#21
On Sunday, January 5, 2020 at 9:25:56 PM UTC-8, Craig Reinholt wrote:
It appears that Day 3 got scratched mid-flight (Scoring SPOT). Sarah was ahead of the pack, did a hard 90 deg towards the Keytah turnpoint and then turned for home. The rest of STD class turned back too. Any info? Craig Visibility was decreasing. Kathy and Sylvia also chose to start early, but had the rug pulled out from under them at the thrd TP. All are on their way back. Jim |
Hey Jim how was the visibility on the way back?
Do the WWGC rules allow the task to be cancelled after the gate is open? Was the Steward consulted?
Anything can be done on safety grounds. Viz was down to less the 0.5km so totally unsafe. Also pilots were unable to see to ground ahead and plan for safe out landing in the event of not getting lift. I am sure all pilots are disappointed, but none would have been happy to continue on those conditions. At 13:03 06 January 2020, Pat Russell wrote: Do the WWGC rules allow the task to be cancelled after the gate is open? Was the Steward consulted? |
Sounds like a good call.
BTW, the tracker replay is great, especially with a ctrl-shift-plus to get the numbers big enough to read. Anybody know what Dist, Tsp, and B% are actually showing? |
On Monday, January 6, 2020 at 8:55:36 AM UTC-5, wrote:
Sounds like a good call. BTW, the tracker replay is great, especially with a ctrl-shift-plus to get the numbers big enough to read. Anybody know what Dist, Tsp, and B% are actually showing? Push Help in the upper right of the tracking box. Part of it: G-TRACK-Live Glider Competitions Tracking (Help & Info) Live Tracking Click on the table headers to sort by Name, ID, Altitude etc.. Click on a row in the table to center on the Glider Click the checkbox next to the pilot name to follow the Glider Alt indicates the altitude QNH of glider in Feet Sp indicates the glider speed in Kts Var indicates the rate of climb in Kts Dist indicates the task distance in Km since exiting the start sector Tsp indicates the task speed in Km/h since exiting the start sector B% indicates Tracker Battery charge remaining Fix indicates the time of the last received Fix for the Glider Click on [-] in the top right of the Glider table to minimise the table Click on a glider callsign to display more details, click again to close it Callsign of Gliders on the ground will be Grey Callsign of Gliders 2000ft below the startpoint will be Red Callsign of Gliders 2000ft above the startpoint will be Yellow |
Thank You!
Push Help in the upper right of the tracking box. Thanks, the help is helpful. Dist indicates the task distance in Km since exiting the start sector For the day before yesterday with turn points, that seems great. For yesterday with turn circles and a minimum time, is there some heuristic calculating task distance and speed before the whole flight is known? |
#29
But they did continue...they were all at or nearly to the farthest Turnpoint. Most made the return trip home which was probably only marginally shorter than finishing the task.
#30
A mismatch between the Task and the actual conditions is a normal part of the game.
The only condition for cancelling a day after the gate is open is clear evidence of unfairness. Perhaps this was the case, but no justification has been published, so far. |
| Thread Tools | |
| Display Modes | |
| Day Win at Jr Worlds for USA | [email protected] | Soaring | 4 | August 16th 11 09:46 PM |
| LS-10 at the worlds. Why only ONE? | John Bojack[_2_] | Soaring | 2 | August 9th 10 09:39 AM |
| The Women, pt 2 - Etihad - women pilots.jpg (1/1) | Mitchell Holman[_4_] | Aviation Photos | 2 | April 19th 10 03:05 PM |
| Worlds first? | nimbusgb | Soaring | 4 | February 15th 08 02:05 AM |
| pre worlds | BB | Soaring | 5 | July 29th 07 02:59 AM |
