LiFePo Refit Part 23 AC
Old February 26th 20, 02:55 PM posted to rec.aviation.soaring
Shaun Wheeler
Default LiFePo Refit Part 23 AC
SLA needs replacement and aircraft is part 23 utility. A LiFePo in the same foot print would be great, I definitely see folks using them and no less than three online stores selling them.
So I started looking at AC 20-184 which seems to be the FAA equivalent of trial by ordeal. Okay, I get it. They aren't quite as proven as SLA and a few have self immolated.
I've found at least a couple of EASA approvals that are sailplane specific but nothing that satisfies the lengthy list of hurdles the FSDO would likely accept.
Thoughts? Suggestions? Am I overthinking this?
Old February 26th 20, 04:05 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Shaun Wheeler wrote on 2/26/2020 6:55 AM:
What is the aircraft that needs the battery? None of the gliders I've had
specified the chemistry of the instrument battery, and those were all easily
removable, suggesting they are "portable" units and not part of the aircraft.
Old February 26th 20, 09:13 PM posted to rec.aviation.soaring
Shaun Wheeler
L33 solo.
Old February 27th 20, 05:43 AM posted to rec.aviation.soaring
2G
On Wednesday, February 26, 2020 at 1:13:46 PM UTC-8, Shaun Wheeler wrote:
L33 solo.
This may be of interest:
http://jdasolutions.aero/blog/faas-p...val-standards/
https://www.aviationpros.com/engines...es-in-aircraft
This is a TSO'd 12V battery:
https://earthxbatteries.com/product-...ified-aircraft
To get approved it looks like any lithium ion battery will need a hardened case with venting to the outside of the A/C.
Tom
Old February 27th 20, 05:17 PM posted to rec.aviation.soaring
L33 solo.
Tom
"at an incredible introductory price of $699"
This is for a starter type/size battery (it says "840 Peak cranking amp").
Curiously that web page does not say what the chemistry is, other than "lithium", but the PDF brochure says "Custom made prismatic LiFePo4 cells".
I wonder: the (large, installed) lithium batteries that caught fire on some airliners, what chemistry were they?
Old February 27th 20, 05:37 PM posted to rec.aviation.soaring
Dave Walsh[_2_]
L33 solo.
http://jdasolutions.aero/blog/faas-p...m-ion-battery-
approval-standards/
https://www.aviationpros.com/engines...ents/aircraft-
airframe-accessories/batteries/article/12256058/lithiumion-
batteries-in-aircraft
Tom
amp").
other than
LiFePo4 cells".
on some
The DreamLiner batteries were LiPo (Lithium Polymer) I think. I
understand they are now in an externally vented metal box? Any
Boeing pilots like to confirm?
Old February 27th 20, 01:13 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Shaun Wheeler wrote on 2/26/2020 1:13 PM:
L33 solo.
Does the handbook specify the type of battery required for the instruments, or
prohibit LiFe batteries? If not, and it's easily removable, I think you can
reasonably claim it's a portable device and use one of your choosing in the
glider; after all, you likely have Lithium batteries in it already - your cell
phone, your inReach/Spot, your logger, and a handheld radio.
Old March 7th 20, 12:47 AM posted to rec.aviation.soaring
cdeerinck
While not necessarily applicable to your situation, FYI, DG prohibits the use of any Lithium-Ion (even LiFePO4) in the tail compartment of its gliders, which surprised me, and foiled my plans. I suspect they have their reasons.
I don't know if that applies to an LS or not.
Best to check with them on what is allowed in your situation.
Old March 7th 20, 03:49 AM posted to rec.aviation.soaring
John Foster
I wonder if that has as much to do with the weight (tail ballast) as much as it does with the fire hazard.
Old March 7th 20, 04:17 PM posted to rec.aviation.soaring
Dan Marotta
My LAK-17a had an SLA tail battery and it was needed as ballast. When I
got a LiFePO4 battery, I put it behind the seat and put a block of lead,
which matched the removed battery weight, in the tail.Â* I suppose I
could have simply left the dead battery there and saved some work but I
didn't want to risk it leaking.
Dan, 5J
Refit Bomber Aircraft Will Help Scientists Study the Total Solar Eclipse pics 2 [1/7] - WB-57 2.jpg (1/1) Miloch Aviation Photos 0 April 15th 17 03:33 PM
Refit Bomber Aircraft Will Help Scientists Study the Total Solar Eclipse [6/8] - kapa20130730-018.jpg (1/1) Miloch Aviation Photos 0 April 15th 17 03:29 PM
Refit Bomber Aircraft Will Help Scientists Study the Total Solar Eclipse [2/8] - 715100main_jsc2011e038628_1600_946-710.jpg (1/1) Miloch Aviation Photos 0 April 15th 17 03:29 PM
Refit Bomber Aircraft Will Help Scientists Study the Total Solar Eclipse Miloch Aviation Photos 0 April 15th 17 03:26 PM
Solar panel chargers and LiFePo batteries [email protected] Soaring 5 May 5th 14 02:09 AM
