#21
![]() "Andy Blackburn" wrote in message ... At 21:00 26 March 2005, Bill Daniels wrote: So, we shouldn't weed out anybody because we can't prevent all the accidents with one set of entry criteria? If just one marginal pilot is counseled to get more current, it's a win. I also never said that there aren't pilots in need of better technical skill or judgement, or that we shouldn't try to weed out pilots who are dangerous due to deficiencies in these areas. The hard part it how. I would add that it seems to me even harder to come up with a standard test for competence in something as complex as competition soaring, particularly given all the exogenous factors in flying. The 'drop a wing on takeoff and you're out' rule is a good example of how hard this could be. How do you allow for glider type, ballast, crosswind, density altitude, wing runner skill? I had a bad wing run (didn't take a single step) on a cross-wind day in and ASW-27B full of water. I had to abort when the wing went down. Did I flunk? I can just see the screaming match. Best to empower the CD to check pilots informally - particularly the unknown/unseeded ones. 9B The wing drop thing is easy to judge. Just watch the ailerons. If they don't start to move until the wing hits the ground or nearly so, it's pilot error. If they move to the stop as soon as the glider tilts a tiny bit yet the wing still goes down, he gets a pass. Any good instructor, towpilot, or any good pilot for that matter, can watch a takeoff and get a good idea of how well a pilot flies. BTW, there's a lot of heat AND light in this thread. I'll bet some folks are thinking about dehydration and how well they fly takeoffs. Thinking's a good thing. Bill Daniels |
August 4, 1086..............John you really are older than I
thought!!!!!!!!!!!!!!! wrote in message ups.com... Uvalde, Texas, August 4, 1086 (15 meter National Championships) ASW-20 crossed the finish line at 50 feet and 85 knots, then started a climbing turn to position himself on down-wind. Pilot sees another ship in the pattern and turns away to avoid a conflict.....................Let's stop the action for a moment and discuss some things. This pilot may have been suffering from the affects of dehydration, but his senses were working well enough to find the airport (per GPS) and make his high speed, low altitude pass through the finish gate. He responded to the "Good Finish" from the gate. He should have been able to complete the flight and make a safe landing. Why didn't he? Resume action...................Pilot leaves airport boundries and crashes in a housing area about 2 blocks north of the airport. He struck power lines and then hit a pick up truck squarely in the drivers door. The door collapsed inward absorbing a lot of energy. The whole truck then moved sideways until the wheels hit the curb, breaking both axles. The pilot received serious injuries to his feet and legs, but made a full recovery. I believe he owes his life to the great big shock absorber he ran into (truck). Let's discuss dehydration a bit. I know a pilot that crashed, severly dehydrated, at 4PM and he doesn't remember anything after breakfast. What does that mean? It means he functioned all day long, right up to the accident. He took off, towed, thermaled and flew some 60 miles cross country to make his rendezvous with destiny. What does all this have to do with anything? Just this; A dehydrated mind is still functioning and can perform simple, well rehearsed, tasks. It's the unexpected that gets you, like a conflict in the pattern. Had the GPS Finish Cylinder been available, would the outcome of this accident been any different? The pilot was functioning well enough to find the airport and he had a plan. It was to finish and pull-up. Had the finish cylinder been in use, his plan would have been to finish (1 mile) and land. Doc Cannon (NT) will tell you the simple act of pulling up is enough to shut down a dehydrated mind. I know, some still make a hard pull-up at the 1 mile mark. I don't, because it is no longer necessary. I am most likely to make a gentle pull-up and then just allow any excess speed to bleed off as I fly the remaining mile to the airport. JJ Sinclair (2 of 5) |
Andy,
