Fueling from plastic gasoline containors
Old February 28th 05, 01:19 PM
Michael Horowitz wrote:
: I may have an opportunity to move to a hanger at a private strip; no
: facilities, so I'll have to tote in my own gasoline in 2 1/2 gal
: plastic containors.
I'm not sure how large of a creature you're fueling, but I've been filling my
Cherokee up with 5 or 6 gallon cans for two years now.
: When refueling, do I only need to worry about grounding the a/c?
: How would static be generated? - Mike
Grounding the a/c isn't nearly as important as grounding the can to the plane.
It's not the static buildup on the plane that's the problem, but rather the static
differential between the plane and the can as the fuel pumps charge as it flows.
You can build a nice fuel trailer for $300-$500 as people have suggested. My
solution is somewhere between cans and a fuel trailer.
I didn't like the small amount of water and particulate gunk I picked up from
the gas station, nor the feeling of having to maintain sterility with the lids, etc.
I ended up constructing a pouring spout for the cans with a spin-on, water-absorbing
fuel filter included in the spout. You can get the filter from a farm-supply or order
it... $20 or so. When I switch to another can, I simply move the pour spout to the
new can. Also, the plumbing for the spout is metal, so I can definatelively bond the
plane to the part of the can that counts..... the pouring area. Charge will not build
up, and even if it did it cannot spark where the two come together (since they're
metal-metal and already bonded together).
It's not that big of a deal to just fill up and bring along a few cans on your
way to go flying.... dump it in when you're done.
-Cory
* Cory Papenfuss *
FS: Revell Monogram "F-14A Tomcat" Plastic Model Kit (1:48 Scale) J.R. Sinclair Aviation Marketplace 0 August 16th 04 05:59 AM
The answer to the gasoline problem Veeduber Home Built 4 May 22nd 04 08:58 PM
FAR Reference - Self Fueling Ben Smith Owning 8 April 8th 04 11:07 PM
$3.00 a gallon gasoline by summer(read all of this, it just might work) Fastglasair Home Built 8 March 10th 04 12:12 AM
Repairing Plastic Jay Honeck Owning 5 February 2nd 04 09:20 PM
