Pardon me, but this is the kind of bull**** that's killing GA
Old March 16th 05, 11:42 PM
Jay Beckman
"A.Coleman" wrote in message
m...
Please read this. This is what's killing GA and we ought to do something
about it.
I'm curious about something from the "4PA" incident...
The article mentions that there were five aircraft ostensibly travelling
together along the same route, right?
What if the lead aircraft (if there was one...) had mentioned to the
controller that they were a "flight of five" from the Pan Am Academy? Might
that have made a lightbulb go off in the controllers head that "these five
probably have similar call signs." ??
The only reason I ask is that we have a lot of Embry Riddle planes in AZ and
they all end in ER which I could see causing a similar set of
circumstances...
Just wondering out loud...
Jay Beckman
PP-ASEL
Chandler, AZ
Old March 16th 05, 11:54 PM
Steven P. McNicoll
"Jay Beckman" wrote in message
news:Sv3_d.6088$uk7.4361@fed1read01...
Might that have made a lightbulb go off in the controllers head that
"these five probably have similar call signs." ??
and they all end in ER which I could see causing a similar set of
circumstances...
A flight is treated as one aircraft and operates under a single call sign.
Old March 17th 05, 04:51 AM
Jay Beckman
nk.net...
circumstances...
Thanks. I kinda figured my theory had holes in it.
Jay B
Old March 17th 05, 12:48 AM
Mike W.
Might
and
circumstances...
Not that the contorollers didn't contribute to the accident, but wouldn't
the PILOT be thinking 'hmmm, was that call for me?' If I were flying in
mountainous terrain and was asked to descend below safe altitude, I sure as
hell would stay right where I was until I found out what the controller had
in mind.
There is a magic word you can use when a controller asks you to do something
you feel is unsafe. 'Unable'.
Old March 17th 05, 01:06 AM
Mike 'Flyin'8'
Ya know when I was doing my first solo XC for my PPL, I flew out of
Carlsbad and over the Julian VOR and off to the rest of my XC trip.
This was the same place where this plane crashed. Anyway, I was level
at 7500 outbound toward the Vulcan Mtn, and the controller told a
plane with Very similarr callsign as mine (I think they actually did
call my plane) to descend to (whatever it was) an altitude which was
lower than then peak of Vulcan Mtn. The other plane did not respond,
and in turn I thought it was my call sign. Of course, I immediatly
thought "No way am I going to descend into that mountain." and called
the tower and asked if the descent was intended for my callsign. They
promptly said "No, maintian 7500" and re-issued the descend for a way
different tail number. Hmmmm..
Might
and
circumstances...
in mind.
Mike Alexander
PP-ASEL
Temecula, CA
See my online aerial photo album at
http://flying.4alexanders.com
Old March 17th 05, 12:09 PM
Denny
I have noted the tendency of controlled pilots to simply lean back,
relax, and let ATC do the driving...
Stuff happens, stay alert...
denny
Old March 18th 05, 07:41 AM
Scott D.
On Wed, 16 Mar 2005 16:42:44 -0700, "Jay Beckman"
om...
about it.
According to the article in the last paragraph and the NTSB report,
the aircraft were on an IFR flight plan. So they would not be
reporting to ATC as a flight of 5. They had a 5-10 min separation
between each other. You would only use flight of X for formation
flying. There was no tops reported but it was overcast at 2000 agl
18 miles away which would be around 3400 MSL and the wreckage was
found at 5500 msl. It would be hard to fly formation while IMC and at
night. So they would not have reported as such.
Scott D
To email remove spamcatcher
Old March 18th 05, 01:57 PM
Steven P. McNicoll
Scott D. wrote in message
There's no restriction on formation flights for IFR operations or
conditions. The military does it regularly, civil operators very rarely.
The only regulatory restriction on formation flights is carrying passengers
for hire.
Old March 17th 05, 04:18 PM
Doug
My condolences to these pilots and their families.
A pilot and ATC enter into a contract when on an IFR flight plan. ATC
agrees to give clearances that avoid terrain and other aircraft and the
pilot agrees to fly the airplane according to those clearances. A pilot
should monitor his position and inform ATC of an incorrect instruction
if he is aware of it. The pilot can maintain safety by deviating even
if it is in violation of the clearance.
When mistakes are made, and they do occasionally happen, responsibility
should be attached to the parties that made the mistake. The only way
to "make whole" the injured party is through money awards. Sometimes
money isn't necessary, sometimes all that is required is recognition of
the mistake.
There was a fairly high profile case some years ago with a commercial
aircraft in Maryland. ATC cleared him to descend prematurely. On their
own, a sim operation gave the exact same instructions the pilots
received to sim pilot crews. Sixty percent crashed in a similar way as
the real plane. If sixty percent crashed, you could crash too. (most
of the ones that DIDN'T crash were had a crew member from that area who
knew about that mountain).
It it accidents like these that make me reluctant to fly approaches
into unfamiliar airports in mountainous terrain or with nearby tall
antennae towers or other tall obstructions. I have, as a pilot, been
given incorrect ATC instructions or temporarily been forgotten to be
given an important turn to final. As a single pilot, I cannot do both
ATC's job and fly the plane. Nor can I count on being able to recognize
an ATC mistake. It sounds easy to say "unable", but it's not, and it is
even harder to be sure, and I have to be SURE, that it is necessary to
say unable. I know, I've been in that situation.
Keep training, ATC, we pilots need you. We all need to work together on
this. Same goes for us pilots. When mistakes happen we all need to take
a hard look at what happened and figure out how to avoid it in the
future.
Old March 17th 05, 04:30 PM
Steven P. McNicoll
"Doug" wrote in message
Sounds like you're referring to TWA514. ATC didn't issue a descent
clearance, ATC issued an approach clearance. The pilot descended through an
intermediate altitude.
What kind of pod is it? [email protected] Naval Aviation 12 February 23rd 05 08:53 AM
This is why we train (kind of long) SD Piloting 38 January 20th 04 04:06 PM
A different kind of extreme runway David Megginson Piloting 26 November 4th 03 09:15 PM
What kind of plane is this? Roy Smith General Aviation 10 October 29th 03 06:23 PM
New kind of helicopter? John Ross Piloting 10 August 15th 03 03:26 AM