I was not implying that anyone is stupid. I would never do that, either. I was trying in my poor manner to suggest that I was a knucklehead for flying at all. I've been around soaring most of my life and I'll tell you some of the most gifted people I know are glider pilots. I'm not a stupid man, myself. I made a dumbass decision to fly yesterday, and the results could have been really bad. So, thanks for making an exception for me. The medication was Naproxen, an anti-inflamatory with some known side effects. From the days activities, I was definitely dehydrated. If urine color is a good indicator of that, it was darker than I remember it for some time. My blood sugar was probably low, and I have low blood pressure on top of all of that. Not a good combination, but I'm here to talk about it. Again, I made a bonehead decision, and got away with it... this time. Sorry if my post sounded bad, as it wasn't intended. Jack Womack |
It occurs to me that if someone is on final glide at
the end of a competition, they may pick a speed (like 85 knots) which their computer says is optimal for points, but which is both: 1) too fast for a rolling finish/landing and 2) too slow for a pull up, turn around, and landing. Is that an accurate assessment? Would a competition pilot be put in a situation where he must decide between points and safety of the landing? Or am I misconstuing this. At 22:00 26 March 2005, John Sinclair wrote: Two different accidents here, the Uvalde ASW-20 driver didn't loose consciouness and remembered things like 85 knots. Another crash that I know about the pilot didn't remember anything after breakfast. JJ At 18:00 26 March 2005, Hl Falbaum wrote: There is an alternate, more plausible explanation for the lack of memory. Fairly minor concussions can produce a phenomenon called retrograde amnesia. This is seen in motor vehicle accidents and falls from heights. So the brain would be functioning fairly normally, and not on 'autopilot' untill the accident. Then after consciouness is regained, the person reccalls nothing for a variable period of time prior to the accident. BTW how do we know then that the spped was 85 kt? -- Hartley Falbaum, M.D., FAAOS ASW27B 'KF' USA wrote in message roups.com... Uvalde, Texas, August 4, 1086 (15 meter National Championships) ASW-20 crossed the finish line at 50 feet and 85 knots, then started a climbing turn to position himself on down-wind. Pilot sees another ship in the pattern and turns away to avoid a Let's discuss dehydration a bit. I know a pilot that crashed, severly dehydrated, at 4PM and he doesn't remember anything after breakfast. What does that mean? It means he functioned all day long, right up to the accident. He took off, towed, thermaled and flew some 60 miles cross country to make his rendezvous with destiny. What does all this have to do with anything? Just this; A dehydrated mind is still functioning and can perform simple, well rehearsed, tasks. It's the unexpected that gets you, like a conflict in the pattern. JJ Sinclair (2 of 5) Mark J. Boyd |
Jack,
Maybe as much as a half-dozen times this has happened to me before or during a flight. I pride myself on a very good 'mission go' record, perhaps 98-99%. But several times I have flown on super hot days, and just not been able to well above the inversion layer, and I'm hot, and I got some nasty water or a bad sandwich or something. Landed, and had to explain to a bunch of folks that I wasn't gonna fly any more that day because I just wasn't feeling great. No specific thing, just knew I was off. Maybe didn't drink enough before the flight, maybe too much, maybe I just hadn't had a good run or bikeride for a while and was just weirdly out of shape. So there's other people who are in the same boat sometimes. At 20:00 26 March 2005, Jack wrote: Yesterday, about the first soaring day we have had in Houston, I decided to fly. I had taken a 1-hour walk that morning. I had done some things around the house. I went to the airport and helped someone else assemble a ship, then assembled mine. I drank normal amounts of fluids. I drank a 16 oz. bottle of water just prior to takeoff. I flew only 49 minutes. Someone had to tell me to raise my gear after launch. I felt fine at first, but soon began to make little mistakes. I couldn't seem to keep up with the thermals. I did some cruising