![]() "Dan, U.S. Air Force, retired" wrote in message news:rhLVd.21112$Sn6.10965@lakeread03... The hard part is the electronics package between the two. It wouldn't be that bad, really. At least not for just a rate damper. The R/C gyros put out pulse-width modulation signals, which are pretty easy to work with. Also, there are a lot of decent servos out there that can read it. I think the hard part of the rate damper project is making sure you don't overtorque something important in your airplane, and setting things up so that, when the damper servo goes haywire, that you can turn it off and revert to a normal airplane quickly and without hurting anything/anybody, and that while you're busy figuring out that something is going wrong, that you can overpower anything it's doing that you don't like. More than a few people and quite a few airplanes have gotten killed in the process of engineers trying to figure out how to do all this automatic stabilization and fly-by-wire stuff. It's not something approached casually, unless it's for a toy that's OK to crash (R/C model). In my somewhat short career as a flight controls engineer (12 years), I've seen 3 airplanes lost and more than a couple of close calls due to control design issues. Even when everything works as designed, there are man-machine interaction problems that can kill you. Even apparently innocuous things. Think back to that Airbus that busted up a couple of years ago in New York. I think there's an article in Flying this month about it. Nothing there that jumps out at you as an obvious hazard, but it got a couple hundred people real dead. I'd really hate to see someone on this newsgroup go out and get himself killed trying to invent something without full cognizance of the hazards. Pete |
Dan, U.S. Air Force, retired wrote:
wrote: You can get really nice R/C servos for way under $100. Ball bearingsand the works. The quarter scale size servos would probably be about right to fly a control surface. Piezo gyros are also under $100 for R/C applications. Regards The hard part is the electronics package between the two. I know the systems I worked on, but I would be reluctant to attempt builing a system. Not my bowl of rice, but I'd like see what others come up with. Dan, U.S. Air Force, retired Dan, did you ever get a chance to work with fuzzy logic? It would require a stepper motor to control the control surface, but it could easily maintain wing level or altitdude with grace and smoothness. Have you ever seen the balancing trick with the mortorized car. A weight on the end of a stick is hinged on top of a programmed electric car. The car acclerates quickly to flip the weight vertical, and then jostles back and forth to balance it there. All with not input except an indicator of the angle of the stick holding the wieght. Impressive. I have the information for the EZTrim altitude hold system. After I have everything else on the plane working, I have a goal of reworking the software to use a fuzzy algorithm. |
The good news is thats the part that has gotten more doale in recen
years. Electronics that used to take a dozen guys to tweak, one kid with a PC and PIC can do. He may not understand the application, but the implementation technology has gotten quite powerful and cheap. Fuzzy Logic, from what I can tell, if you do a really good job, you can get to where a properly tuned PID controller would be, but without that pesky math. Now neural networks, that would be something to see. Watch the network learn how to fly from a few simple rules 1) Stall is bad 2) crashing is really bad 3) Its good to keep the oily side down. I think I'd have it learn that sucker learn the basics flying an model (R/C or computer). Stepper motors- Why go to all the trouble when you have cheap off the shelf full up servos? Dan, U.S. Air Force, retired wrote: wrote: You can get really nice R/C servos for way under $100. Ball bearingsand the works. The quarter scale size servos would probably be about right to fly a control surface. Piezo gyros are also under $100 for R/C applications. Regards The hard part is the electronics package between the two. I know the systems I worked on, but I would be reluctant to attempt builing a system. Not my bowl of rice, but I'd like see what others come up with. Dan, U.S. Air Force, retired |
On Wed, 2 Mar 2005 08:30:27 -0800, "Pete Schaefer"
wrote: "Roger" wrote in message .. . To paraphrase the manual for my auto-pilot. When encountering more than moderate turbulence, turn off the autopilot. I believe Pete touched on this as well. Driving an auto-pilot too hard can put your servos on the rate limit. On a rate limit, a servo develops serious amplitude-dependent lag, which can destabilize your loop closures. THe way arount this problem? Big, huge, powerful, fast servos. This solution opens up a whole other can of worms. Ahhh... That's not what I was getting at. They have you disconnect to protect your airplane as the servos can do too good a job of holding altitude. It wasn't lag they were worried about. Just as the question asks on the FAA exam. What do you do when entering an area of moderate to severe turbulence? The AP doesn't know the correct answer for that one and it's going to hold altitude, and/or attitude even if it has to break something to do it. (depends on the AP) There really is such a thing as "too much of a good thing". Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Roger" wrote in message ... Ahhh... That's not what I was getting at. They have you disconnect to protect your airplane as the servos can do too good a job of holding altitude. It wasn't lag they were worried about. Yeah, there are a couple of issues there. The autopilot might command surface deflections beyond what is safe for the control surface. Could rip a surface off. And, as I already said, the autopilot could get into an oscillation if it rides a rate limit. Just as the question asks on the FAA exam. What do you do when entering an area of moderate to severe turbulence? Yup. There really is such a thing as "too much of a good thing". Roger that...uh..Roger. |
Dick
Check developments in Israel. They have a lot of UAV's that have systems in them that might fit your requirement right off the shelf? Big John `````````````````````````````````````````````````` `````` On Fri, 25 Feb 2005 00:12:06 GMT, "Dick" wrote: Sitting around the hanger and discussing the possibility of somehow using off-the-shelf electronic/computer components or gadgits for semi-automatic wing leveling on lightly loaded, short wingspans. Not being computer guys, the current thought is that something should be out there that is available cheaply and modifiable to use a simple wing leveler. Having heard someplace that automotive computers, as an example, sense data millions of times leads us to believe that sensing the wing tip initial movement and counteracting very very quickly would be a good thing. As an example: One fellow pictured a rolling ball bearing inside a tube somehow activating a magnetic switch which in turn pulses a dc linear motor to operate the aileron minutely. We are not sure how to detect the very earliest initial wing tip movement or drive the small trim type motor and would appreciate some thoughts or site recommendations to investigate. Thanks, Dick |
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 08:40 PM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
