#21
("Morgans" wrote)
My ideal sport plane would be an amphibian, if they get the rotating landing gear back in. http://www.beriev-usa.com/main/index.html (You're half way there with this Russian number) http://web.media.mit.edu/~tim/pix/oshkosh03_1/0788.jpg (At Oshkosh) http://web.media.mit.edu/~tim/pix/oshkosh03_1/0791.jpg (At Oshkosh) Montblack |
![]() "Jose" wrote in message news:b8uZd.5306 You are missing the point. Take a small engine, divide the output in half, and the prop is going to be small. Why? Because I can. Because that would divide the HP into two, so a smaller size bike belt would be reliable. Pay attention. -- Jim in NC |
Morgans wrote:
"Montblack" wrote Wonder if for all the trade-offs and compromises, you gain anything with one engine and two pylon props? Montblack I think so. Not too far off from my musings. Take a liquid cooled motorcycle engine, run dual drive belts, one out each of the pylon mounts, and with the smaller diameter props, you could run them faster to take advantage of the high revving engine. You get to use Harley sized drive belts and sprockets, readily available in junkyards everywhere. (the sprockets, I mean) In the article the airplane's pylons looked too thin to use belt drive. Shaft drive maybe? Dan, U.S. Air Force, retired |
![]() "Dan, U.S. Air Force, retired" wrote in message In the article the airplane's pylons looked too thin to use belt drive. Shaft drive maybe? Dan, U.S. Air Force, retired Most likely. -- Jim in NC |
I'm calling it "dead in the water" :-)
MJC "Montblack" wrote in message ... High Performance Aircraft out of Germany - HPA TT62 http://www.hp-aircraft.de/edoc/tech.html I'm calling it The Little Mermaid. Montblack |
("Morgans" wrote)
In the article the airplane's pylons looked too thin to use belt drive. Shaft drive maybe? Most likely. What about two horizontal pylons, we could call them wings? One centerline (diesel) engine turning two props. Montblack |
![]() "Montblack" wrote What about two horizontal pylons, we could call them wings? One centerline (diesel) engine turning two props. Montblack Naa. Then you get disturbed airflow to the props, need higher landing gear, and the wings would not keep the spray off the props, if it were to be an amphibian. With pylons, it is easy to adjust the angle to keep the driveline nice in line and straight. -- Jim in NC |
:Yes, that is all true. The real problem is the rapid decline in the
efficiency of conversion from power to thrust as the propellor rpm increases. The pounds of thrust per horsepower declines like a capacitor discharge curve as the rpm increases and you have lost two thirds by the time the prop rpm gets to 2000! A ducted fan helps a little, but they are much less efficient than a big old lazy unshrouded propellor chugging away. Highflyer Highflight Aviation Services Pinckneyville Airport ( KPJY ) PS: Pinckneyville rec.aviation flyin is coming up May 20, 21, and 22. See the article in AOPA Online. "Morgans" You are missing the point. Take a small engine, divide the output in half, and the prop is going to be small. Small props do not mind turning fast. Also, if you use the belts for the RPM reduction, you have to put the big pulley out on the pylon, where you want a small one. -- Jim in NC |
#29
Montblack wrote:
("Morgans" wrote) In the article the airplane's pylons looked too thin to use belt drive. Shaft drive maybe? Most likely. What about two horizontal pylons, we could call them wings? One centerline (diesel) engine turning two props. Montblack That was exactly my thought when I looked at it. "They put a T-tail behine a V-Tail. Why?" |
US Team Junior News, Calling US Juniors | John Seaborn | Soaring | 0 | October 4th 04 10:36 PM |
Airman Finds True Calling as Part of 'Best Force' | Otis Willie | Military Aviation | 0 | September 10th 04 11:18 PM |
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). | Phillip Rhodes | Military Aviation | 0 | September 7th 04 01:30 PM |
Calling Simmers in the Midlands, UK | 'Mort' | Simulators | 0 | March 24th 04 08:16 PM |
Enola Gay and all the controversy, discussions, name calling andeverything else it has brought up. | Mark and Kim Smith | Military Aviation | 29 | December 28th 03 11:07 AM |
