Tow plane types/mods for high density altitude glider towing
Old August 14th 19, 04:33 PM posted to rec.aviation.soaring
Dan Marotta
Default Tow plane types/mods for high density altitude glider towing
That is super!
Was there any difficulty with your CAA or was the GFA authorized to make
those mods?
On 8/13/2019 2:08 PM, JS wrote:
Regarding mods, the eTug deserves mention.
A Pawnee with a 350 cubic inch Chevy LS1 running on Mogas. Early experiments provided too steep a climb angle, so the original 4-blade prop was adjusted to decrease the climb rate. Now it has a different prop.
I've hooked many gliders up to eTug, yet to tow behind it.
https://www.glidingclub.org.au/membe...aircraft/etug/
These days a crate LS3 engine can be purchased for about $8000 and produces 430HP on Mogas. Car engines require a PSRU (speed reduction).
https://www.gmperformancemotor.com/p... AhPlEALw_wcB
Not much concern about shock cooling or leaded Avgas going away.
Dan, 5J
Old August 14th 19, 06:34 PM posted to rec.aviation.soaring
Craig Funston[_3_]
On Wednesday, August 14, 2019 at 7:33:57 AM UTC-7, Dan Marotta wrote:
That is super!
those mods?
Dan, 5J
Akaflieg Stuttgart just flew their concept of an optimized towplane. Congratulations to all the students and their mentors.
https://akaflieg.hg.stuvus.uni-stutt...EvgsGCyBGeZLCI
Craig
Old August 14th 19, 07:03 PM posted to rec.aviation.soaring
John Foster
That is super!
those mods?
Dan, 5J
Craig
That looks promising. Now to make them "affordable".
Old August 14th 19, 07:33 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
That is super!
make those mods?
prop.
reduction).
https://www.gmperformancemotor.com/parts/19370416.html?
gclid=Cj0KCQjwv8nqBRDGARIsAHfR9wC30A7wF3SFSrhYOBoL dkinr_7MGZMpHxignUEhA1qfW5iBSSEbHwAaAhPlEALw_wcB
Dan, 5J
https://akaflieg.hg.stuvus.uni-stutt...erstflug-fs35-
harpyie/?
fbclid=IwAR1rgq8zp1xdRFvQTqvAQGbklVeiF76CE0bKvKbdx jlFvEvgsGCyBGeZLCI
I remember a couple of specialist tow planes appearing a few years ago,
apparently to disappear without trace a bit later. One came from an
Akaflieg and was dual purpose: two seat aerobatic aircraft and tow-plane.
The other was from the Finnish Akaflieg equivalent - the PIK-27.
Are either in use as tow-planes now?
Has more than the prototype of either type been built?
Martin | martin at
Gregorie | gregorie dot org
Old August 14th 19, 08:21 PM posted to rec.aviation.soaring
The Mü30 Schlacro from Akaflieg Munich is in use and serves as an excellent towplane. Schlacro comes from "Schlepp" (Tow) and "Acro". It will probably be around at WGC 2020 at Stendal. Currently it is working there during Idaflieg summer camp. Since it was built by the students, it unfortunately is a unique aircraft.
The fs35 is a very interesting concept indeed, combining a motorglider similar to a HK36 Super Dimona with a 155hp turbocharged aircraft diesel engine..
Old August 14th 19, 08:55 PM posted to rec.aviation.soaring
AS
A great concept, indeed! The turbo-charged Diesel engine should make the Hot/High condition secondary. Here is the link to the engine manufacturer's site:
http://www.continentaldiesel.com/typ....php?id=84&L=1
Uli
'AS'
Old August 15th 19, 05:39 AM posted to rec.aviation.soaring
JS[_5_]
That is super!
those mods?
Dan, 5J
The original LS1-mod Pawnee, VH-CUR is EXP. Don't think they've certified one yet.
Old August 15th 19, 06:44 PM posted to rec.aviation.soaring
Bob Youngblood
On Monday, August 12, 2019 at 9:38:43 PM UTC-4, son_of_flubber wrote:
What are your favorite aircraft types (and modifications) for glider towing in high density altitude and/or short runways?
The C-188 300 constant speed prop is a great towplane. I am already planning to make one my next project.
  #29
Old August 15th 19, 10:35 PM posted to rec.aviation.soaring
Don't do it if you have neighbors. Second loudest tug I've seen, behind only a 650 Agcat.
UH
  #30
Old August 15th 19, 10:57 PM posted to rec.aviation.soaring
Hmmmm.....not sure if our field.....remember a short time tug that was great, but maybe 75% throttle lit up the local PoPo....
Yeah.....not many tows, but they were fun......
Perlan High Altitude Tow Plane Frank Whiteley Soaring 32 August 25th 18 02:32 PM
Martin B-57 Canberra pics [19/20] - NASA High Altitude Plane.jpg (1/1) Miloch Aviation Photos 0 August 26th 16 01:34 AM
High Altitude simulator accuracy in X-Plane Ghazan Haider Simulators 2 August 16th 05 07:01 PM
Pressure Altitude or Density Altitude john smith Piloting 3 July 22nd 04 11:48 AM
