How did you install your FLARM brick and/or ADS-B Out?
Old November 27th 19, 05:05 AM posted to rec.aviation.soaring
JS[_5_]
Default How did you install your FLARM brick and/or ADS-B Out?
I installed mine with pop rivets.
Old November 27th 19, 03:53 PM posted to rec.aviation.soaring
Mike N.
I have a Power Flarm I just acquired when I recently purchased a glider.
How can I determine if I have the ADS-B 1090ES receiver? Or is this something I can add?
I looked on the Flarm web site mentioned above and it I could not find information that tells me if I have, or how to add the ADS-B 1090ES receiver.
Thanks
Old November 21st 19, 05:45 PM posted to rec.aviation.soaring
Tom BravoMike
On Wednesday, November 20, 2019 at 9:31:50 PM UTC-6, wrote:
I refuse to install flarm, because I consider that company to be actively obstructing the adoption of adsb in gliders, by diverting money better spent on adsb, and by not allowing flarm traffic displays to accept non-flarm-format inputs. My glider has a Trig 22 and TN72 and a scout adsb-in sending data to the foreflight on my kneepad iphone.
I refuse to install FLARM because it doesn't make sense to me that I actually need BOTH the FLARM and a transponder/ADSB to see and be seen by others in the air. I know and understand the point about 'collision avoidance' vs. 'situational awareness'. I accept the fact that competition pilots flying in gaggles feel and are safer with the additional warnings from FLARM. ADDITIONAL to your eyes, because if you are flying that close to other aircraft(s) you should be looking out and not at the instruments.
All my clubs' gliders are equipped with FLARM, but I heard several skeptical opinions from fellow members. My recent experience was: beep-beep-beep... Where is he? Oh gosh, so close cutting in behind me at the same altitude. I'd rather be warned in advance about him approaching to be able to control his position all the time.
Also, very discouraging to me are the endless discussions about antennas, range issues and software updates.
So I'm looking forward to seeing a device integrating and combining the advantages of gliding-specific FLARMs with GA universal transponders/ADS-B.
Old November 21st 19, 06:14 PM posted to rec.aviation.soaring
Darryl Ramm
All my clubs' gliders are equipped with FLARM, but I heard several skeptical opinions from fellow members. My recent experience was: beep-beep-beep.... Where is he? Oh gosh, so close cutting in behind me at the same altitude.. I'd rather be warned in advance about him approaching to be able to control his position all the time.
^^ That's just not going to happen. And you can get a flavor for why from other concurrent threads here.
Old November 21st 19, 07:15 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Tom BravoMike wrote on 11/21/2019 9:45 AM:
should be looking out and not at the instruments. All my clubs' gliders are
range issues and software updates. So I'm looking forward to seeing a device
Your beep-beep-beep... analysis missed half of what Flarm does for you: the OTHER
glider was also alerted to the potential conflict. And before the beep beep beep,
Flarm will alert you to the other glider coming into range, and you can track it's
progress on the screen well before the collision warning.
I have a glider with a Mode C transponder and Flarm: the transponder alerts most
airplanes to my presence; the FLARM alerts most gliders to my presence; Flarm
shows me the gliders and airplanes with transponders. To add ADS-B would cost me
about $3000 (Mode S transponder + TN72), and would only slightly increase the
number of airplanes that sense me, and would not change the number of airplanes
and gliders I can sense.
I do have a full ADS-B system (Dynon Skyview) in my Phoenix touring motorglider,
and it's great system for detecting airplanes, but not gliders. When I've flown it
at glider camps or contests, I also use a portable Flarm.
Most pilots that have Flarm installed do not engage in "endless discussions about
antennas, range issues and software updates" - we just turn it on and use it. Some
pilot will have problems, but once the installation is done correctly, it's just
the yearly updates that confuse some pilots. Some are also confused by updating
their flight computer or vario software and the databases, but they get some help
with those, too, and then go fly for another year.
Old November 21st 19, 08:49 PM posted to rec.aviation.soaring
I agree completely with Eric, I would not trade the PowerFlarm for ADSB in/out for my 27. Its absoulutly necessary IMHO for contest flying. I also fly a 170B with Skybeacon adsb out and stratus 2 in on a Ipad and foreflight and around busy class D airspace. Its very useful but not as good at alerts as the PowerFlarm is.
CH ASW27/C170B
Old November 22nd 19, 05:15 AM posted to rec.aviation.soaring
Thomas Van de Velde
Here's how: https://photos.app.goo.gl/KuVwn8tV9iLHkPgx7
Boeing 737 Flies Through Brick Wall, Smashes Tower on Takeoff, Keeps On Flying - 737 brick wall.JPG ... Miloch Aviation Photos 1 October 17th 18 05:34 PM
Flarm Brick for sale [email protected] Soaring 0 March 19th 17 11:12 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
Ugh. Flight trace didn't download off FLARM brick Kurt Thams Soaring 9 June 10th 15 12:37 PM