around and some dolphin flying, and realized I was getting airsick. I've never felt airsick in my life. I couldn't put it together. I found 8 knots up and flew a couple of minutes in that before finally realizing I was not feeling better, and not flying better. Finally I pulled the flaps down at 4600 feet and made a bee line for the airport IP. I got there fast with 90 degrees of flap. I declared my intent to land and proceeded to do so. At about 10 feet, my radio crackeld 'LANDING GEAR!' and I barely got it down in time. Some facts: I am taking a medication that can cause these effects. I had no lunch. I haven't flown seriously for a dozen years. This is my first ship with a retractable gear. I am certain I was dehydrated. Does that make me a knucklehead? In my opinion, IT DOES! I should have been more familiar with the medication. I should have had lunch. I should have come down at the first sign that things weren't going well. Actually, I shouldn't have flown at all, though the beginning of the flight went fine. True self-evaluation can possibly save your life. I won't fly again until I know the effects of this medicine are gone. I will fly a lot more before attending Region 10 this year. Unfortunately, people make bad decisions. I got away with it... this time. Jack Womack Andy Blackburn wrote: At 18:00 26 March 2005, Bb wrote: It is simply not true that the only people who crash are inexperienced 'poor pilots' who could be 'weeded out' by any entry criteria. I'm with the Professor on this one. The worst thing we can do in reviewing accidents is assert that the pilot was knucklehead. This may make us all feel better, but we will learn very little. Some accidents are the result of a single catastrophic misjudgement, but most I've looked at have resulted from a series of decisions or circumstances that individually seemed fairly benign, but compounded to create an outcome that was both unpleasant and inevitable. Those who don't learn from the past... 9B Mark J. Boyd |
Jack,
Thanks for sharing this experience with the rest of us. I really respect you for being so honest about your flight. I know many pilots who would not. It is always a great reminder that ALL pilots have bad days and that the good ones recognize it and are honest about it so the rest of us can learn from their experiences. Bruno |
M B wrote: It occurs to me that if someone is on final glide at the end of a competition, they may pick a speed (like 85 knots) which their computer says is optimal for points, but which is both: 1) too fast for a rolling finish/landing and 2) too slow for a pull up, turn around, and landing. Is that an accurate assessment? Would a competition pilot be put in a situation where he must decide between points and safety of the landing? It seems to me that 85 knots is a little too slow to do a full circuit from, but plenty do do a 180, or a 360, or an abbreviated circuit similar to a rope-break exercise. Someone gave a figure of 9 ft of pullup for each knot of speed. That's about right for speeds around 110 knots, but is a gross overestimate for speeds around 80 or 90 knots (and an underestimate for higher speeds). The true numbers are quadratic. If you want a rule of thumb I suggest the following: take speed in knots, double it, drop off the last digit, square what is left giving height for a pull-up in feet. This calculation gives just over 90% of the theoretical maximum pull-up, which is proabably not a bad figure taking into the drag loses. Note that this is for a pull up to a zero speed hammerhead. For a pull up to flying speed you need to subtract the appropriate height for your circuit speed e.g. 100 ft for 50 knots. examples, from zero-height finish, 50 knot circuit speed: 50 knots - 100 - 10, squared = 100 ft gain, 0 ft AGL @ 50 kt 60 knots - 120 - 12, squared = 144 ft gain, 44 ft AGL @ 50 kt 80 knots - 160 - 16, squared = 256 ft gain, 156 ft AGL @ 50 kt 90 knots - 180 - 18, squared = 324 ft gain, 224 ft AGL @ 50 kt 100 knots - 200 - 20, squared = 400 ft gain, 300 ft AGL @ 50 kt 120 knots - 240 - 24, squared = 576 ft gain, 476 ft AGL @ 50 kt 150 knots - 300 - 30, squared = 900 ft gain, 800 ft AGL @ 50 kt A pull up from 85 knots to 50 knots will give you about a 200 ft height gain, plus whatever height your finish was at. We give students rope breaks at 200 ft, right? So a competent and alert pilot should have no trouble deciding whether to land straight ahead after the pull up or do an abbreviated circuit. -- Bruce | 41.1670S | \ spoken | -+- Hoult | 174.8263E | /\ here. | ----------O---------- |
