Vibration Monitor (Hyde, Wanttaja?)
Old March 13th 05, 05:07 PM
RST Engineering
Strangely enough, that is what I *DID* for a living when Spectral Dynamics
was the industry leader in machinery diagnostics. Unfortunately, my job was
the circuit design, not the diagnostics itself, so all I concerned myself
with was the black box that took a defined input and produced a defined
output. There are times I wish that I had transferred to the applications
department. They were the ones that seemed to have the most fun (and the
most three martini Friday lunches).
Stangely enough, this is what I do for a living. No kidding.
I am an engineer at Bently Nevada, Corp, the industry leader in machinery
diagnostics.
Old March 13th 05, 05:11 PM
RST Engineering
Yes, all of the below.
Sometimes you drill a hole in a small magnet and use a small screw to hold
it to the propeller backing plate. Sometimes you use a strip of reflective
tape on the prop itself. Sometimes you use a pulse from the #1 magneto
lead.
"Morgans" wrote in message
"sleepy6" wrote
That notch causes a much larger timing blip in the signal than any
crank movement will cause. By measureing the time between the timing
blips you can determine the amount of rotation after a timing blip that
you see an up or down crank movement event.
What sort of technology does a proxomity detector use? Magnetics, sonic,
radio waves?
Old March 13th 05, 05:12 PM
RST Engineering
Love to. You got my address?
"George A. Graham" wrote in message
Jim,
I have a Memsic demo board, which displays LEDS on two axis with
their tilt and motion sensor.
I am done with it, would you like to play with it?
George Graham
RX-7 Powered Graham-EZ, N4449E
Homepage http://bfn.org/~ca266
Old March 13th 05, 05:18 PM
mindenpilot
"RST Engineering" wrote in message
was the circuit design, not the diagnostics itself, so all I concerned
myself with was the black box that took a defined input and produced a
defined output. There are times I wish that I had transferred to the
applications department. They were the ones that seemed to have the most
fun (and the most three martini Friday lunches).
LOL.
I've been an engineer designing in the dark many times.
Fortunately at Bently, there is a large effort to train engineers in
diagnostics.
Then we can use personal experience in addition to requirements documents
when designing a new product.
Or, at least, we can determine if requirements make sense!
Adam
Old March 13th 05, 05:21 PM
mindenpilot
"sleepy6" wrote in message
Of course this simple setup will not show side to side movement. That
would require a second proximity detector 90 degrees from the first
one. The 2 signals would require integration but would then show all
movement in the rotational plane with the proper signal processing and
calibration.
Exactly. This two-dimensional shaft path is called an orbit.
Adam
Old March 13th 05, 05:39 PM
RST Engineering
Understood. What I started out to do (and still plan on doing) is to have a
device that will stay permanently mounted to the engine that can be
calibrated (adjusted, signed, pick a verb) when the engine is known to be
good and light a "your engine is about to come apart" lamp at the
appropriate time.
What this group seems to be leaning toward is a lab quality device that will
allow for sophisticated diagnostics. That ain't the thrust of my Kitplanes
columns. KISS and BURP.
Old March 13th 05, 05:48 PM
mindenpilot
a device that will stay permanently mounted to the engine that can be
appropriate time.
will allow for sophisticated diagnostics. That ain't the thrust of my
Kitplanes columns. KISS and BURP.
As is tradition, we tend to get off topic ;-)
I think you can accomplish this using the methods discussed.
Mount 2 proximity probes 90 degrees apart.
Calibrate the readings for normal low vibrations (be sure to account for any
nonlinearities in the probe).
Design the circuit to trip the buzzer/lamp when the vibration exceeds the
normal level.
You may need some analog circuitry to help (gain, etc).
But you don't need to get much fancier than that.
Adam
Old March 13th 05, 09:16 PM
RST Engineering
Proximity probes? Or accelerometers?
I understand about the analog circuitry and actually plan on making a five
or six channel filter at each of the possible resonance points relative to
the fundamental ... and then strobing the filters to light a "normal",
"low", "high" lamp for each channel.
any nonlinearities in the probe).
normal level.
Adam
  #29
Old March 14th 05, 12:49 AM
Morgans
reflective
lead.
This guy was talking about a notch and proximity detector for the phase
detection. I know about all of the things you mentioned, but the proximity
detector's workings are new to me.
  #30
Old March 14th 05, 01:10 AM
mindenpilot
I would use proximity probes if you are primarily going to measure
vibration.
They are also the best choice if you are going to notch the shaft and do
phase measurment.
I'm not sure about other venders' prox probes, but the one's I'm used to
have a linear range.
The phase measurment can be gained so that it rails one way when over the
notch and rails the other way when not, so you don't have to worry about the
linear range. As for vibration measurments, you will have to make sure that
you stay in the linear range of the probe.
I want to make sure I understand what you meant by having a filter at the
resonance points.
Are you only going to measure vibration at resonance (i.e. bandpass)?
Or, are you NOT going to measure at resonance (i.e. notch filter)?
Keep in mind other events may cause vibration, such as impulse, rub, etc,
which will likely occur synchronous to the shaft, and have nothing to do
with resonance.
This is where a phase reference may be handy because you could determine if
it is happening 1X/rev, 2X/rev, etc.
OR, are you assuming that an impulse/rub event will excite the case at the
resonance frequency?
At any rate, what you intend on doing is definitely do-able.
I recommend playing with probes a bit to see what you get.
Sounds like a fun project.
Let me know if there's anything I can offer...
Adam
normal level.
Adam
Wierd vibration -- Prop or engine, balance or not??? Chuck Owning 17 December 1st 04 02:12 PM
Pinging Ron Wanttaja - "Unporting?" Bob Chilcoat Home Built 13 November 24th 04 07:28 PM
Vibration Testing Jim Weir Home Built 20 October 10th 04 07:22 AM
Vibration Testing Jim Weir Owning 21 October 10th 04 07:22 AM
Survey - 3 blade prop conversion- Cockpit vibration, happy or not Fly Owning 20 June 30th 04 05:32 PM
