a rope
brea=
safely
execut=
minimum
altit=
ude. That requires 180=C2=B0 of turn, if the towplane drifted
downwind and
270=C2=B0
total=
back to
ali=
altitude
tur=
ns. Is that ideal?=20
Performing a stable, 270=C2=B0 or 360=C2=B0 turn for
altitude correction
sh=
above a
best
option.=
for
deci=
sion making. =20
for
an=
performing
a=
learned to
d=
o this with Phil Beale on my CFI-A checkride back in 1986.)=20
Paul A.
Jupiter, FL
When we flew K7 and K13 you could dive against the brakes,
provided you open the air brakes about 50kn then lowered the
nose the speed gain was not too high.If you put on 70Kn then
opened the airbrakes the speed would not reduce much.
However if you try that in a Mk 1 Duo discus you will be zooming
down the runway at 120+kn waiting for the boundary fence.
Old April 19th 19, 12:33 AM posted to rec.aviation.soaring
Matt Herron Jr.
R
Hi Henry:
best,
Evan
Tight 360s are much safer than shallow 360s. Much harder to stall/spin. I just finished a winch launching class, and was taught that in the event of a rope break you can find yourself at mid field at 300' -400' and your best option is a tight 360 turn or two- to the downwind side, tangent to the runway, then land from mid field once below 300'. (this is for a shorter 2700' runway). It seemed very unintuitive at first, but it worked just fine.
  #29
Old April 19th 19, 01:16 AM posted to rec.aviation.soaring
Dave Nadler
On Thursday, April 18, 2019 at 5:14:05 PM UTC-4, Paul Agnew wrote:
...My ASW19 stock spoilers are just not effective enough...
Yup, do the -19 spoiler upgrade that adds an additional panel,
nice to have that additional drag and safety margin!
  #30
Old April 19th 19, 03:37 AM posted to rec.aviation.soaring
Tango Eight
R
Hi Henry:
best,
Evan
Tight 360s are much safer than shallow 360s. Much harder to stall/spin. I just finished a winch launching class, and was taught that in the event of a rope break you can find yourself at mid field at 300' -400' and your best option is a tight 360 turn or two- to the downwind side, tangent to the runway, then land from mid field once below 300'. (this is for a shorter 2700' runway). It seemed very unintuitive at first, but it worked just fine..
Thanks for pointing that out. Winch training on my todo list, maybe I'll change my opinion in light of new data. Winch trained pilots have some advantages: namely, a lot more landings and more low altitude maneuvering and decision making. That's got to make a difference.
-Evan
Preventing Landing Accidents Glider Safety Webinar Tom[_12_] Soaring 0 January 18th 12 07:49 PM
Overshoot in Honduras? Mike Isaksen Piloting 12 June 2nd 08 02:53 PM
Hawk overshoot [1/1] Peter Twydell Aviation Photos 0 March 25th 08 08:20 PM
Preventing Landing Accidents DVD [email protected] Soaring 0 March 26th 07 05:56 PM
Preventing Landing Accidents Video Thomas Knauff Soaring 0 March 21st 04 03:01 PM