I was in a flying camp during a holiday and after 10 days straight
flying 5-8 hrs per day cross country in hot dry weather I took off in the ASW19 and began to get disorientation and and feeling unwell, I elected to land back ,I was so unsure of my reaction times etc set 65-70 knots with full brakes and let her fly to the deck leveled off at flare height and waited for the ASW19 to settle on the runway (5000ft long) .I got some odd looks at the way I landed . One of the club members present was a doctor and he said sunstroke and dehydration accummulated over the last 10 days . I did not fly for the rest of the week. "It was a lesson I won't forget " "M B" wrote in message ... Jack, Maybe as much as a half-dozen times this has happened to me before or during a flight. I pride myself on a very good 'mission go' record, perhaps 98-99%. But several times I have flown on super hot days, and just not been able to well above the inversion layer, and I'm hot, and I got some nasty water or a bad sandwich or something. Landed, and had to explain to a bunch of folks that I wasn't gonna fly any more that day because I just wasn't feeling great. No specific thing, just knew I was off. Maybe didn't drink enough before the flight, maybe too much, maybe I just hadn't had a good run or bikeride for a while and was just weirdly out of shape. So there's other people who are in the same boat sometimes. At 20:00 26 March 2005, Jack wrote: Yesterday, about the first soaring day we have had in Houston, I decided to fly. I had taken a 1-hour walk that morning. I had done some things around the house. I went to the airport and helped someone else assemble a ship, then assembled mine. I drank normal amounts of fluids. I drank a 16 oz. bottle of water just prior to takeoff. I flew only 49 minutes. Someone had to tell me to raise my gear after launch. I felt fine at first, but soon began to make little mistakes. I couldn't seem to keep up with the thermals. I did some cruising around and some dolphin flying, and realized I was getting airsick. I've never felt airsick in my life. I couldn't put it together. I found 8 knots up and flew a couple of minutes in that before finally realizing I was not feeling better, and not flying better. Finally I pulled the flaps down at 4600 feet and made a bee line for the airport IP. I got there fast with 90 degrees of flap. I declared my intent to land and proceeded to do so. At about 10 feet, my radio crackeld 'LANDING GEAR!' and I barely got it down in time. Some facts: I am taking a medication that can cause these effects. I had no lunch. I haven't flown seriously for a dozen years. This is my first ship with a retractable gear. I am certain I was dehydrated. Does that make me a knucklehead? In my opinion, IT DOES! I should have been more familiar with the medication. I should have had lunch. I should have come down at the first sign that things weren't going well. Actually, I shouldn't have flown at all, though the beginning of the flight went fine. True self-evaluation can possibly save your life. I won't fly again until I know the effects of this medicine are gone. I will fly a lot more before attending Region 10 this year. Unfortunately, people make bad decisions. I got away with it... this time. Jack Womack Andy Blackburn wrote: At 18:00 26 March 2005, Bb wrote: It is simply not true that the only people who crash are inexperienced 'poor pilots' who could be 'weeded out' by any entry criteria. I'm with the Professor on this one. The worst thing we can do in reviewing accidents is assert that the pilot was knucklehead. This may make us all feel better, but we will learn very little. Some accidents are the result of a single catastrophic misjudgement, but most I've looked at have resulted from a series of decisions or circumstances that individually seemed fairly benign, but compounded to create an outcome that was both unpleasant and inevitable. Those who don't learn from the past... 9B Mark J. Boyd |
#29
Hahaha...
I'l try this in the 2-33 at Vne (about 80 knots) and see if I get over 200 ft 'regained' I doubt it. But then again, that's maybe off topic. I think your calculations are for gliders that don't fly like they have a parachute attached to the back, right? ![]() I'm sure even the Blanik will get numbers fairly close to what you write, but I'lll give it a go (at altitude). Passengers love to 'zoom' so this should be fun... At 06:30 27 March 2005, Bruce Hoult wrote: In article , M B wrote: It occurs to me that if someone is on final glide at the end of a competition, they may pick a speed (like 85 knots) which their computer says is optimal for points, but which is both: 1) too fast for a rolling finish/landing and 2) too slow for a pull up, turn around, and landing. Is that an accurate assessment? Would a competition pilot be put in a situation where he must decide between points and safety of the landing? It seems to me that 85 knots is a little too slow to do a full circuit from, but plenty do do a 180, or a 360, or an abbreviated circuit similar to a rope-break exercise. Someone gave a figure of 9 ft of pullup for each knot of speed. That's about right for speeds around 110 knots, but is a gross overestimate for speeds around 80 or 90 knots (and an underestimate for higher speeds). The true numbers are quadratic. If you want a rule of thumb I suggest the following: take speed in knots, double it, drop off the last digit, square what is left giving height for a pull-up in feet. This calculation gives just over 90% of the theoretical maximum pull-up, which is proabably not a bad figure taking into the drag loses. Note that this is for a pull up to a zero speed hammerhead. For a pull up to flying speed you need to subtract the appropriate height for your circuit speed e.g. 100 ft for 50 knots. examples, from zero-height finish, 50 knot circuit speed: 50 knots - 100 - 10, squared = 100 ft gain, 0 ft AGL @ 50 kt 60 knots - 120 - 12, squared = 144 ft gain, 44 ft AGL @ 50 kt 80 knots - 160 - 16, squared = 256 ft gain, 156 ft AGL @ 50 kt 90 knots - 180 - 18, squared = 324 ft gain, 224 ft AGL @ 50 kt 100 knots - 200 - 20, squared = 400 ft gain, 300 ft AGL @ 50 kt 120 knots - 240 - 24, squared = 576 ft gain, 476 ft AGL @ 50 kt 150 knots - 300 - 30, squared = 900 ft gain, 800 ft AGL @ 50 kt A pull up from 85 knots to 50 knots will give you about a 200 ft height gain, plus whatever height your finish was at. We give students rope breaks at 200 ft, right? So a competent and alert pilot should have no trouble deciding whether to land straight ahead after the pull up or do an abbreviated circuit. -- Bruce | 41.1670S | \ spoken | -+- Hoult | 174.8263E | /\ here. | ----------O---------- Mark J. Boyd |
#30
Mark,
Wise pilots include a safety margin in their altitude calculations. This is typically based on the availability of landable fields around the finish airport, the nature of the day, and the preferences of individual pilots. (I use +500 feet for airports with safe landing options.) The wise pilot uses best speed to fly up to a point between 5 and 10 miles from the airport, at which point he assesses his energy state (altitude and speed), conditions on course, and conditions at the finish. If no changes were made at this point, he would arrive at the finish "point" at best speed to fly with his safety altitude between him and the ground. Assuming the aforementioned conditions favor a flying finish, the pilot would convert his safety altitude to speed. This is why the decision to roll to a finish or fly through the gate is hardly split second. You've been assessing which to pursue for several minutes based on some very simple rules (how fast am I going, how high above my safety glide slope am I?). I know some pilots who have fine tuned this approach into an art. For example, a highly successful competitor shared tactics with me after a final glide we shared at Uvalde (he beat me by about 20 seconds in the last 5 miles). I maintained a typcial safe approach: 90 knots to 3 miles out, then increasing my speed to roughly 110 knots for arrival at the finish line, but he dove to nearly redline at 4 miles out. His logic went like this: I commited myself to a rolling finish. I new I would cross the threshold with about 80 knots, at which point I'd pull the brakes, drop the gear, and get myslef off the runway and stopped as quickly as I could. This wouldn't cost me very much time. But I aslo knew that the brown field just this side of the runway had produced noticeable lift that last few finishes. If it was true to form, it would give me enough extra energy for a flying finish. It was working, and I was able to maintain speed across the length of the field, which was more than enough to get me to the finish line with enough energy for safe pattern insertion. This demonstrates a much better understanding of sailplane performance than is typical. But the lesson here was that this pilot was already commited to a rolling finish. He was simply waiting a good reason to change his tactics. It came. Seems to me some pilots are so fixated on the finish line, they need a calamity to adjust their thinking, and then don't recognize the calamity taking shape as they lose altitude and airspeed during the last several miles to the finish. At a typcial nationals, 1 minute equals about 5 points. At worst, the choice of a rolling finish will cost you no more than 10 points. The decision to fly to the finish line at 85 knots without using your ready reserve of altitude might cost you 5 to 8 points. Look at your standings in the last contest you participated in... if you were more than 200 points behind the winner, you might want to reassess your priorities. If you're starting to get close, you might want to start working on your skills as well as your understanding of the risk /reward formulas for each phase of flight. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
